Web Content Viewer
Actions
VB-S805D
All Network Cameras
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
  • Compact and Low Profile Design
  • Genuine Canon 95° Wide Angle Lens with 4x Optical Zoom
  • 1.3 Megapixel (Native 1280 x 960 Resolution)
  • Advanced DIGIC DV III Image Processor Helps Maximize Image Quality and Minimize Power Consumption
  • Exceptional Low Light Performance
  • Smart Shade Control and Auto Gain Control Limit
  • Custom Video Settings
  • Powerful DIGIC NET II Processor Allows Simultaneous Streaming of M-JPEG and H.264 Codecs in Multiple Resolutions
  • On-Board Video Analytics and Versatile Functions
  • Multiple Networking Functions
  • ONVIF 2.2 / Profile S Conformant
  • Built-in SD Card Slot with Enhanced SD Card Functionality
  • Free RM-Lite Network Video Monitoring & Recording Software
  • PoE IEEE 802.3af
This is to make Misc appear on the page when needed.
CAMERA
IMAGE SENSOR
1/3 type CMOS (primary color filter)
NUMBER OF EFFECTIVE PIXELS
Approx. 1.3 million pixels
ANALOG VIDEO RESOLUTION
N/A
ANALOG VIDEO STANDARD
N/A
ANALOG S/N RATIO
N/A
SCANNING METHOD
Progressive
LENS
Fixed focal length lens (4x digital zoom)
FOCAL LENGTH
2.7 mm
F-NUMBER
F1.6
HORIZONTAL VIEWING ANGLE
95°
VERTICAL VIEWING ANGLE
60°
DAY/NIGHT SWITCH
Auto/Manual
I/R CUT FILTER
Fixed
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
0.45 lux (F1.6, shutter speed 1/30 sec., smart shade control is off , 50IRE)
0.03 lux (F1.6, shutter speed 1/2 sec., smart shade control is off , 50IRE)
0.01 lux (F1.6, shutter speed 1/2 sec., smart shade control is on, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
0.25 lux (F1.6, shutter speed 1/30 sec., smart shade control is off , 50IRE)
0.02 lux (F1.6, shutter speed 1/2 sec., smart shade control is off , 50IRE)
0.007 lux (F1.6, shutter speed 1/2 sec., smart shade control is on, 50IRE)
FOCUS
Fixed at infinity
SHOOTING DISTANCE
0.5m (1.6 ft.) - infinity
SHUTTER SPEED
1, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000, 1/4000, 1/8000, 1/10000, 1/16000 sec.
EXPOSURE
Auto / Auto (Flickerless)/Auto (Shutter-priority AE)/ Manual (Shutter Speed, Gain)
WHITE BALANCE
Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/ Manual (One-shot WB / R Gain/ B Gain)
METERING MODE
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
Auto / Manual / Disable
Auto: 3 Levels
Manual: 7 Levels
AGC LIMIT
5 levels
IMAGE STABILIZER
N/A
PAN ANGLE RANGE
350° (±175°)
TILT ANGLE RANGE
90° (ceiling-mounted position: -90° - 0°)
ROTATION ANGLE RANGE
180° (±90°)
MOVING SPEED
N/A
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
VIDEO SIZE
JPEG, H.264: 1280x720, 640x360, 320x180 1280x960, 640x480, 320x240
VIDEO QUALITY
JPEG, H.264: 5 levels
FRAME RATE
JJPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
JPEG, H.264 (1280x960): 30fps
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user Max. 50 user names and passwords registered for authorized users.
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4,IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec (Auto Key Exchange/Manual)
IEEE 802.1X
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version
ONVIF Ver. 2.4 / Profile S
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (Client), DHCP (Client), DNS (Client), ARP, ICMP, POP3, NTP, SMTP authentication, RTSP, WV-HTTP(Canon proprietary), ONVIF
IPv6 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SMTP (Client), DHCPv6 (Client), DNS (Client), ICMPv6, POP3, NTP, SMTP authentication, RTSP, WV-HTTP (Canon Proprietary), ONVIF
AUTO IP
Available
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK
N/A
PRIVACY MASK
Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
PRESETS
Max. 20 positions
INTELLIGENT FUNCTION - VIDEO
Moving object detection, abandoned object detection, removed object detection, camera tampering detection, and passing detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
INTELLIGENT FUNCTION - VOLUME
Volume Detection
EVENT TRIGGER TYPE
External Device Input, Timer, Intelligent Function (Video),
Intelligent Function (Volume)
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail)
Temporary storage memory in camera: Max.
approx. 5 MB
Frame Rate: Max. 10 fps (JPEG)
Max. 30 fps (H.264)
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
Digital PTZ
Cropping Sizes: 640x360, 512x288, 384x216, 256x144, 128x72 640x480, 512x384, 384x288, 256x192, 128x96
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
Number of Registers: 4
Items to Register: Exposure, Smart Shade Control, White Balance, Image Quality Adjustment, Day/Night
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
Φ3.5mm (Φ0.14 in.) mini-jack connector (monaural) Switch LINE IN/MIC IN in the setting page. LINE IN x 1 (connect to an amplifier microphone) or MIC IN x 1 (connect to a microphone w/o amplifier)
AUDIO OUTPUT TERMINAL
N/A
EXTERNAL DEVICE I/O TERMINAL
Input x 1, Output x 1
ANALOG VIDEO OUT
N/A
MEMORY CARD
MicroSD Memory Card, MicroSDHC Memory Card, MicroSDXC Memory
Card Compatible.
Frame Rate: Max. 1 fps (JPEG)
Max. 30 fps (H.264)
OPERATING ENVIRONMENT
TEMPERATURE
Temperature: -10°C - +50°C (+14°F - +122°F)
HUMIDITY
Humidity: 5% - 85% (without condensation)
POWER SUPPLY
PoE
PoE: PoE power supply via LAN connector (IEEE802.3af compliant)
AC ADAPTER
N/A
EXTERNAL POWER SOURCE
N/A
POWER CONSUMPTION
WITH PoE
Max. approx. 4.1 W
WITH AC ADAPTER
N/A
WITH 12VDC
N/A
WITH 24VAC
N/A
OTHER
DIMENSIONS
((Φ x H) Φ120 x 54mm (Φ4.72 x 2.13 in.)
MOUNTING POSITION
Horizontal / Vertical
HEATER
N/A
WEIGHT
Approx. 240 g (.53 lb.)
OUTDOOR READY
No
IP RATING
N/A
VANDAL RESISTANT
No
IMPACT RESISTANCE
N/A
VB-S805D Network Camera
VB-S805D Network Camera VB-S805D Main Unit Setup CD-ROM Wire unit Screw for wire Template Installation Guide Warranty Card
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-S805D that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
A&E System Design Tools
A&E Specifications
Date:
11/20/14
Size:
500 KB
Drawings / 3D CAD
Date:
07/01/15
Size:
920 KB
Date:
11/6/14
Size:
2.48 MB
Date:
11/6/14
Size:
404 KB
Angle of View Calculator
Choose the camera with the required distances, scene sizes and focal lengths.
Note: For best results, please view the Calculator on either a desktop or laptop screen.
Angle of View Calculator >
Required Disk Space Calculator
Determine your surveillance system's hard drive storage space needs.
Required Disk Space Calculator >
Camera Layout Simulator
Place your cameras into a simulated environment to determine video coverage area.
Camera Layout Simulator >
DISCLAIMERS
©2016 Canon U.S.A., Inc. All rights reserved. Canon and DIGIC are registered trademarks of Canon Inc. in the United States and may also be trademarks or registered trademarks in other countries. “ONVIF” and ONVIF logo are trademarks of ONVIF Inc.. Some of the images and effects are simulated. Not responsible for typographical errors.
 Return to Top
