Web Content Viewer
Actions
VB-C50FSi
Support Network Cameras
Features
<br/> <br/> <br/> <br/> <br/> Network Video Solutions from Canon allow you to transmit high-quality video images through the Internet or a LAN connection. This may involve an individual viewing scenes from multiple locations, many individuals viewing a single location or a combination of the two. Network Video Solutions literally put you and/or the information you wish to broadcast in several places at once:<br/> Record -- Anything that's transmitted can be recorded and stored to be viewed again at any time, a crucial factor in safety and security applications.<br/> <br/> Share -- Network Video Solutions can accommodate multiple viewers and multiple image locations, linking people in a way no other technology can offer.<br/> <br/> Flexibility -- Canon systems make installation, configuration and maintenance easy, so you'll be up and running quickly and worry-free.<br/> <br/> Save -- Putting Canon's Network Video Solutions to work for you will boost the productivity of your business immediately, for cost and time savings that go straight to your bottom line.<br/> With over 60 years of industry-leading experience and a host of groundbreaking technical innovations to its credit, Canon richly deserves its reputation as maker of the world's most advanced cameras and photographic equipment: Each camera features a CCD sensor built to Canon's exacting specifications, ensuring high-resolution images in a variety of motion patterns and lighting conditions.<br/> Canon's Network Video Solutions are designed to perform long term in demanding situations with minimal maintenance.<br/> From network-ready cameras to servers to software, Canon offers a complete, fully integrated system that's ready to go to work.<br/> How can the system work for you? Consider: Medical Facility -- Monitor multiple locations to provide the highest quality care and security in facilities where quick reactions are essential.<br/> <br/> Retail Store -- Strategically located cameras can dramatically improve security and allow employees to provide more prompt customer service.<br/> <br/> Construction Site -- Oversee security, safety practices and project status wherever you are. Ideal for client presentations as well.<br/> <br/> Museum or Gallery -- Constant surveillance in multiple locations can reduce staffing requirements and give you greater peace of mind.<br/> <br/> Teleconferencing -- Conduct high-quality meetings with colleagues and clients all over the world for unmatched convenience and substantial cost savings.<br/> <br/> Distance Learning -- Broadcast lectures and classroom sessions to remote students. WebView's crisp images and superior camera control make students feel as if they're in the room.<br/> <br/> Tourism -- Promote destinations and attractions with live views available to prospective visitors anywhere in the world.<br/> <br/> Traffic Reports -- Newsrooms can monitor key sites to give accurate, real-time traffic reports.<br/>
<br/> <br/> <br/> <br/> <br/> The VB-C50FSi is the fast, simple, affordable network video solution you've been looking for. With a Web server and FTP server built right in, the VB-C50FSi can transmit video images directly to your PC. You simply connect your camera to your computer through the Web or your LAN and, in minutes, you're viewing still or full motion video. There's also the built-in network server that provides viewing for up to 50 clients simultaneously. With such performance, the VB-C50FSi is a versatile and affordable solution for your security video needs.<br/> <br/> The VB-C50FSi offers audio capability when the optional VB-EX50 Multi-Terminal Module is added. With the module a microphone can be connected to the camera, allowing remote monitoring of audio at the camera site. Admin Viewer or Viewer for PC and a speaker-equipped PC allows you to hear audio with the captured video images. Audio playback also lets the remote user or a pre-recorded audio file be heard at the monitored location through a powered speaker. Playback can also be linked to motion or sensor triggered events.<br/>
The VB-C50FSi works in virtually all your locations because of its impressive zoom range. The camera's 26X optical zoom lens boasts the industry's widest focal length range. Combine that with a 12X digital zoom, and you've got a camera that gives wide coverage and can also zoom in to show you important detail.<br/> <br/>
If you need a camera for an extreme, low light situation, the VB-C50FSi is for you. At a shutter speed of 1/30th second, the VB-C50FSi performs with as little as 1 Lux of illumination. And, when there's even less light or no light at all, the camera's Infrared Night Mode with built-in Infrared light feature lets you see what's going on -- up to 9.8' away.<br/> <br/>
The VB-C50FSi broadcasts three different resolutions simultaneously and lets you choose the one that suits your needs. For example, if you have a slower connection or wish to view images through your video-enabled cell phone, you can select a lower resolution image. If your network can accommodate larger file sizes, you can select higher resolution images. The range of resolutions include: 160 x 120, 320 x 240, and 640 x 480.<br/> <br/>
The VB-C50FSi is easy to install wherever you need it because it weighs-in at a light 1.1 pounds and measures only 2.61"(w) x 5.28" (d) x 3.82" (h) (66.2 x 134.2 x 97.0 mm). Power over Ethernet (PoE) allows the VB-C50FSi to receive both data and power through a single Ethernet cable. That means that installation in hard-to-reach locations such as rooftops or ceilings is simpler and more affordable than before, as there is no need for additional power cabling.<br/> <br/>
The VB-C50FSi's scheduling function lets you control the operation of your camera. You can tell it when to record, or when to output signals to an external device. You can schedule by week, date, time, motion-detection, and more -- so you capture just what's important to you.<br/> <br/>
The VB-C50FSi's scheduling function lets you control the operation of your camera. You can tell it when to record, or when to output signals to an external device. You can schedule by week, date, time, motion-detection, and more - so you capture just what's important to you.<br/> <br/>
With the VB-C50FSi, you can enable motion detection in four areas (within the camera's field of view) and set the level of sensitivity, area ratio, and duration of detected movement in each of the four areas. You can even automatically capture images with 15MB of internal memory for storing still images, activated by schedule, motion detection or contact sensor.<br/> <br/>
<br/> <br/> <br/> <br/> <br/> With the VB-C50FSi, you don't have to compromise on image quality. As with every Canon camera, you know you'll be getting the performance of Genuine Canon Optics. But, the VB-C50FSi also comes equipped with a 1/4" CCD with 340K effective pixels, giving you an extraordinary level of detail. On top of that, you get features like the backlight controls that let you adjust your exposure. And, the Shade Correction feature which brightens shadows without affecting brighter areas. The result is image quality that meets your critical security requirements.<br/>
The optional VB-EX50 Multi-Terminal Module increases the functionality and versatility of your VB-C50FSi camera by providing connections for Audio In/Out, Video In/Out (BNC), and External Sensor In/Out.<br/> <br/> With the Audio In/Out capability, you can connect a microphone to your camera. With a speaker-equipped PC and either Admin Viewer or Viewer for PC, you can then hear audio from the camera site. This feature is useful for customer service monitoring, event webcasting, video conferencing and other applications. Or, you can connect a speaker to the camera. With a microphone connected to your PC, you can then talk to someone at the camera site.<br/> <br/> With the Video In connection, you can input an external analog video signal -- for example, from a legacy system camera -- which can then be routed through the VB-C50FSi to your network or the Internet. You can then view the signal from the VB-C50FSi or the external video source. With Video Out, you can connect a monitor and display the camera's video signal. This set up can be used in security situations where you want a subject to know they are being videotaped -- e.g. at a secure entranceway or in a store.<br/> <br/> Plus, External Sensor In/Out provides connections for Alarm Out and Sensor In.<br/> <br/> With all this flexibility, you can get connected and get the VB-C50FSi working for you right away.<br/> <br/>
The VB-C50FSi comes with additional features, including: Control of network bandwidth<br/> DHCP (Automatically assigns the IP Address) and DDNS<br/> Automatic image capture with 15MB of internal storage capacity for still image recording -- activated by schedule, motion detectors, or contact sensors.<br/> Optional Multi Terminal VB-EX50 Module for connecting external speakers, cameras, sensors and alarms.<br/> <br/>
VB-C50FSi Box Contents
VB-C50FSi Box Contents VB-C50SFSi Camera Software CD User's Manual
Specifications
Network Video Solution Camera
Item Code
0777B002
Total Number of Pixels
1/4 680,000 Pixel CCD (340,000 Effective Pixels)
Minimum Illumination
1 Lux (1/30 Shutter Speed)
Zoom
26X Optical Zoom Lens/12X Digital Zoom
Night Mode
Yes
Display Image Size
JPEG: 80x60 / 160x120 / 320x240 / 640x480
Dimensions
2.60(w) x 5.28 (d) x 3.81 (h) (66.2 x 134.2 x 97.0 mm)
Weight
Approx. 1.1 lbs (480g)
Power
PoE (Power Over Ethernet), 802.3af Compliant
Optional Software
Description
4075B002 / VK-16 v2.2 Network Video Recording Software
4075B001 / VK-64 v2.2 Network Video Recording Software
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-C50FSi that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
