Web Content Viewer
Actions
ColorPASS-Z3000
ColorPass Controllers
Features
Built on a Windows XPE Platform, the ColorPASS-Z3000 features Pentium 4® @2.4 GHz processor, a 60GB Hard Drive, and 256 MB SDRAM, giving it the power to quickly process some of the largest graphic files.
Equipped with EFI® Job Monitor, the ColorPASS-Z3000 gives users the ability to track the status of any job that is sent to an EFI-driven device and will alert users to errors that would prevent a job from printing.
With Command Workstation™ 4.1 standard, the ColorPass-Z3000 allows users to easily navigate through its windows, instantly tracking, editing and merging jobs. Users can also preview PDF files and scale images to fit various paper sizes. Also available is the Command WorkStation LE 4.0, giving MAC users access to the software's most powerful features.
The ColorPASS-Z3000 ships standard with ColorWise® 3, the color management software that lets users utilize ICC profiles and customize color curves.
The standard Graphic Arts Feature Set is ideal for users who require features like Spot-On® Color Matching to reproduce PANTONE® colors accurately, Auto Trapping to ensure proper registration, and Hot Folders to eliminate the time-consuming task of configuring print settings for multiple jobs.
With NetWise™ 3, the ColorPASS-Z3000 can be easily integrated into your existing network, and thus can serve as the hub of your network printing system.
The ColorPASS-Z3000 supports Fiery® Remote Scan for advanced capabilities, such as scanning hard copies back to your desktop or server, or e-mailing scans to any user over the internet.
Specifications
Product Specifications
Model Name
ColorPASS-Z3000
Dimensions (H x W x D)
20 x 9-1/2 x 20-2/5 (508mm x 243mm x 518mm)
Weight
39 lb. (17.69kg)
Power Supply
Auto-switching 110/220V, 50-60Hz 350W
Power Consumption
115.5W
Processor
Intel® Pentium 4 @ 2.4GHz CPU
Memory / RAM
256MB SDRAM (Upgradable to 512MB)
Hardware
400MHz System Bus (Front Side Bus) 60GB hard disk Standard
System Bus
Hard Drive
60GB hard disk
CD-ROM
Standard
Networking
Autosensing Ports
RJ-45
10/100 Base-T Standard Support
Yes
Peer-to-Peer Windows Printing
Yes
Automatic IP Configuration
Yes
Utilities
Member Printing
Yes
Custom Page Size
Yes
Tray Alignment
Yes
Fiery Scan
Fiery Remote Scan 4.x
Fiery Downloader
Yes
Web Tools
Yes
Fiery Driver
Yes
Color Management
ColorWise
ColorWise 3
Document Printing Features
Load Balancing
Yes
Archiving
Yes
DocBuilder Pro
Optional
Brochures
Loading...
 Return to Top
