Web Content Viewer
Actions
VB-M50B
All Network Cameras
Item Code: 1064C001AA
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
An Advanced Lens with large aperture ratio range of F1.8 (W) to F2.4 (T) and focal length range of 17.7mm - 88.5mm works in combination with a high sensitivity sensor to achieve exceptional low-light clarity even at long distances. The large aperture allows greater quantities of light to hit the high-sensitivity sensor resulting in video with exceptional color in low light at both the wide and telephoto ends of the zoom range.
Fast and Precise Pan / Tilt Mechanism allows for 300°/second panning and tilting speeds when moving between presets. This enables video of the desired areas to be taken with as little delay as possible which can allow security personnel to more rapidly respond to situations.
This camera is equipped with a motorized pan/tilt function and a 5x Optical Zoom Lens for accurate subject tracking and zooming in on a subject while retaining high image quality. The capability to save up to 64 preset pan/tilt/zoom positions, which can then be later recalled, helps eliminate the time required to move between positions.
64 Preset Positions with 5 Preset Tour Routes allows users to automate camera movement to different areas of interest at different times of the day in order to cover more area with a single camera. This model will support creation of up to 64 preset camera positions and scheduling of up to 5 preset tour routes*.
The camera will internally save the desired pan/tilt/zoom (PTZ) position of the camera so that the user can choose to easily return to that position at a later occasion without having to manually adjust the PTZ positions of the camera each time.
Also included in the presets are Focus Mode, Exposure, Slow Shutter, White Balance, Clear IR Mode, Day/Night, and other settings in order to save the user from having to make frequent manual adjustments to these camera controls.
Preset tour routes program the camera to constantly move between different presets in sequence. The speed of movement between each preset can also be precisely configured to ensure proper monitoring of an entire area.
*If the durability limit for the pan/tilt operations is exceeded, the motors may need to be replaced
High-Sensitivity CMOS Sensor helps to deliver outstanding color and clarity even in challenging low-light conditions. In conjunction with the camera's Genuine Canon lens and DIGIC DV III image processor - the High-Sensitivity CMOS sensor make it possible to capture video footage in light levels of less than 0.01 lux.
Clear IR Mode uses an Infrared Bandpass Filter (IRBPF) that only permits infrared light to pass through to the image sensor, blocking visible light in order to achieve greater visibility and image sharpness in the presence of IR lighting. This added filter helps to reduce haze, shimmering, blurring and aberrations caused by visible light so that fine details can be discernable in the resulting video*. This is useful in applications such as license plate recognition where bright vehicle headlights can potentially blind the camera.
*As with Night Mode, the resulting video from Clear IR Mode will be monochrome.
Image Stabilization is an optional feature that can be used to help reduce motion blur caused by wind or mechanical vibration. The camera calculates the amount of vibration being experienced both horizontally and vertically and stabilizes the image by digitally removing pixels, which results in capturing video with minimized motion blurring.
This network camera is equipped with an impressive selection of video capture settings that can be tailored to better accommodate environmental lighting changes, such as shifts in sunlight direction and during the transitions between day and night. Users are able to define presets that include settings such as shutter speed, gain, aperture, white balance, day/night mode and more in addition to the camera's pan/tilt/zoom position. These presets can be recalled on a schedule or can tie-in with the camera's automatic day/night switch options to help ensure high-quality video even in situations with varying ambient light conditions.
For maximized image quality, Canon has incorporated the same DIGIC DV III Image Processor used in many of its high-end DSLR cameras in order to reproduce video with life-like colors, tonal accuracy, smooth gradation and reduced noise. Unlike other cameras that rely on a shared processor for image quality and compression, Canon network cameras are engineered with a DIGIC DV III Image Processor solely dedicated to maximizing image quality.
Canon's DIGIC DV III Image Processor is a high-speed engine with maximum processing power which helps to optimize overall video quality with:
  • Vivid, life-like color reproduction and image clarity
  • Rich, smooth gradations
  • Drastically reduced image noise
DIGIC NET II Processor is a powerful and efficient compression, encryption, and transmission processor that gives Canon Network Cameras the ability to simultaneously deliver standard HD (1280 x 960) video at 30 frames per second in both M-JPEG and H.264 codecs. Users have the flexibility of streaming multiple resolutions of M-JPEG and H.264, all while minimizing power consumption. In situations where remote cameras are using cellular data, users can potentially realize substantial savings in data charges.
Area-Specific Data Size Reduction (ADSR) is an optional function that allows users to reduce bandwidth consumption and video storage space requirements, thus lessening the need for expensive networking and storage equipment. The reduction in bandwidth and storage is achieved by defining up to eight specific areas in the camera's field of view which are most critical and where high video quality must be maintained, while video quality in the rest of the camera's field of view is lowered.
Motion Adaptive Noise Reduction helps reduce overall bandwidth consumption and lower the costs associated with transmitting data, while providing clean images in low light areas where motion is detected. Areas without motion receive added noise reduction thus minimizing bandwidth consumption, while areas with motion receive a smaller amount of noise reduction resulting in greater visual clarity for optimized monitoring and surveillance.
A host of intelligent On-board Video Analytics have been built into the camera to aid in analyzing video content for the purposes of identifying and alerting potentially critical situations. For maximum flexibility, detection characteristics (sensitivity, area and duration) can be finely tuned by users to allow for precise event detection by the camera, while notification tools can alert the correct parties to help expedite response time. In addition, costly storage space can be saved by using these On-board Video Analytics as triggers to start recording so that the camera does not have to continuously record during all hours of the day.
Moving Object Detection - used to detect moving objects, such as persons or vehicles, in predefined areas such as hallways and parking lots.
Abandoned Object Detection - used to identify motionless objects that have been left behind by a moving object such as a suspicious package placed on a city street.
Removed Object Detection - used to identify the removal of a static object from a designated area, such as a priceless painting in a museum/gallery.
Camera Tampering Detection - used to detect the tampering of a camera such as redirection, blocking, defocusing, or even spray paint.
Passing Detection - used to detect when a moving object passes through the camera's field of view in a specified direction, such as an individual entering into a restricted area from the exit doorway.
Intrusion Detection - used to identify when a moving object enters and remains in a specified area for a period of time deemed unacceptable, such as an individual stepping over a partition in a museum.
The Open Network Video Interface Forum (ONVIF) is a growing industry standard that promotes interoperability of security devices and eliminates the need for custom drivers. This network camera supports ONVIF Profile S which helps ensure that basic features such as video streaming, pan / tilt / zoom control, audio streaming and more, will work properly with a wide array of VMS systems. This camera also supports ONVIF Profile G which specifies SD card recording, searching and streaming compatibility.
Camera Viewer with Mobile Device Support allows user to access the camera's functionality from any location via the web browser on their PC or mobile device. The "Mobile Viewer" interface is designed to provide easy control of the essential functions necessary to operate the camera (video stream, pan/tilt/zoom control, presets, exposure settings, etc.) via the touch screens of mobile iOS or Android devices. Installers can also quickly configure their camera at the installation site and remotely control it.
The Low Power Consumption offered by this camera helps reduce the potential occurrence of overheating and failure. In addition, overall system power requirements are lessened, potentially giving the user the ability to save on energy, back-end equipment and hardware costs while lowering environmental impact.
The Built-in SD Card Slot, which supports SD, SDHC and SDXC memory cards, provides temporary secondary storage for video data and camera logs. In addition, the memory card recording can be used in remote deployments to reduce the amount of additional hardware needed to store video.
Live images and H.264 video can be saved to the memory card during network outages, event triggers, at scheduled times and manually via the Camera Viewer. When issues occur, system logs can also be created on the memory card for future troubleshooting.
The Recorded Video Utility allows for searching, downloading and viewing the recorded video and the Canon Camera Management Tool allows for backing up and restoring camera settings to/from the memory card.
An optional "Auto Video Delete" feature allows the user to define a retention period for recorded videos (up to 90 days).
This network camera accepts 24 V AC, 12 V DC and Power over Ethernet (PoE) offering flexibility when it comes to utilizing power sources available at the installation location.
This network camera can be installed in environments where a high level of network security is of extreme importance. It supports IEEE802.1X authentication, which provides additional network security with port-based access control that helps ensure only authorized client devices are connected to the network. In addition, IPSec is used to encrypt all packets of IP data sent over the network and SSL/TLS is used to safeguard data by encrypting sensitive information transmitted between a client and an application.
I/O support can be used to move the camera to a particular position or trigger an alarm when a door is opened or closed. An external microphone and speakers can be attached to this network camera so that the operator can hear what is going on at the camera location as well as playback audio files to people at that site.
CCMT provides a powerful, single unified method of configuring and managing all Canon network cameras on the local network. CCMT not only saves valuable time by streamlining the initial camera configuration, but greatly simplifies the management of an entire Canon network camera deployment. This tool supports network settings configuration, batch firmware upgrades, settings backup/restore, modifying video stream settings, and more.
CAMERA
IMAGE SENSOR
1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS
Approx. 1.3 million pixels
ANALOG VIDEO RESOLUTION
N/A
ANALOG VIDEO STANDARD
N/A
ANALOG S/N RATIO
N/A
SCANNING METHOD
Progressive Scan
LENS
5x optical zoom lens with auto focus
FOCAL LENGTH
17.7(W) - 88.5mm(T)
F-NUMBER
F1.8 (W) - F2.4(T)
DIGITAL ZOOM
20x
HORIZONTAL VIEWING ANGLE (16:9)
15.6° (W) – 3.2° (T)
VERTICAL VIEWING ANGLE (16:9)
8.8° (W) – 1.8° (T)
DAY/NIGHT MODE
Yes
I/R CUT FILTER
Automatically removable infrared-cut filter
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
.04 lux (F1.8, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
.002 lux (F1.8, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
FOCUS MODES
Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE
Day Mode: 3.0 m (9.8 ft.) – infinity (W), 5.0 m (16.4 ft.) – infinity (T)
Night Mode: 3.0 m (9.8 ft.) – infinity (W), 5.0 m (16.4 ft.) – infinity (T)
SHUTTER SPEED
1 – 1/16000 sec.
EXPOSURE MODES
Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Auto (Aperture-priority AE)/Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE
Auto/Light Source/Manual
Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp
Manual: One-shot WB/R Gain/B Gain
METERING MODE
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
HAZE COMPENSATION
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT
6 levels
IMAGE STABILIZER
Digital (2 levels)
PAN ANGLE RANGE
348° (±174°)
TILT ANGLE RANGE
105° (ceiling-mounted position: -90° – +15°)
ROTATION ANGLE RANGE
N/A
IR ILLUMINATION RANGE
N/A
MOVING SPEED
Pan: Max. 300°/sec., Tilt: Max. 300°/sec.
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
BIT RATE CONTROL
Target Bit Rate: 64–16384 kbps
VIDEO SIZE
JPEG, H.264: 1280 x 720, 640 x 360, 320 x 180
1280 x 960, 640 x 480, 320 x 240
SIMULTANIOUS VIDEO STREAMS
N/A
VIDEO QUALITY
JPEG, H.264: 10 levels
FRAME RATE
JPEG: 0.1 – 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
1280 x 960 : 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION
Number of Specified Areas: Max. 8 areas
Data Size Reduction Level: 3 levels
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client
– H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user (level of control varies depending on user)
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec
IEEE 802.1X
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version
Profile S, Profile G
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL
AUTO IP (LINK-LOCAL)
Yes
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Full-duplex (two-way) – Echo cancellation function compliant
RTP, Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK
Available (audio files can be played back when an event is triggered by the intelligent function or external device input)
PRIVACY MASK
Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
Available
PRESETS
Number of registers: Max. 64 positions (+Home Position)
Number of Preset Tour Route: Max. 5
INTELLIGENT FUNCTION - VIDEO
Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection
INTELLIGENT FUNCTION - AUDIO
Volume Detection, Scream Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
EVENT TRIGGER TYPE
External Device Input, Intelligent Function (Video), Intelligent Function (Audio), Timer, Day/Night Switch
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72
640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
Available
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
ϕ3.5 mm (ϕ0.14 in.) mini-jack connector (monaural)
LINE IN (connect to an amplifier microphone) or MIC IN (connect to a microphone w/o amplifier)
– Switch LINE IN/MIC IN in the setting page.
AUDIO OUTPUT TERMINAL
LINE OUT (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL
Input x 2, Output x 2
ANALOG VIDEO OUT
N/A
MEMORY CARD TYPE
SD Memory Card, SDHC Memory Card, SDXC Memory Card Compatible.
Frame Rate: Max. 1 fps (JPEG), Max. 30fps (H.264)
MEMORY CARD RECORDED CONTENT
Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE
Max. 1 fps (JPEG)
Max. 30 fps (H.264)
OPERATING ENVIRONMENT
TEMPERATURE
AC, DC, PoE: -10°C - +50°C (+14°F - +122°F)
HUMIDITY
5% – 85% (without condensation)
STORAGE ENVIRONMENT
TEMPERATURE
-30°C – +60°C (-22°F – +140°F)
HUMIDITY
5% – 90% (without condensation)
POWER SUPPLY
PoE
PoE power supply via LAN connector (IEEE802.3at Class 0 compliant)
AC ADAPTER
PA-V18 (100 – 240 V AC) (sold separately)
EXTERNAL POWER SOURCE
24 V AC/12 V DC
POWER CONSUMPTION
WITH PoE
Max. approx. 9.8W
WITH AC ADAPTER
Max. approx. 11.2W
WITH 12VDC
Max. approx. 10W
WITH PoE +
N/A
WITH 24VAC
Max. approx. 9.6W
OTHER
DIMENSIONS
(ϕ x H) ϕ129 x 157 mm (ϕ5.08 x 6.18 in.)
MOUNTING POSITION
Horizontal
HEATER
N/A
WEIGHT
Approx. 1170g (2.58lb.)
OUTDOOR READY
No
IP RATING
N/A
VANDAL RESISTANT
No
IMPACT RESISTANCE
N/A
This is to make Misc appear on the page when needed.
VB-M50B Network Camera
VB-M50B Network Camera VB-M50B Network Camera Setup CD-ROM Straight Power Connector L-shaped Power Connector Installation Guide Warranty Card
Brochures
Loading...
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-M50B that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
A&E System Design Tools
Angle of View Calculator
Choose the camera with the required distances, scene sizes and focal lengths.
Note: For best results, please view the Calculator on either a desktop or laptop screen.
Angle of View Calculator >
Required Disk Space Calculator
Determine your surveillance system's hard drive storage space needs.
Required Disk Space Calculator >
Camera Layout Simulator
Place your cameras into a simulated environment to determine video coverage area.
Camera Layout Simulator >
DISCLAIMERS
©2016 Canon U.S.A., Inc. All rights reserved. Canon and DIGIC are registered trademarks of Canon Inc. in the United States and may also be trademarks or registered trademarks in other countries. “ONVIF” and ONVIF logo are trademarks of ONVIF Inc.. Some of the images and effects are simulated. Not responsible for typographical errors.
 Return to Top
