Web Content Viewer
Actions
VB-R13
All Network Cameras
Item Code: 1383C001AA
NETWORK VIDEO PRODUCTS NOW SOLD BY AXIS COMMUNICATIONS (A CANON GROUP COMPANY). Learn more on the Axis Communications website.
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
The network camera offers seamless pan/tilt/zoom (PTZ) control provided by its 360° endless panning and 180° tilting capability. Full coverage with no blind spots is made possible by the ability to continuously pan in either direction without stopping combined with the flexible movement of 180° tilting and auto flipping. Continuous tracking provides broad surveillance and eliminates concern that a subject may move outside of the viewing range of the camera. The camera's video display and coordinate information can be rotated 180° to swiftly change from forward views to rear views with virtually no camera misalignment. The preset function allows for patrol route setup that greatly reduces the work involved in control operations and adjustments. Moreover, security personnel are able to respond to situations more quickly due to Canon's highly accurate and sensitive 450°/second pan/tilt mechanism that allows fast movement between positions.
Fast and Precise Pan / Tilt Mechanism allows for 450°/second panning and tilting speeds when moving between presets. This enables video of the desired areas to be taken with as little delay as possible which can allow security personnel to more rapidly respond to situations.
This camera is equipped with a motorized pan/tilt function and a 30x Optical Zoom Lens for accurate subject tracking and zooming in on a subject while retaining high image quality. The capability to save up to 256 preset pan/tilt/zoom positions, which can then be later recalled, helps eliminate the time required to move between positions.
The power of Canon's 30x optical zoom lens provides a high level of magnification and clear, sharp video for easier identification of subjects of interest even from long distances. It can be combined with an additional 20x digital zoom, which uses additional image processing to make the subject appear closer by enlarging pixel sizes.
The 1/3" high-sensitivity CMOS sensor processes and transmits 1920 x 1080 (Full HD) video helping to capture finer details, even in challenging low-light conditions, which is critical for subject identification and other important security matters.
256 Preset Positions with 5 Preset Tour Routes allow users to automate camera movement to different areas of interest at different times of the day in order to cover more area with a single camera. This model will support creation of up to 256 preset camera positions and scheduling of up to 5 preset tour routes*.
The camera will internally save the desired pan/tilt/zoom (PTZ) position of the camera so that the user can choose to easily return to that position at a later occasion without having to manually adjust the PTZ positions of the camera each time.
Also included in the presets are Focus Mode, Exposure, Slow Shutter, White Balance, Day/Night, and other settings in order to save the user from having to make frequent manual adjustments to these camera controls.
Preset tour routes program the camera to constantly move between different presets in sequence. The speed of movement between each preset can also be precisely configured to ensure proper monitoring of an entire area.
*If the durability limit for the pan/tilt operations is exceeded, the motors may need to be replaced
For maximized image quality, Canon has incorporated the same DIGIC DV III Image Processor used in many of its high-end DSLR cameras in order to reproduce video with life-like colors, tonal accuracy, smooth gradation and reduced noise. Unlike other cameras that rely on a shared processor for image quality and compression, Canon network cameras are engineered with a DIGIC DV III Image Processor solely dedicated to maximizing image quality.
Canon's DIGIC DV III Image Processor is a high-speed engine with maximum processing power which helps to optimize overall video quality with:
  • Vivid, life-like color reproduction and image clarity
  • Rich, smooth gradations
  • Drastically reduced image noise
DIGIC NET II Processor is a powerful and efficient compression, encryption, and transmission processor that gives Canon Network Cameras the ability to simultaneously deliver full HD (1920 x 1080) video at 30 frames per second in both M-JPEG and H.264 codecs. Users have the flexibility of streaming multiple resolutions of M-JPEG and H.264, all while minimizing power consumption. In situations where remote cameras are using cellular data, users can potentially realize substantial savings in data charges.
In the event of an intruder or irregular occurrence within the field of view, this speed dome network camera has the ability to automatically trigger for recording, follow the subject, and/or alert authorities. Once the Auto Zoom function of the Auto Tracking feature is enabled, the camera automatically zooms into the subject being tracked and can self-regulate the panning and tilting in order to keep the subject centered on the display screen as that subject moves*. This function is ideal for automated, unmanned monitoring of large areas that normally do not see movement, or during off hours in areas where movement is not expected but must be monitored for suspicious activity and intruders.
* Accuracy of tracking is not guaranteed as there are situations that may affect reliability such as objects moving in opposite directions, poor lighting conditions, etc.
The Enhanced Digital Zoom function can be used to further zoom-in on the subject(s) without loss of video quality when optical zoom is not enough. With this feature, the camera streams a lower resolution digital crop of the original video, as opposed to digital zoom which manipulates the image to make the subject appear larger by increasing pixel sizes and reducing image quality. Enhanced Digital Zoom typically produces a higher-quality image than digital zoom while significantly lowering the amount of bandwidth and storage space needed to transmit and retain the video.
Image Stabilization is an optional feature that can be used to help reduce motion blur caused by wind or mechanical vibration. The camera calculates the amount of vibration being experienced both horizontally and vertically and stabilizes the image by digitally removing pixels, which results in capturing video with minimized motion blurring.
Area-Specific Data Size Reduction (ADSR) is an optional function that allows users to reduce bandwidth consumption and video storage space requirements, thus lessening the need for expensive networking and storage equipment. The reduction in bandwidth and storage is achieved by defining up to eight specific areas in the camera's field of view which are most critical and where high video quality must be maintained, while video quality in the rest of the camera's field of view is lowered.
Motion Adaptive Noise Reduction helps reduce overall bandwidth consumption and lower the costs associated with transmitting data, while providing clean images in low light areas where motion is detected. Areas without motion receive added noise reduction thus minimizing bandwidth consumption, while areas with motion receive a smaller amount of noise reduction resulting in greater visual clarity for optimized monitoring and surveillance.
This network camera is equipped with an impressive selection of video capture settings that can be tailored to better accommodate environmental lighting changes, such as shifts in sunlight direction and during the transitions between day and night. Users are able to define presets that include settings such as shutter speed, gain, aperture, white balance, day/night mode and more in addition to the camera's pan/tilt/zoom position. These presets can be recalled on a schedule or can tie-in with the camera's automatic day/night switch options to help ensure high-quality video even in situations with varying ambient light conditions.
A host of optional on-board image optimization features were designed to maximize video image quality.
Haze Compensation automatically heightens contrast to display a clear image despite the presence of haze, fog or smog.
Smart Shade Control analyzes and selectively adjusts the exposure in overexposed and darkened areas.
Auto Gain Control Limit gives the user full control over the amount of digital gain applied when using auto exposure in low-light scenarios.
White Balance settings can be adjusted in order to compensate for different types of lighting to ensure color-accurate images.
A host of intelligent On-board Video Analytics have been built into the camera to aid in analyzing video content for the purposes of identifying and alerting potentially critical situations. For maximum flexibility, detection characteristics (sensitivity, area and duration) can be finely tuned by users to allow for precise event detection by the camera, while notification tools can alert the correct parties to help expedite response time. In addition, costly storage space can be saved by using these On-board Video Analytics as triggers to start recording so that the camera does not have to continuously record during all hours of the day.
Moving Object Detection - used to detect moving objects, such as persons or vehicles, in predefined areas such as hallways and parking lots.
Abandoned Object Detection - used to identify motionless objects that have been left behind by a moving object such as a suspicious package placed on a city street.
Removed Object Detection - used to identify the removal of a static object from a designated area, such as a priceless painting in a museum/gallery.
Camera Tampering Detection - used to detect the tampering of a camera such as redirection, blocking, defocusing, or even spray paint.
Passing Detection - used to detect when a moving object passes through the camera's field of view in a specified direction, such as an individual entering into a restricted area from the exit doorway.
Intrusion Detection - used to identify when a moving object enters and remains in a specified area for a period of time deemed unacceptable, such as an individual stepping over a partition in a museum.
The Open Network Video Interface Forum (ONVIF) is a growing industry standard that promotes interoperability of security devices and eliminates the need for custom drivers. This network camera supports ONVIF Profile S which helps ensure that basic features such as video streaming, pan / tilt / zoom control, audio streaming and more, will work properly with a wide array of VMS systems. This camera also supports ONVIF Profile G which specifies SD card recording, searching and streaming compatibility.
Camera Viewer with Mobile Device Support allows user to access the camera's functionality from any location via the web browser on their PC or mobile device. The "Mobile Viewer" interface is designed to provide easy control of the essential functions necessary to operate the camera (video stream, pan/tilt/zoom control, presets, exposure settings, etc.) via the touch screens of mobile iOS or Android devices. Installers can also quickly configure their camera at the installation site and remotely control it.
The Built-in SD Card Slot, which supports SD, SDHC and SDXC memory cards, provides temporary secondary storage for video data and camera logs. In addition, the memory card recording can be used in remote deployments to reduce the amount of additional hardware needed to store video.
Live images and H.264 video can be saved to the memory card during network outages, event triggers, at scheduled times and manually via the Camera Viewer. When issues occur, system logs can also be created on the memory card for future troubleshooting.
The Recorded Video Utility allows for searching, downloading and viewing the recorded video and the Canon Camera Management Tool allows for backing up and restoring camera settings to/from the memory card.
An optional "Auto Video Delete" feature allows the user to define a retention period for recorded videos (up to 90 days).
The Low Power Consumption offered by this camera helps reduce the potential occurrence of overheating and failure. In addition, overall system power requirements are lessened, potentially giving the user the ability to save on energy, back-end equipment and hardware costs while lowering environmental impact.
This network camera accepts 24 V AC, 12 V DC and Power over Ethernet (PoE) offering flexibility when it comes to utilizing power sources available at the installation location.
This network camera can be installed in environments where a high level of network security is of extreme importance. It supports IEEE802.1X authentication, which provides additional network security with port-based access control that helps ensure only authorized client devices are connected to the network. In addition, IPSec is used to encrypt all packets of IP data sent over the network and SSL/TLS is used to safeguard data by encrypting sensitive information transmitted between a client and an application.
I/O support can be used to move the camera to a particular position or trigger an alarm when a door is opened or closed. An external microphone and speakers can be attached to this network camera so that the operator can hear what is going on at the camera location as well as playback audio files to people at that site.
CCMT provides a powerful, single unified method of configuring and managing all Canon network cameras on the local network. CCMT not only saves valuable time by streamlining the initial camera configuration, but greatly simplifies the management of an entire Canon network camera deployment. This tool supports network settings configuration, batch firmware upgrades, settings backup/restore, modifying video stream settings, and more.
CAMERA
IMAGE SENSOR 1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS Approx. 2.1 million pixels
ANALOG VIDEO RESOLUTION
ANALOG VIDEO STANDARD
ANALOG S/N RATIO
SCANNING METHOD Progressive Scan
LENS 30x optical zoom lens with auto focus
FOCAL LENGTH 4.4 (W) - 132mm (T)
F-NUMBER F1.4 (W) - F4.6 (T)
DIGITAL ZOOM 20x
HORIZONTAL VIEWING ANGLE (16:9) 62.6° (W) - 2.2° (T)
VERTICAL VIEWING ANGLE (16:9) 36.9° (W) - 1.3° (T)
DAY / NIGHT MODE Yes
I/R CUT FILTER Automatically removable infrared-cut filter
MIN. SUBJECT ILLUMINATION - DAY (COLOR) 0.05 lux (F1.4, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) 0.002 lux (F1.4, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
FOCUS MODES Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE Day Mode: 0.3 m (12 in.) - infinity (W), 2.0 m (6.6 ft.) - infinity (T)
Night Mode: 1.0 m (3.3 ft.) - infinity (W), 2.0 m (6.6 ft.) - infinity (T)
SHUTTER SPEED 1 - 1/16000 sec.
EXPOSURE MODES Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Auto (Aperture-priority AE)/Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE Auto/Light Source/Manual
Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp
Manual: One-shot WB/R Gain/B Gain
METERING MODES Center-Weighted/Average/Spot
EXPOSURE COMPENSATION 9 levels
SMART SHADE CONTROL Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
HAZE COMPENSATION Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT 6 levels
IMAGE STABILIZER Digital (2 levels)
PAN ANGLE RANGE 360°continuous panning
TILT ANGLE RANGE 180° (ceiling-mounted position: 0° - 180°)
ROTATION ANGLE RANGE
IR ILLUMINATION RANGE
MOVING SPEED Pan: Max. 450°/sec.
Tilt: Max. 450°/sec.
SERVER
VIDEO COMPRESSION METHOD JPEG, H.264
BIT RATE CONTROL Target Bit Rate: 64-16384 kbps
VIDEO SIZE JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270
1280 x 720, 640 x 360, 320 x 180
1280 x 960, 640 x 480, 320 x 240
SIMULTANIOUS VIDEO STREAMS
PLACE HOLDER
VIDEO QUALITY JPEG, H.264: 10 levels
FRAME RATE JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE 1920 x 1080 : 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL 0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS Max. 30 Clients + 1 Admin Client
- H.264: Max. 10 Clients
CAMERA CONTROL Administrator, Authorized user, Guest user (level of control varies depending on user)
ACCESS CONTROL User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS SSL/TLS, IPsec
IEEE 802.1X EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF VERSION Profile S, Profile G
IPv4 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
AUTO IP (LINK-LOCAL) Yes
AUDIO COMPRESSION METHOD G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD Full-duplex (two-way) - Echo cancellation function compliant
RTP, Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK Available (audio files can be played back when an event is triggered by the intelligent function or external device input)
PRIVACY MASK Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION Available
PRESETS Number of registers: Max. 256 positions (+Home Position)
Number of Preset Tour Route: Max. 5
INTELLIGENT FUNCTION - VIDEO Detection Types: Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, Intrusion Detection, and Auto Tracking
INTELLIGENT FUNCTION - AUDIO Volume Detection, Scream Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS Max. 15
EVENT TRIGGER TYPE External Device Input, Intelligent Function (Video), Intelligent Function (Audio), Timer, Day/Night Switch
IMAGE UPLOAD FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY Available
IMAGE CROPPING FUNCTION N/A
DAYLIGHT SAVING TIME Available
CUSTOM SETTINGS Available
INTERFACE
NETWORK TERMINAL LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural)
LINE IN (connect to an amplifier microphone) or MIC IN (connect to a microphone w/o amplifier)
AUDIO OUTPUT TERMINAL Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural)
LINE OUT (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL Input x 2, Output x 2
ANALOG VIDEO OUT N/A
MEMORY CARD TYPE SD Memory Card, SDHC Memory Card, SDXC Memory Card Compatible.
MEMORY CARD RECORDED CONTENT Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE Max. 1 fps (JPEG)
Max. 30 fps (H.264)
OPERATING ENVIRONMENT
TEMPERATURE AC, DC, PoE: -10°C - +50°C (+14°F - +122°F)
HUMIDITY 5% - 85% (without condensation)
STORAGE ENVIRONMENT
TEMPERATURE -30°C - +60°C (-22°F - +140°F)
HUMIDITY 5% - 90% (without condensation)
POWER SUPPLY
PoE PoE power supply via LAN connector (IEEE802.3at Type1 compliant)
AC ADAPTER AC Adapter: PA-V18 (100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE 24VAC / 12VDC
POWER CONSUMPTION
WITH PoE 10.7W
WITH AC ADAPTER AC Adapter PA-V18: Max. approx. 11.3 W (100 V AC)
Max. approx. 11.1 W (240 V AC)
WITH 12VDC 9.7W
WITH PoE + N/A
WITH 24VAC 10.2W
OTHER
DIMENSIONS (Φ x H) Φ199 x 199 mm (Φ7.83 x 7.83 in.)
MOUNTING POSITION
HEATER N/A
WEIGHT Approx. 1990 g (4.39 lb.)
OUTDOOR READY No
IP RATING N/A
VANDAL RESISTANT N/A
IMPACT RESISTANCE N/A
This is to make Misc appear on the page when needed.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-R13 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
A&E System Design Tools
Angle of View Calculator
Choose the camera with the required distances, scene sizes and focal lengths.
Note: For best results, please view the Calculator on either a desktop or laptop screen.
Angle of View Calculator >
Required Disk Space Calculator
Determine your surveillance system's hard drive storage space needs.
Required Disk Space Calculator >
Camera Layout Simulator
Place your cameras into a simulated environment to determine video coverage area.
Camera Layout Simulator >
DISCLAIMERS
©2016 Canon U.S.A., Inc. All rights reserved. Canon and DIGIC are registered trademarks of Canon Inc. in the United States and may also be trademarks or registered trademarks in other countries. “ONVIF” and ONVIF logo are trademarks of ONVIF Inc.. Some of the images and effects are simulated. Not responsible for typographical errors.
 Return to Top
