Web Content Viewer
Actions
ColorPASS-Z5100
ColorPass Controllers
Features
The Graphic Arts Feature Set includes the following tools:<br/> Soft Proofing - to allow matched-color screen previews of print jobs<br/> Auto Trapping - to ensure proper registration and fit of adjacent colors<br/> Halftone Screening - for accurate proofing<br/> SpotOn&#8482; Color Matching - for the precise reproduction of PMS colors<br/> Unlimited Separations - lets you print as many spot color plates as desired<br/> Paper Simulation - to give the user a better idea of how the final piece will look when printed<br/> Hot Folders - a separate utility that lets you send print files and job tickets to the server automatically<br/> &nbsp; <br/>
Specifications
Product Specifications
Model Name
ColorPASS-Z5100
Dimensions (H x W x D)
21-1/2 x 7-1/2 x 18-1/2 (537.5mm x 187.5mm x 462.5mm)
Weight
55 lb. (24.75kg)
Power Supply
Auto-switching 110/220V, 50/60Hz
Power Consumption
120W maximum / 400 BTU/Hr
Processor
Intel Pentium III 1GHz
Memory / RAM
512MB SDRAM
Hardware
100MHz System Bus512K 80GBStandard (250MB)Standard Optional
System Bus
100MHz System Bus
Level 2 Cache
512K
Hard Drive
80GB
Zip Drive
Standard (250MB)
CD-ROM
Standard
Advanced Controller Kit
Optional
Networking
Simultaneous Auto-Switching Protocols
EtherTalk, TCP/IP, Novell IPX/SPX 802.2, 802.3, Ethernet II and SNAP frame types, Novell NDS compliant
Autosensing Ports
RJ-45
10/100 Base-T Standard Support
Yes
Optional Token Ring Support
Optional
Peer-to-Peer Windows Printing
Yes
Automatic IP Configuration
Yes
Utilities
Member Printing
Yes
Custom Page Size
Yes
Tray Alignment
Yes
Fiery Scan
Yes
Fiery Downloader
Yes
Web Tools
Yes
Fiery Driver
Yes (with Automatic Configurator)
Color Management
ColorWise
ColorWise 3 - Standard
Document Printing Features
Load Balancing
Yes
Archiving
Yes
DocBuilder Pro
Optional
Brochures
Loading...
 Return to Top
