Web Content Viewer
Actions
VB-S800VE
All Network Cameras
Item Code: 1388C001AA
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
The 1/3" high-sensitivity CMOS sensor processes and transmits 1920 x 1080 (Full HD) video helping to capture finer details, even in challenging low-light conditions, which is critical for subject identification and other important security matters.
The lightweight and compact form factor of this camera facilitate ease of installation as well as an unobtrusive appearance, making it ideal for applications that require a clean refined environment.
The lightweight VB-S800VE is just 600 g (21.2 oz)
An IP66 Rating means that the unit is both water resistant to powerful streams of water and dust tight, thus allowing this camera to be installed outdoors without the need for any additional protective equipment. (Not appropriate for underwater submersion).
This camera was built with two vandal resistant elements to help ensure safety from impact and tampering. The enclosure has an IK10 rating, which specifies withstanding up to 20 joules of impact resistance, roughly the equivalent of a 10 pound bowling ball being dropped on it from a distance of 15 inches. In addition, the enclosure is equipped with tamper-resistant screws to help prevent entry into and removal of the unit.
For maximized image quality, Canon has incorporated the same DIGIC DV III Image Processor used in many of its high-end DSLR cameras in order to reproduce video with life-like colors, tonal accuracy, smooth gradation and reduced noise. Unlike other cameras that rely on a shared processor for image quality and compression, Canon network cameras are engineered with a DIGIC DV III Image Processor solely dedicated to maximizing image quality.
Canon's DIGIC DV III Image Processor is a high-speed engine with maximum processing power which helps to optimize overall video quality with:
  • Vivid, life-like color reproduction and image clarity
  • Rich, smooth gradations
  • Drastically reduced image noise
A host of optional on-board image optimization features were designed to maximize video image quality.
Haze Compensation automatically heightens contrast to display a clear image despite the presence of haze, fog or smog.
Smart Shade Control analyzes and selectively adjusts the exposure in overexposed and darkened areas.
Auto Gain Control Limit gives the user full control over the amount of digital gain applied when using auto exposure in low-light scenarios.
White Balance settings can be adjusted in order to compensate for different types of lighting to ensure color-accurate images.
This camera has a one-way moisture release vent that allows for efficient disposal of any excess moisture that builds up in the enclosure. A blower will circulate air throughout the inside of the enclosure, simultaneously removing excess moisture. This feature helps ensure that the viewing surface of the enclosure will not fog up and contributes to the long life-span of this unit.
A built-in-microphone provides dynamic audio support, allowing for audio recording and streaming at the camera's installation site. This microphone is sensitive enough to pick up sounds from several yards away so the user can not only see, but also hear what is going on at the camera location.
Motion Adaptive Noise Reduction helps reduce overall bandwidth consumption and lower the costs associated with transmitting data, while providing clean images in low light areas where motion is detected. Areas without motion receive added noise reduction thus minimizing bandwidth consumption, while areas with motion receive a smaller amount of noise reduction resulting in greater visual clarity for optimized monitoring and surveillance.
Area-Specific Data Size Reduction (ADSR) is an optional function that allows users to reduce bandwidth consumption and video storage space requirements, thus lessening the need for expensive networking and storage equipment. The reduction in bandwidth and storage is achieved by defining up to eight specific areas in the camera's field of view which are most critical and where high video quality must be maintained, while video quality in the rest of the camera's field of view is lowered.
This optional feature allows cameras to be installed in areas even if there are restrictions on what can be recorded, as a digital mask can be applied to up to 8 sections within the camera's field of view. This prevents the user from seeing any sensitive material that may be behind the masked area, such as an ATM machine displaying banking information.
A host of intelligent On-board Video Analytics have been built into the camera to aid in analyzing video content for the purposes of identifying and alerting potentially critical situations. For maximum flexibility, detection characteristics (sensitivity, area and duration) can be finely tuned by users to allow for precise event detection by the camera, while notification tools can alert the correct parties to help expedite response time. In addition, costly storage space can be saved by using these On-board Video Analytics as triggers to start recording so that the camera does not have to continuously record during all hours of the day.
Moving Object Detection - used to detect moving objects, such as persons or vehicles, in predefined areas such as hallways and parking lots.
Abandoned Object Detection - used to identify motionless objects that have been left behind by a moving object such as a suspicious package placed on a city street.
Removed Object Detection - used to identify the removal of a static object from a designated area, such as a priceless painting in a museum/gallery.
Camera Tampering Detection - used to detect the tampering of a camera such as redirection, blocking, defocusing, or even spray paint.
Passing Detection - used to detect when a moving object passes through the camera's field of view in a specified direction, such as an individual entering into a restricted area from the exit doorway.
Intrusion Detection - used to identify when a moving object enters and remains in a specified area for a period of time deemed unacceptable, such as an individual stepping over a partition in a museum.
The Open Network Video Interface Forum (ONVIF) is a growing industry standard that promotes interoperability of security devices and eliminates the need for custom drivers. This network camera supports ONVIF Profile S which helps ensure that basic features such as video streaming, pan / tilt / zoom control, audio streaming and more, will work properly with a wide array of VMS systems.
Camera Viewer with Mobile Device Support allows user to access the camera's functionality from any location via the web browser on their PC or mobile device. The "Mobile Viewer" interface is designed to provide easy control of the essential functions necessary to operate the camera (video stream, pan/tilt/zoom control, presets, exposure settings, etc.) via the touch screens of mobile iOS or Android devices. Installers can also quickly configure their camera at the installation site and remotely control it.
Power over Ethernet (PoE) is a single cable solution which allows more flexibility in choosing installation locations by eliminating the constraint of requiring AC power outlets nearby. Additionally, the cost of cable installation is reduced because a dedicated power cable is no longer necessary to operate the camera.
The Low Power Consumption offered by this camera helps reduce the occurrence of overheating and failure. In addition, overall system power requirements are lessened, potentially giving the user the ability to save on energy, back-end equipment and hardware costs while lowering environmental impact.
CAMERA
IMAGE SENSOR
1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS
Approx. 2.1 million pixels
SCANNING METHOD
Progressive Scan
LENS
Fixed focal length lens
FOCAL LENGTH
2.7 mm
F-NUMBER
F1.6
DIGITAL ZOOM
4x
HORIZONTAL VIEWING ANGLE
93.8°
VERTICAL VIEWING ANGLE
58.7°
DAY / NIGHT MODE
Yes
I/R CUT FILTER
Digital Night Mode
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
0.5 lux (F1.6, shutter speed 1/30 sec.)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
0.3 lux (F1.6, shutter speed 1/30 sec.)
FOCUS MODES
N/A
SHOOTING DISTANCE
0.5m (1.6 ft.) - infinity
SHUTTER SPEED
1 - 1/16000 sec.
EXPOSURE MODES
Auto/ Auto (Flickerless)/ Auto (Flickerless2) Auto (shutter-priority AE)/ Manual (Shutter Speed, Gain)
WHITE BALANCE
Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm
Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/ Manual
(One-shot WB / R Gain/ B Gain)
METERING MODES
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
Auto / Manual / Disable
Auto: 3 Levels
Manual: 7 Levels
HAZE COMPENSATION
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT
6 levels
IMAGE STABILIZER
N/A
MOTION ADAPTIVE NOISE REDUCTION
Available
CLEAR IR
N/A
PAN ANGLE RANGE
350° (±175°)
TILT ANGLE RANGE
90° (ceiling-mounted position: -90° - 0°)
ROTATION ANGLE RANGE
180° (±90°)
IR ILLUMINATION RANGE
N/A
MOVING SPEED
N/A
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
BIT RATE CONTROL
Target Bit Rate: 64-16384 kbps
VIDEO SIZE
JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270
1280 x 720, 640 x 360, 320 x 180
1280 x 960, 640 x 480, 320 x 240
SIMULTANIOUS VIDEO STREAMS
2x H.264, 2x MJPEG, 1x H.264 1x MJPEG
VIDEO QUALITY
JPEG, H.264: 10 levels
FRAME RATE
JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
JPEG, H.264 (1920 x 1080): 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION
Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client
- H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec (Auto Key Exchange/Manual)
IEEE 802.1X
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version
ONVIF Profile S
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL
AUTO IP(LINK-LOCAL)
Yes
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Full-duplex (two-way)/half-duplex (One-way communication)
RTP, Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK
Available
PRIVACY MASK
Number of registration: Max. 8 places,
Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
N/A
PRESETS
Max. 20 positions (Digital)
INTELLIGENT FUNCTION - VIDEO
Moving object detection, abandoned object detection, removed object
detection, camera tampering detection, passing detection and intrusion detection
INTELLIGENT FUNCTION - AUDIO
Volume Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
EVENT TRIGGER TYPE
External Device Input, Timer, Intelligent Function (Video),
Intelligent Function (Audio), Day/Night Switch
IMAGE UPLOAD
FTP/HTTP
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72
640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
ENHANCED DIGITAL ZOOM
N/A
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
Available
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
Built-in Microphone
Sensitivity: -40 dB (0 dB=1 V/Pa)
S/N Ratio: 62 dB or greater
Frequency Response: 50 Hz - 16 kHz
AUDIO OUTPUT TERMINAL
Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural)
LINE OUT (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL
Input x 1, Output x 1
ANALOG VIDEO OUT
N/A
MEMORY CARD TYPE
MicroSD Memory Card, MicroSDHC Memory Card, MicroSDXC Memory Card Compatible.
MEMORY CARD RECORDED CONTENT
Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE
Frame Rate: Max. 1 fps (JPEG)
Max. 30 fps (H.264)
OPERATING ENVIRONMENT
TEMPERATURE
Operating Temperature Range
-25°C - +50°C (-13°F - +122°F)
HUMIDITY
Humidity: 5% - 85% RH (without condensation)
STORAGE ENVIRONMENT
TEMPERATURE
-30°C - +60°C (-22°F - +140°F)
HUMIDITY
5% - 90% RH (without condensation)
POWER SUPPLY
PoE
PoE: PoE power supply via LAN connector (IEEE802.3af compliant)
AC ADAPTER
N/A
EXTERNAL POWER SOURCE
N/A
MAXIMUM POWER CONSUMPTION
WITH PoE
Max. 3.9 W
WITH AC ADAPTER
N/A
WITH 12VDC
N/A
WITH PoE +
N/A
WITH 24VAC
N/A
OTHER
DIMENSIONS
(Φ x H) Φ132 x 65 mm (Φ5.20 x 2.56 in.)
- Camera only
MOUNTING POSITION
Ceiling mount/Wall mount
HEATER
No
WEIGHT
Approx. 600 g (21.2 oz.) (T.B.D.)
OUTDOOR READY
Yes
* Dome may cloud when installed under direct sunlight
IP RATING
IP66
VANDAL RESISTANT
Yes
IMPACT RESISTANCE
IK10 (20J)
This is to make Misc appear on the page when needed.
VB-S800VE Network Camera
VB-S800VE Network Camera VB-S800VE Main Unit
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-S800VE that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
 Return to Top
