Web Content Viewer
Actions
VB-M600D
All Network Cameras
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
Third party integration is simple with the VB-M600D because it's ONVIF version 1.02 conformant. Compatibility with this standard protocol, as well as WebView - Canon's network camera protocol, enables the user to create a system which best meets their needs, with equipment from different manufacturers and third party recording software. It also simplifies the work of system integrators by expanding the ability to use third party recording software. This XML based standard systematizes the protocols of settings for camera, control and information acquisition. Among the functions supported are camera search by WS-Discovery, authentication by WS-Security, RTP streaming of video (JPEG, H.264), audio (G.711), events (including PTZ and Camera status) and Multicast. Network settings, camera system parameters, rebooting external IO control and preset home settings are also supported. In addition, SSL communication and setting of intelligent functions are also possible.
"ONVIF" and HTML5 are trademarks of ONVIF Inc.
With the VB-M600D is capable of acquiring exceptional color video down to 0.018 Lux and black/white video down to 0.001 Lux. This increased sensitivity brings astonishing clarity to video recorded in very challenging poorly lit areas or during nighttime surveillance.
Color image in light conditions of 0.4 lux Monochrome image in light conditions of 0.1 lux
The megapixel CMOS Sensor of the VB-M600D ensures the maximum in image quality, a hallmark of Canon products. It's approximately 1.3 million pixels delivers sharp, high resolution video with four times the detail of a VGA resolution camera for clearer, more useful video monitoring.
The VB-M600D is able to deliver superb visual quality and image consistency thanks to the brilliant lens technology Canon brings to this camera. The 101.2º of coverage gives a more complete view of your location and the minimal aberration lens provides delivers clear, sharp video throughout the entire field of view.
The VB-M600D features the Remote Adjustment Function which saves time, energy and ultimately money by eliminating the need to set the Pan/Tilt/Rotation/Zoom and Focus during installation. Controllable from a remote location, installers can place the camera where it is best suited and then fine-tune the image area captured as required.
The VB-M600D is packed with features which enhance its functionality and usability. Among the most useful are its sophisticated On-board Video Analytics, enabling the camera to detect Moving, Abandoned, or Removed Objects in its range of vision, and also detect attempts at Camera Tampering and changes in Sound Levels. For added control, the VB-M600D also offers a Privacy Mask function which allows the blocking of certain areas of the camera's field of view, to protect from inadvertent intrusions of privacy or password theft (even during P/T/Z operations the specified areas will be masked).
Thanks to the VB-M600D's impressive algorithm highly precise detection is achieved by using polygonal and rectangle shapes to specify up to 15 areas of detection (as opposed to only using rectangle shapes like some competitor models). Additional flexibility is provided in that notification of a detection can be made through the network from the camera using a number of functions including automatic recording, e-mail transmission, uploading video to a specified target server and events in ONVIF by the RM server. It is also possible to combine a number of detection functions for simultaneous notification.
Specifying areas of detection using polygonal shapes increases accuracy.
Specifying areas of detection using rectangular shapes limits accuracy.
Moving Object Detection
Suspicious person who is trying to break in to the building is detected.
Removed Object Detection
Theft of valuables is detected.
Abandoned Object Detection
Suspicious parked car is detected.
Camera Tampering Detection
Changing the camera's angle and obstructing the surveillance visual with spray-paints or cloth is detected.
Sound Level Detection
Vandalism is detected.
Privacy Mask Function
Certain areas of the camera's view can be blocked, enabling fine security countermeasures against invasion of privacy and password theft by the camera.
"ONVIF" and are trademarks of ONVIF Inc.
All encoding and transmission is performed with Canon's proprietary hardware-based compression engine called DIGIC NET. This powerful processor allows the VB-M600D to simultaneously deliver both H.264 and JPEG video in high resolution 1280 x 960 at the maximum frame rate of 30fps - with no loss in frame rate, unlike many competing models.
The H.264 Codec of the VBM600D provides superb image compression, delivering high resolution images with small data size, thereby resulting in low bandwidth utilization. The benefits are obvious, with an infrastructure cost savings as well as reduced data storage capability needs, all while maximizing the quality of the video image.
Video CompressionImage Sizes
H.2641280 x 960, 640 x 480, 320 x 240
JPEG1280 x 960, 640 x 480, 320 x 240, 160 x 120
When faced with the challenge of capturing an image which has a bright background, the solution is found in Canon's exclusive Smart Shade Control, or SSC. It automatically compensates for the problem, adjusting the contrast of the darker areas without losing the brightness of the lighter areas. It will substantially reduce the instance of difficult to read or hidden information.
As the available light changes, the Auto Day/Night feature allows this camera to automatically adjust to maintain optimal image quality. This feature of the VB-M600D is especially useful for installations near doors, windows or skylights as the Auto Day/Night function can achieve up to 40x increased image sensitivity.
The VB-M600D supports IEEE 802.3af compliant Power over Ethernet (PoE) technology, which allows the use of a single LAN cable to both power the camera and transfer video and audio data when connected to a PoE switch. By eliminating the need to run AC connections to installation sites of the cameras, installation costs are kept to a minimum. In addition, there is more flexibility in placement of the VB-M600D and this offers a convenient way to provide a conduit for remote control and access.
With the VB-M600D, you can have two-way mono audio communication between the remote monitoring center and the surveillance location. G.711μ-Law compliant, it offers echo cancellation. This feature allows the camera to serve as an even more powerful component of your security infrastructure.
Audio output can be set to playback pre-recorded audio when triggered by an event like motion detection
The VB-M600D has a built-in SD Memory Card slot, allowing streamed images from the camera as well as uploaded images to be saved to an SD card, providing a backup in case of problems with the network. In addition, when issues occur system logs are also created and stored on the SD card for future troubleshooting.
For security in network communication, the VB-M600D supports both HTTPS as well as IPsec encryption.
Canon's proprietary software is included at no cost with the purchase of VB-M600D. It allows for the monitoring, recording and playback of up to four cameras.
VB-M600D Network Camera
VB-M600D Network Camera VB-M600D Network Camera Installation Template Power Connector Setup CD-ROM Installation Guide Audio Cable Warranty Card Safety Wire
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-M600D that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
A&E System Design Tools
Drawings / 3D CAD
File Description:
Date
01/21/14
Size
156 KB
File Description:
Date
01/21/14
Size
27 KB
File Description:
Date
01/21/14
Size
3.75 MB
File Description:
Date
01/21/14
Size
124 KB
File Description:
Date
01/21/14
Size
3.275 MB
File Description:
Date
01/21/14
Size
134 KB
Angle of View Calculator
Choose the camera with the required distances, scene sizes and focal lengths.
Note: For best results, please view the Calculator on either a desktop or laptop screen.
Work on-line >
Download Tool >
Required Disc Storage Calculator
Determine your surveillance system's hard drive storage space needs.
Work on-line >
Download Tool >
This is to make Misc appear on the page when needed.
CAMERA
IMAGE SENSOR
1/3 type CMOS (primary color filter)
NUMBER OF EFFECTIVE PIXELS
Approx. 1.3 million pixels
ANALOG VIDEO RESOLUTION
N/A
ANALOG VIDEO STANDARD
N/A
ANALOG S/N RATIO
N/A
SCANNING METHOD
Progressive
LENS
3x Optical zoom Lens
FOCAL LENGTH
2.8 (W) - 8.4 mm (T)
F-NUMBER
F1.2 (W) - F2.0 (T)
HORIZONTAL VIEWING ANGLE
101.2° (W) - 33.7° (T)
VERTICAL VIEWING ANGLE
74.7° (W) - 25.3° (T)
DAY/NIGHT SWITCH
Auto/Manual
I/R CUT FILTER
Removable
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
0.25 lux (F1.6, when shutter speed is 1/30 sec., when SSC is off)
0.07 lux (F1.6, when shutter speed is 1/8 sec., when SSC is off)
0.018 lux (F1.6, when shutter speed is 1/8 sec., when SSC is on)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
0.008 lux (F1.6, when shutter speed is 1/30 sec., when SSC is off)
0.002 lux (F1.6, when shutter speed is 1/8 sec., when SSC is off)
0.001 lux (F1.6, when shutter speed is 1/8 sec., when SSC is on)
FOCUS
One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE
Day Mode: 0.3m (12 in.) - infinity
Night Mode: 1.0m (3.3 ft.) - infinity
SHUTTER SPEED
1, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000,1/4000, 1/8000 sec.
EXPOSURE
Auto/Auto (Flickerless)/ Auto(Shutter-priority AE)/ Manual (Shutter Speed/Aperture/Gain)
WHITE BALANCE
Auto/Select Light Source (Warm Fluorescent, White Fluorescent, Daylight Fluorescent, Mercury Lamp, Sodium Lamp, Halogen Lamp)/Lock (One-shot WB)/Manual
METERING MODE
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
7 levels
SMART SHADE CONTROL
7 levels
AGC LIMIT
N/A
IMAGE STABILIZER
N/A
PAN ANGLE RANGE
350° (±175°)
TILT ANGLE RANGE
150° (±75°)
ROTATION ANGLE RANGE
350° (±175°)
MOVING SPEED
Pan: 19.2°/sec., Tilt: 14.2°/sec., Rotation: 43.7°/sec. - When the Camera Angle Setting Tool is used
SERVER
VIDEO COMPRESSION METHOD
H.264, JPEG
VIDEO SIZE
JPEG: 1280 x 960, 640 x 480, 320 x 240, 160 x 120
H.264: 1280 x 960, 640 x 480, 320 x 240
VIDEO QUALITY
JPEG, H.264: 5 levels
FRAME RATE
JPEG: 30 - 0.1 fps
H.264: 30/15/10 fps
MAXIMUM FRAME RATE
1280 x 960: 30 fps
I-FRAME INTERVAL
Fixed
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user Max. 50 user names and passwords registered for authorized users.
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4,IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec (Auto Key Exchange/Manual)
IEEE 802.1X
N/A
ONVIF Version
ONVIF Ver. 1.02
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (client), DHCP (client), DNS (client), ARP, ICMP, POP3, NTP, SMTP authentication, WV-HTTP (from Canon), ONVIF
IPv6 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SMTP (client), DNS (client), ICMPv6, POP3, NTP, SMTP authentication, WV-HTTP (from Canon), ONVIF
AUTO IP
N/A
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Full-duplex (two-way) - Echo cancellation function compliant
AUDIO FILE PLAYBACK
Available (audio files can be played back when an event is triggered by the intelligent function or external device input.)
PRIVACY MASK
Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
N/A
PRESETS
N/A
INTELLIGENT FUNCTION - VIDEO
Moving Object Detection, Abandoned Object Detection, Removed Object Detection, and Camera Tampering Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
INTELLIGENT FUNCTION - VOLUME
Volume Detection
EVENT TRIGGER TYPE
External Device Input, Intelligent Function (Video), Intelligent Function (Volume), Timer
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail) Temporary storage memory in camera: Max. 4 MB, Frame Rate: Max. 10 fps
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
N/A
DAYLIGHT SAVING TIME
N/A
CUSTOM SETTINGS
N/A
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
Φ3.5mm (Φ0.14 in.) mini-jack connector (monaural) - Connect via an audio interface cable (included) Switch LINE IN/MIC IN in the setting page. LINE IN x 1 (connect to an amplifier microphone) or MIC IN x 1 (connect to a microphone w/o amplifier)
AUDIO OUTPUT TERMINAL
Φ3.5mm (Φ0.14 in.) mini-jack connector (monaural) - Connect via an audio interface cable (included) LINE OUT x 1 (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL
Input x 2, Output x 2
ANALOG VIDEO OUT
N/A
MEMORY CARD
SD, SDHC, SDXC Memory Card Compatible. Frame Rate: Max. 1 fps
OPERATING ENVIRONMENT
TEMPERATURE
Temperature: -10°C - +50°C (+14°F - +122°F)
HUMIDITY
Humidity: 5% - 85% (without condensation)
POWER SUPPLY
PoE
PoE power supply via LAN connector (IEEE802.3af compliant)
AC ADAPTER
PA-V17 (100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE
24 V AC/12 V DC
POWER CONSUMPTION
WITH PoE
Max. approx. 8.6 W
WITH AC ADAPTER
Max. approx. 10.9 W
WITH 12VDC
Max. approx. 9.0 W
WITH 24VAC
Max. approx. 8.3 W
OTHER
DIMENSIONS
(Φ x H) Φ186 x 140mm (Φ7.32 x 5.51 in.)
MOUNTING POSITION
Horizontal / Vertical
HEATER
N/A
WEIGHT
Approx. 1200g (2.65 lb.)
OUTDOOR READY
No
IP RATING
N/A
VANDAL RESISTANT
No
IMPACT RESISTANCE
N/A
Brochures
Loading...
DISCLAIMERS
©2016 Canon U.S.A., Inc. All rights reserved. Canon and DIGIC are registered trademarks of Canon Inc. in the United States and may also be trademarks or registered trademarks in other countries. “ONVIF” and ONVIF logo are trademarks of ONVIF Inc.. Some of the images and effects are simulated. Not responsible for typographical errors.
 Return to Top
