Web Content Viewer
ColorPass Controllers
  • The new Fiery technology allows users to be more productive by automating workflows, minimizing clicks and utilizing new features such as Server Job Presets and Proof Print.
  • The new variable data printing (VDP) enhancements boost performance and increase workflow flexibility with support of PDF/VT-1 format.
  • The controller is also fully compliant with the PDF-X/3 standard for exceptional reproduction.
  • With Image Enhance Visual Editor, users can make on-the-fly corrections for individual images without the need to go back to the original design files.
  • The ColorPASS-GX400 controller utilizes optimized ICC profiles in the ColorWise® architecture to achieve accurate and consistent color on supported imageRUNNER ADVANCE models.
  • Through the Spot-On® with Substitute Colors features, users can quickly match and reuse spot colors in logos and other documents with ease for reliable reproductions.
  • At the touch of a finger, Command WorkStation 5.3 provides expert-level control over all your document workflows.
  • It helps reduce operator mistakes and waste, while shortening learning curves with an intuitive and flexible drag and drop operation from a Mac® or Windows® client.
  • More advanced prepress capabilities can be added through the optional SeeQuence Impose and Compose, which combine feature-rich document imposition and composition tasks into an integrated user interface.
  • From Command WorkStation's streamlined Job Center area, users can easily view the status of all network servers; monitor consumable levels; preview jobs; and group, manage, and track the status of jobs.
ColorPASS-GX400 Controller
Type: External
Supported Devices: imageRUNNER ADVANCE C9280 PRO/C9270 PRO/C7270/C7260/C5255
Processor: Intel® Core™ i5-660 Processor x 3.33GHz
System: Fiery System 10
PDL Support: Adobe PS 3
Print: 1200 x 1200 dpi
Resolution: 2400-dpi Equivalent x 600 dpi
Standard: 2GB
Maximum: 4GB
HDD: 500GB
DVD-ROM Drive: Internal CD/DVD-RW (Standard)
Interfaces (to LAN): 10/100/1000Base-T (RJ-45)
Dimensions (H x W x D): 19-1/8" x 8-1/2" x 19-1/8"
Weight: Approx. 43.5 lb.
Print Driver Supported OS
  • Windows® (Windows 2000/XP/Server 2003/Server 2008/Windows Vista®/Windows 7/Windows 8)
  • Macintosh® (OS X 10.5 or Later)
Color Management Features
  • Spot-On with Substitute Colors
  • PANTONE® Calibrated System
  • Image Enhance Visual Editor
  • Image Smoothing
  • Image Smoothing
  • Graphic Arts Package
  • Graphic Arts Package Premium Edition*
Workflow and Print Management Features
  • Command WorkStation 5.3
  • Hot Folders and Virtual Printer
  • JDF Support
  • Mixed Media and Booklet-Maker V3
  • Suspend on Mismatch
  • Print/Process Next
  • Quick Doc Merge
  • Schedule Printing
  • Sequential Print
  • Proof Print
  • Set Page Device Visual Mapping
  • SeeQuence Suite (Impose and Compose)
  • Spool-RIP-Print simultaneously
  • Advanced Job Re-Order
  • Paper Catalog
  • Adobe PDF 1.5, 1.6, and 1.7 (Acrobat® 6, 7, 8 and 9)
  • PDF/X-1a, 3 and 4
  • Adobe PDF Print Engine 2 Support
Command WorkStation 5.3 Supported Files
  • Adobe Acrobat®
  • PostScript
  • Microsoft® Office Documents
  • Simultaneous Auto-switching Protocols
  • EtherTalk II
  • TCP/IP
  • Novell® IPX Print
    - Exchange, Novell, Domino LDAPv3/RFC2251
    - E-mail Address Access and Authentication
    - User Password Validation
  • Certificate Management
    - SSL/TLS
    - X509 Standard
  • IPv6 Support
  • IPsec Support
  • Auto-sensing Ports
    • RJ-45 for on-board 10/100/1000Base-T and
    • 10/100Base-T, Automatic IP configuration
    SNMP Printing Support
    • Mac Bonjour, AppleTalk®, SMB (peer to peer), LPD
    Variable Data Printing
    • Fiery FreeForm™ v1 enhanced and v2.1
    • PPML v2.2, PDF/VT-1
    • PODi certified
    • Creo VPS Compatibility
    • Optimized PostScript® and Optimized PDF
    • Password Access in CWS
    • SNMPv3 System Updates
    • Secure Erase
    • 802.1x Support
    • IP Filtering
    • User Authentication
    • MAC Filtering
    • IPsec Support
    • Port Blocking
    • SSL/TLS Support
    • SNTP
    • Removable Hard Disk Drive*
    • ColorPASS-GX400 Driver
    • WebTools
    • Hot Folders and Virtual Printers
    • Remote Scan
    Power Supply and Consumption
    Auto-switching 90-135/180-265 VAC, 47-63Hz
    6A @ 115 VAC, 3A @ 230 VAC
    • CE Mark, CSA, TUV/G, UL, CB Scheme, EU RoHS
    • EMC
      - EN55022 Part B (CE marked)
      - FCC Class B
      - VCCI II
    • SeeQuence Suite Impose and Compose
    • Removable Hard Disk Drive Kit-B1
    • X-Rite Eye-One
    • Integrated Interface and Stand-A1
This is to make Misc appear on the page when needed.
 Return to Top
