Web Content Viewer
Actions
VB-S800D Mark II
All Network Cameras
NETWORK VIDEO PRODUCTS NOW SOLD BY AXIS COMMUNICATIONS (A CANON GROUP COMPANY). Learn more on the Axis Communications website.
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
  • Compact Micro Dome Camera with High Quality Full HD Video
  • Genuine Canon 95° Angle of View Lens
  • 2.1 Megapixel (Native 1920 x 1080 Full HD Resolution)
  • Enhanced Digital Presets That Include Positioning and Video Settings
  • Advanced DIGIC DV III Image Processor Helps Maximize Image Quality and Minimize Power Consumption
  • Area Specific Data Size Reduction and Motion Adaptive Noise Reduction
  • Smart Shade Control and Auto Gain Control Limit
  • Powerful DIGIC NET II Processor Allows Simultaneous Streaming of M-JPEG and H.264 Codecs in Multiple Resolutions
  • On-Board Video Analytics and Versatile Functions
  • Multiple Networking Functions
  • ONVIF Profile S and G Conformant
  • Built-in microSD Card Slot with Enhanced SD Card Functionality
  • Free RM-Lite Network Video Monitoring & Recording Software
  • PoE IEEE 802.3af Compliant
This is to make Misc appear on the page when needed.
CAMERA
IMAGE SENSOR
1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS
Approx. 2.1 million pixels
SCANNING METHOD
Progressive Scan
LENS
Fixed focal length lens
FOCAL LENGTH
2.7mm
F-NUMBER
F1.6
DIGITAL ZOOM
4x
HORIZONTAL VIEWING ANGLE (16:9)
95°
VERTICAL VIEWING ANGLE (16:9)
60°
DAY/NIGHT MODE
Yes
I/R CUT FILTER
Digital Night Mode
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
0.45 lux (F1.6, shutter speed 1/30 sec)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
0.25 lux (F1.6, shutter speed 1/30 sec)
FOCUS MODES
SHOOTING DISTANCE
0.5m (1.6 ft.) - infinity (W)
SHUTTER SPEED
1 - 1/16000 sec.
EXPOSURE MODES
Auto/ Auto (Flickerless)/Auto (Flickerless2)/Auto (shutter-priority AE)/ Manual (Shutter Speed, Gain)
WHITE BALANCE
Auto/Light Source (Daylight Fluorescent/White Fluorescent/WarmFluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/Manual(One-shot WB/R Gain/B Gain)
METERING MODES
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
Auto / Manual / Disable
Auto: 3 Levels
Manual: 7 Levels
HAZE COMPENSATION
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT
6 levels
IMAGE STABILIZER
Digital (2 Levels)
MOTION ADAPTIVE NOISE REDUCTION
Available
CLEAR IR
N/A
PAN ANGLE RANGE
3350° (±175°)
TILT ANGLE RANGE
90° (ceiling-mounted position: -90° - 0°)
ROTATION ANGLE RANGE
180° (±90°)
IR ILLUMINATION RANGE
N/A
MOVING SPEED
N/A
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
BIT RATE CONTROL
VIDEO SIZE
JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270
1280 x 720, 640 x 360, 320 x 180
1280 x 960, 640 x 480, 320 x 240
VIDEO QUALITY
JPEG, H.264: 10 levels
FRAME RATE
JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
JPEG, H.264 (1920 x 1080): 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client
- H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec (Auto Key Exchange/Manual)
IEEE 802.1X
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version
ONVIF Profile S
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL
AUTO IP (LINK-LOCAL)
Yes
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Audio Reception Only
AUDIO FILE PLAYBACK
Available
PRIVACY MASK
Number of registration: Max. 8 places,
Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
Available
PRESETS
Number of registers: Max. 20 positions (+Home Position)
Number of Preset Tour Route: Max. 1
INTELLIGENT FUNCTION - VIDEO
Moving object detection, abandoned object detection, removed object
detection, camera tampering detection, passing detection and intrusion detection
INTELLIGENT FUNCTION - AUDIO
Volume Detection & Scream Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
EVENT TRIGGER TYPE
External Device Input, Timer, Intelligent Function (Video),
Intelligent Function (Volume)
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72
640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
ENHANCED DIGITAL ZOOM
Available
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
Available
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
Φ3.5mm (Φ0.14 in.) mini-jack connector (monaural)
Switch LINE IN/MIC IN in the setting page.
AUDIO OUTPUT TERMINAL
LINE OUT x 1 (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL
Input x 1, Output x 1
ANALOG VIDEO OUT
N/A
MEMORY CARD TYPE
MicroSD Memory Card, MicroSDHC Memory Card, MicroSDXC Memory Card Compatible.
MEMORY CARD RECORDED CONTENT
Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE
Frame Rate: Max. 1 fps (JPEG)
Max. 30 fps (H.264)
OPERATING ENVIRONMENT
TEMPERATURE
Temperature: -10°C - +50°C (+14°F - +122°F)
HUMIDITY
Humidity: 5% - 85% RH (without condensation)
STORAGE ENVIRONMENT
TEMPERATURE
-30°C - +60°C (-22°F - +140°F)
HUMIDITY
5% - 90% RH (without condensation)
POWER SUPPLY
PoE
PoE: PoE power supply via LAN connector (IEEE802.3af compliant)
AC ADAPTER
PA-V18(100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE
24 V AC/12 V DC
MAXIMUM POWER CONSUMPTION
WITH PoE
Max. approx. 4.1 W
WITH AC ADAPTER
PA-V18 Max. approx. 9.9W (100 VAC)
PA-V18: Max. approx. 9.4W (240 VAC)
WITH 12VDC
Max. approx. 8.6 W
WITH PoE +
WITH 24VAC
Max. approx. 8.8 W
OTHER
DIMENSIONS
(Φ x H) Φ120 x 54mm (Φ4.72 x 2.13 in.)
MOUNTING POSITION
Ceiling mount / Surface Mount
HEATER
N/A
WEIGHT
Approx. 240 g (.53 lb.)
OUTDOOR READY
No
IP RATING
N/A
VANDAL RESISTANT
No
IMPACT RESISTANCE
N/A
VB-S800D Mark II Network Camera
VB-S800D Mark II Network Camera VB-S800D Mark II Main Body Installation Guide Warranty Card Template Safety Wire 1x M4 Screw for Wire
Brochures
Loading...
 Return to Top
