Web Content Viewer
Actions
VC-C4/VC-C4R
Support Analog Pan/Tilt/Zoom Cameras
Features
You can install your VC-C4s where you need them -- without drawing a lot of attention -- because they're the smallest remote-controlled cameras in their class. At a compact 4" x 4.48" x 3.58" and a feather-light .83 lbs., the VC-C4 proves that good things come in small packages.<br/> <br/> The VC-C4R has all the functionality and performance of the VC-C4, and is only slightly heavier at .96 lbs. But, it can also be mounted on the ceiling where it's out of the way and even less obtrusive.
Along with the Canon VB150 Network Camera Server, the VC-C4 and VC-C4R are part of a state of the art video network -- operating over a LAN, Intranet or the Internet. Alternatively, the VC-C4 and VC-C4R can also be connected to a standard television or monitoring system using the built-in S-Video and Composite Video terminals. Up to nine cameras can be daisy-chained in this way, and operated from a single Infrared controller or controlled from your PC. In this configuration, you are in complete control of pan, tilt and zoom.
The VC-C4 and VC-C4R give you the quality images you've come to expect from Canon. The image excellence begins with the Genuine Canon&#160;16x Optical Zoom Lens. Combine this with a 380,000 pixel, 1/4" CCD and state of the art electronics, and you've got sharp, bright images that won't let you down. Not only that, but Intelligent Image Processing results in higher compression performance for sharp, robust video streaming. No matter what you use your cameras for, you need image crisp, detailed images -- and the VC-C4 and VC-C4R don't let you down.
With the VC-C4 and VC-C4R, you've got it covered. The VC-C4's expansive 200 degree pan and 120 degree tilt range mean that nothing's out of sight for this camera. The same goes for the ceiling-mounted VC-C4R with its 100 degree tilt range and an eye-popping 340 degree pan range. Center-mounting -- plus a quieter, more precise pan/tilt mechanism -- eliminates shaking and minimizes vibration throughout the pan and tilt ranges. The VC-C4 and VC-C4R give you camera coverage that meets your most challenging application.
Specifications
Network Video Solution Camera
Item Code
VC-C4: 4671A001
Video Signal
NTSC
Total Number of Pixels
410,000 (380,000 effective pixels)
Minimum Illumination
6 lux (2 lux at gain-up mode)
Focusing
Auto/Manual
Zoom
16x
Pan Angle Range
+/- 100° (+/- 170° VC-C4R)
Tilt Angle Range
+90/-30°
Moving Speed
1 to 90°/sec (+10°, -90° VC-C4R)
White Balance
Auto
Dimensions
4 x 4.48 x 3.58
Weight
0.83 lbs. (375 grams)
Operating Environment
32 degrees F
Power
13V, 12W
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VC-C4/VC-C4R that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
