Web Content Viewer
Actions
VB-M641V
All Network Cameras
Item Code: 0309C001AA
NETWORK VIDEO PRODUCTS NOW SOLD BY AXIS COMMUNICATIONS (A CANON GROUP COMPANY). Learn more on the Axis Communications website.
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
  • IK10 Vandal Resistant Enclosure
  • Canon's Unique Remote Adjustment Function for Easy Post-Installation Changes to the Camera's Pan/Tilt/Rotation Angles and Zoom
  • Canon 2.4x Optical Zoom Lens with 111.5° Angle of View
  • 1.3 Megapixel High-Sensitivity CMOS Sensor with Exceptional Low-Light Performance
  • Advanced DIGIC DV III Image Processor to help Maximize Image Quality
  • Haze Compensation, Smart Shade Control and Auto Gain Control Limit
  • Area-Specific Data Size Reduction (ADSR) to Maintain Video Quality in Important Areas
  • While Reducing Bandwidth Usage
  • Scheduled Custom Video Settings
  • On-Board Video Analytics and Versatile Functions
  • Powerful DIGIC NET II Processor allows for Simultaneous Streaming of M-JPEG and H.264 in Multiple Resolutions
  • Multiple Networking Configuration, Security and Encryption Functions
  • Audio and I/O Support
  • Built-in SD Card Slot
  • Multiple Power Options: 24 VAC, 12 VDC, PoE
  • ONVIF 2.4.2 / Profile S / Profile G Conformant
This is to make Misc appear on the page when needed.
CAMERA
IMAGE SENSOR
1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS
Approx. 1.3 million pixels
ANALOG VIDEO RESOLUTION
ANALOG VIDEO STANDARD
ANALOG S/N RATIO
SCANNING METHOD
Progressive Scan
LENS
2.4x optical zoom lens (electric drive)
FOCAL LENGTH
2.55 (W) - 6.12 mm (T)
F-NUMBER
F1.2 (W) - F1.8 (T)
DIGITAL ZOOM
4x
HORIZONTAL VIEWING ANGLE
111.5° (W) - 46.2° (T)
VERTICAL VIEWING ANGLE
60.5° (W) - 25.9° (T)
DAY/NIGHT SWITCH
Yes
I/R CUT FILTER
Automatically removable infrared-cut filter
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
0.02 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
0.001 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
FOCUS MODES
Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE
Day Mode: 0.3 m (12 in.) - infinity
Night Mode: 0.3 m (12 in.) - infinity
SHUTTER SPEED
1 - 1/16000 sec.
EXPOSURE MODES
Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE
Auto/Light Source/Manual
Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp
Manual: One-shot WB/R Gain/B Gain
METERING MODES
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
HAZE COMPENSATION
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT
6 levels
IMAGE STABILIZER
Digital (2 Levels)
PAN ANGLE RANGE
350° (±175°)
TILT ANGLE RANGE
150° (±75°)
ROTATION ANGLE RANGE
350° (±175°)
IR ILLUMINATION RANGE
MOVING SPEED
Pan: 20.1°/sec.
Tilt: 20.7°/sec.
Rotation: 40.0°/sec.
- Camera Angle Setting Tool Required
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
BIT RATE CONTROL
Target Bit Rate: 64-16384 kbps
VIDEO SIZE
JPEG, H.264: 1280 x 720, 640 x 360, 320 x 180 1280 x 960, 640 x 480, 320 x 240
SIMULTANIOUS VIDEO STREAMS
VIDEO QUALITY
JPEG, H.264: 10 levels
FRAME RATE
JPEG: 0.1 - 30 fps H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
1280 x 960 : 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION
Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user (level of control varies depending on user)
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec
IEEE 802.1X
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version
Ver. 2.4.2, Profile G, Profile S
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (Client), DHCP (Client), DNS (Client), mDNS,ARP, ICMP, POP3 (Client), NTP (Client), SMTP authentication (POP before SMTP, SMTP-AUTH), AutoIP, RTP/RTCP, RTSP, SSL/TLS, IPsec, WV-HTTP (Canon proprietary), ONVIF (Profile S, Profile G)
IPv6 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SMTP (Client), DHCPv6 (Client), DNS (Client), mDNS, ICMPv6, POP3 (Client), NTP (Client), SMTP authentication (POP before SMTP, SMTP-AUTH), RTP/RTCP, RTSP,SSL/TLS, IPsec, WV-HTTP (Canon proprietary), ONVIF (Profile S, Profile G)
AUTO IP(LINK-LOCAL)
Yes
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Full-duplex (two-way) - Echo cancellation function compliant RTP, Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK
Available (audio files can be played back when an event is triggered by the intelligent function or external device input.)
PRIVACY MASK
Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
N/A
PRESETS
Number of registers: Max. 20 positions (+Home Position)
Items to Reg.: Digital Pan/Digital Tilt/Digital Zoom, Exposure, Smart Shade Control, Focus, White Balance, Video Quality Adjustment, Day/Night, Haze Compensation
Number of Preset Tour Route: Max. 1
INTELLIGENT FUNCTION - VIDEO
Detection Types: Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection
INTELLIGENT FUNCTION - AUDIO
Volume Detection, Scream Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
EVENT TRIGGER TYPE
External Device Input, Intelligent Function (Video), Intelligent Function (Audio), Timer, Day/Night Switch Number of Linked Events: 2 Linked Event Conditions: AND, OR (whether or not there is a sequence to events)
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72 640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural) Switch LINE IN/MIC IN in the setting page. Use the included interface cable
AUDIO OUTPUT TERMINAL
Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural) LINE OUT (connect to an amplifier speaker) Use the included interface cable
EXTERNAL DEVICE I/O TERMINAL
Input x 2, Output x 2
ANALOG VIDEO OUT
N/A
MEMORY CARD TYPE
microSD Memory Card, microSDHC Memory Card, microSDXC Memory Card Compatible.
MEMORY CARD RECORDED CONTENT
Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE
Frame Rate: Max. 1 fps (JPEG) Max. 30 fps (H.264)
OPERATING ENVIRONMENT
TEMPERATURE
Temperature: AC, DC, PoE: -10°C - +50°C (+14°F - +122°F)
HUMIDITY
Humidity: 5% - 85% RH (without condensation)
STORAGE ENVIRONMENT
TEMPERATURE
-30°C - +60°C (-22°F - +140°F)
HUMIDITY
5% - 90% RH (without condensation)
POWER SUPPLY
PoE
PoE power supply via LAN connector (IEEE802.3at Type1 PoE compliant)
AC ADAPTER
PA-V18 (100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE
24 V AC/12 V DC
POWER CONSUMPTION
WITH PoE
Max. approx. 8.4 W
WITH AC ADAPTER
PA-V18: Max. approx. 9.8 W (100 V AC)
Max. approx. 9.8 W (240 V AC)
WITH 12VDC
Max. approx. 8.7 W
WITH PoE +
WITH 24VAC
Max. approx. 8.1 W
OTHER
DIMENSIONS
(Φ x H) Φ150 x 129 mm (Φ5.91 x 5.08 in.)
MOUNTING POSITION
Ceiling mount/Surface mount
HEATER
N/A
WEIGHT
Approx. 890 g (1.97 lb.)
OUTDOOR READY
No
IP RATING
N/A
VANDAL RESISTANT
Yes
IMPACT RESISTANCE
IK10 (20J)
Brochures
Loading...
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-M641V that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
A&E System Design Tools
A&E Specifications
Date
10/10/15
Size
509 KB
Drawings / 3D CAD
Date
10/13/15
Size
1.43 MB
Date
10/13/15
Size
138 KB
Date
10/13/15
Size
199 MB
Date
10/13/15
Size
194 KB
Date
10/13/15
Size
1.47 MB
Date
10/13/15
Size
142 KB
Date
10/13/15
Size
696 KB
Date
10/13/15
Size
77 KB
Date
10/13/15
Size
110 KB
Date
10/13/15
Size
11.0 KB
Angle of View Calculator
Choose the camera with the required distances, scene sizes and focal lengths.
Note: For best results, please view the Calculator on either a desktop or laptop screen.
Angle of View Calculator >
Required Disk Space Calculator
Determine your surveillance system's hard drive storage space needs.
Required Disk Space Calculator >
Camera Layout Simulator
Place your cameras into a simulated environment to determine video coverage area.
Camera Layout Simulator >
DISCLAIMERS
©2016 Canon U.S.A., Inc. All rights reserved. Canon and DIGIC are registered trademarks of Canon Inc. in the United States and may also be trademarks or registered trademarks in other countries. “ONVIF” and ONVIF logo are trademarks of ONVIF Inc.. Some of the images and effects are simulated. Not responsible for typographical errors.
 Return to Top
