Web Content Viewer
Actions
VB-M44 Black
All Network Cameras
Item Code: 2542C002AA
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
  • 20x Optical Zoom with Fast and Precise Pan/Tilt Mechanism
  • 1.3 Megapixel (Native 1280 x 960 Resolution)
  • Updated 1/3" type CMOS Sensor with Superb Low Light Performance
  • Enhanced Presets That Include PTZ Positioning and Video Settings
  • Advanced DIGIC DV III Image Processor Helps Maximize Image Quality and Minimize Power Consumption
  • Area Specific Data Size Reduction and Motion Adaptive Noise Reduction
  • Smart Shade Control and Auto Gain Control Limit
  • Powerful DIGIC NET II Processor Allows Simultaneous Streaming of M-JPEG and H.264 Codecs in Multiple Resolutions
  • On-Board Video Analytics and Versatile Functions
  • Multiple Networking Functions
  • ONVIF Profile S and G Conformant
  • Built-in SD Card Slot with Enhanced SD Card Functionality
  • Various Power Options (12 V DC, 24 V AC and PoE IEEE 802.3af)
This is to make Misc appear on the page when needed.
CAMERA
IMAGE SENSOR
1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS
Approx. 1.3 million pixels
SCANNING METHOD
Progressive Scan
LENS
20x optical zoom lens with auto focus
FOCAL LENGTH
4.7 (W) - 94mm (T)
F-NUMBER
F1.6 (W) - F3.5 (T)
DIGITAL ZOOM
20x
HORIZONTAL VIEWING ANGLE (16:9)
60.4° (W) - 3.2° (T)
VERTICAL VIEWING ANGLE (16:9)
35.1° (W) - 1.8° (T)
DAY/NIGHT MODE
Yes
I/R CUT FILTER
Automatically removable infrared-cut filter
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
0.05 lux (F1.6, shutter speed 1/30 sec.)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
0.003 lux (F1.6, shutter speed 1/30 sec.)
FOCUS MODES
Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE
Day Mode: 0.3m (12 in.) - infinity (W), 1.0m (3.3 ft.) - infinity (T)
Night Mode: 1.0m (3.3 ft.) - infinity (W), 1.5m (4.9 ft.) - infinity (T)
SHUTTER SPEED
1 - 1/16000 sec.
EXPOSURE MODES
Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Auto (Aperture-priority AE)/
Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE
Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/Manual(One-shot WB/R Gain/B Gain)
METERING MODES
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
Auto / Manual / Disable
Auto: 3 Levels
Manual: 7 Levels
HAZE COMPENSATION
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT
6 levels
IMAGE STABILIZER
Digital (2 Levels)
MOTION ADAPTIVE NOISE REDUCTION
Available
CLEAR IR
N/A
PAN ANGLE RANGE
340° (±170°)
TILT ANGLE RANGE
100° (ceiling-mounted position: -90° - +10°)
ROTATION ANGLE RANGE
N/A
IR ILLUMINATION RANGE
N/A
MOVING SPEED
Pan: Max. 150°/sec.
Tilt: Max. 150°/sec.
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
BIT RATE CONTROL
VIDEO SIZE
JPEG, H.264: 1280 x 720, 640 x 360, 320 x 180
1280 x 960, 640 x 480, 320 x 240
VIDEO QUALITY
JPEG, H.264: 10 levels
FRAME RATE
JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
1280 x 960: 30 fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION
Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client
- H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec (Auto Key Exchange/Manual)
IEEE 802.1X
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version
ONVIF Profile S
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL
AUTO IP (LINK-LOCAL)
Yes
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Full-duplex (two-way)/half-duplex (One-way communication)
RTP, Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK
Available
PRIVACY MASK
Number of registration: Max. 8 places,
Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
Available
PRESETS
Max. 64 positions
INTELLIGENT FUNCTION - VIDEO
Moving object detection, abandoned object detection, removed object
detection, camera tampering detection, passing detection and intrusion detection
INTELLIGENT FUNCTION - AUDIO
Volume Detection & Scream Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
EVENT TRIGGER TYPE
External Device Input, Timer, Intelligent Function (Video),
Intelligent Function (Audio), Day/Night Switch
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72
640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
ENHANCED DIGITAL ZOOM
Available
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
Available
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
Φ3.5mm (Φ0.14 in.) mini-jack connector (monaural)
Switch LINE IN/MIC IN in the setting page.
AUDIO OUTPUT TERMINAL
LINE OUT x 1 (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL
Input x 2, Output x 2
ANALOG VIDEO OUT
N/A
MEMORY CARD TYPE
SD Memory Card, SDHC Memory Card, SDXC Memory Card Compatible
MEMORY CARD RECORDED CONTENT
Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE
OPERATING ENVIRONMENT
TEMPERATURE
Temperature: -10°C - +50°C (+14°F - +122°F)
HUMIDITY
Humidity: 5% - 85% RH (without condensation)
STORAGE ENVIRONMENT
TEMPERATURE
-30°C - +60°C (-22°F - +140°F)
HUMIDITY
5% - 90% RH (without condensation)
POWER SUPPLY
PoE
PoE power supply via LAN connector (IEEE802.3af compliant)
AC ADAPTER
PA-V18(100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE
24 V AC/12 V DC
MAXIMUM POWER CONSUMPTION
WITH PoE
Max. approx. 9.2 W
WITH AC ADAPTER
PA-V18 Max. approx. 9.9W (100 VAC)
PA-V18: Max. approx. 9.4W (240 VAC)
WITH 12VDC
Max. approx. 8.6 W
WITH PoE +
N/A
WITH 24VAC
Max. approx. 8.8 W
OTHER
DIMENSIONS
(Φ x H) Φ132 x 155mm (Φ5.20 x 6.10 in.)
MOUNTING POSITION
Ceiling mount
HEATER
N/A
WEIGHT
Approx. 1140 g (2.52 lb.)
OUTDOOR READY
No
IP RATING
N/A
VANDAL RESISTANT
No
IMPACT RESISTANCE
N/A
VB-M44 Network Camera
VB-M44 Network Camera VB-M44 Main Body Power Connector Installation Guide Warranty Card
Brochures
Loading...
 Return to Top
