Web Content Viewer
Actions
PD-704
Non Contact Displacement Sensor
Contact Us - Request Information form
Contact Us
Features
  • Measure velocity/length without contacting moving target.
  • Track fast acceleration (up to 100G).
  • Measure zero velocity (Object at stopped position).
This is to make Misc appear on the page when needed.
Specifications
PD-704
Measurement Method Profile Matching Method
Light Source LED
Measurement Distance
(WD: Working Distance)
70mm
Measurement Range ±15mm
Measurement Speed Range -4,000mm/s to 4,000mm/s
(Including the stop state)
Maximum Acceleration
of Target Measurement Object
100G
Measurement Resolution
1&956;m
Measurement Accuracy *1 WD:70mm±5mm ±0.2% or 100&956;m
WD:70mm±15mm ±0.5% or 100&956;m
Measurement Repeatability *2 0.02% or 20&956;m
Light Source LED
Sampling Rate 4kHz
Pulse Output 1µm to 1,000µm (Set on application software) Phase A/B (RS422-compliant line driver)
Other
Input/Output
Trigger Input Photo coupler insulation:5 to 24V
Error Output Open collector output(Photo coupler insulation):5 to 24V
USB Interface USB 2.0 Full Speed(Compatible with USB 1.1) compliant
Operating Temperature 0℃ to 50℃
Storage Temperature -30℃ to 50℃
Humidity 90%RH or lower
Vibration Bare vibration Evaluated in vibrating environment Frequency:10 to 500Hz 5G sin wave 2 hours for XYZ directions
Protection Class *3 IP65
Power Voltage DC12V to 24V
Power Consumption 8W
Weight 1.2kg
Dimensions 180 x 135 x 67
Materials Aluminum, Window(Stain proof coating)
Cable Length Power Cable 5m
I/O Cable 5m
USB Cable 5m
*1  When measured in our environment.
*2  When measured in our conditions.
*3  When used the optional kit.
*4  A glossy surface similar to a mirror may not be measured.
Please fill out a brief survey to download brochures.
 Return to Top
