Web Content Viewer
Actions
VB-C10
Support Network Cameras
Features
With a built-in Web and FTP server, the VB-C10 and VB-C10R can transmit video images directly to your PC without the need for a Network Camera Server. Simply use the camera's standard Ethernet connection to hook up the unit to your computer via the Web or your LAN. In minutes, you'll be viewing still or full motion video live from the camera's location. The VB-C10 and VB-C10R are TCP/IP, HTTP, BOOTP, FTP, and NTP compatible, making it easy to integrate them into your network video system.
With a wide range of camera motion and focal length, the VB-C10 lets you see everything you need to see. The Genuine Canon 16X Optical Zoom Lens gives you a wide view that can be increased to a full 65 degree field of view using the optional wide angle adapter. Not only that, but the VB-C10 can quickly and steadily pan a full 200 degrees, or tilt an impressive 120 degrees.<br/> <br/> With the ceiling-mounted VB-C10R, you get the same range of focal lengths and a tilt range of 100 degrees. But, you get even more coverage with a 340 degree pan range. With the VB-C10 and VB-C10R, you always have the best view in the house.
The best camera isn't worth anything if you can't install it exactly where you need it. That's what makes the VB-C10 and VB-C10R so powerful. The VB-C10 is only 4.4" x 4.2" x 5.6" and barely tips the scales at 1.4 lbs. The VB-C10R is an equally small 4.4" x 5.4" x 5.6", weighing in at 1.6 lbs. You can install these small units where you want -- so you get the view you need.
With the VB-C10 and VB-C10R, you get bright, clear, high resolution video images. The name Canon means unsurpassed optics -- and the camera's Genuine Canon 16x Optical Zoom Lens lives up to that reputation. But Canon also means quality electronics, too -- like the 380,000 pixel CCD that ensures that none of that optical quality of the lens is lost. The result? Superior images that you've come to expect from Canon cameras.
The VB-C10 and VB-C10R give you the flexibility to capture images just the way you need them and in a way that matches your network environment. You can capture smooth, full motion video at a capture rate of 30 frames per second, at 320 x 240 pixels. (Motion-JPEG is used for image compression.) You can also vary the video capture size, depending on your needs: from 160 x 120, to 320 x 240, to 640 x 480.<br/> <br/> In Automatic Image Capture mode, your VB-C10 and VB-C10R can capture up to 5MB of still images -- either schedule-based or sensor-activated. With flexibility like this, your video network will be exactly what you need.
You can tell your cameras when to record by connecting them to external devices such as door sensors or alarms. That way, you won't miss a thing.
The VB-C10 and VB-C10R come bundled with VB Administration Tools software that gives you unrestricted control and unprecedented ease of use of your cameras. With this software package, you can pan, tilt and zoom your cameras without the limitations of previously set viewing restrictions. You can also bypass preset service times or time limits. Managing server operations is easy, and using Panorama Image is a breeze. With VB Administration Tools, you have everything you need to get the most from your video network system.
Collect, store and manage the still images from your VB-C10 and VB-C10R effortlessly with the VB Collector software that comes with your cameras. Download pictures according to the schedule you set and access them easily with this powerful tool. The power and versatility of your video network is under control with VB Collector.
VB-C10 Kit Contents
VB-C10 Kit Contents VB-C10 (Item Code: 7474A002) / VB-C10R (Item Code: 7475A002) camera Power adapter PA-V16 Adapter plug for external device VB-C10 Manual Applications CD-ROM
Specifications
Network Video Solution Camera
Item Code
VB-C10: 7474A002
Total Number of Pixels
380,000 pixels
Minimum Illumination
6 lux
Zoom
16x
Pan Angle Range
VB-C10: 200° , VB-C10R: 340°
Tilt Angle Range
VB-C10: 120°, VBC10R: 100°
Dimensions
4.2 x 5.6 x 4.4 in. (106 x 143 x 111mm)
Weight
VB-C10: 1.4lb (645g); VB-C10R: 1.6lb (730g)
Power
AC Adapter (100-240V, 50/60 Hz) included, power consumption 15W or less, DC 11.5 V - 14V
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-C10 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
