Web Content Viewer
Actions
ColorPASS-Z650
ColorPass Controllers
Features
Connected to the CLC 1180, 1140 or 1110, the ColorPASS-Z650 delivers a level of color quality and consistency once reserved only for high-level commercial printers.
Fueled by a powerful Intel® Pentium® III 1GHz processor, 256MB of memory, and a 40GB hard drive, the ColorPASS-Z650 crunches through full-color jobs, delivering exceptional image quality at remarkable speed.
The ColorPASS-Z650's ColorWise® 3 color-management system provides a wide array of color correction and calibration tools for achieving consistent color from all applications and platforms.
ColorCal®, a scanner-based calibration process, employs a two-step method to compensate for potential measurement inconsistencies, thereby ensuring optimum calibration accuracy.
Post-Rip Calibration eliminates the need to reRIP an entire job by applying all calibration properties after rasterization, which results in greater productivity.
With Auto-Gray, the gray balance between multiple devices is adjusted automatically, for the closest possible visual match.
The ColorPASS-Z650 is further enhanced with the optional Graphic Arts package, a specialized set of productivity tools that integrates into high-end, prepress workflows for exceptional control over output quality and greater accuracy in proofing.
When using Command Workstation software, prepress time is reduced significantly due to multiuser access, which enables all users to be linked to the entire production process, from any desktop PC.
Specifications
Product Specifications
Model Name
ColorPASS-Z650
Dimensions (H x W x D)
20-1/2 x 7-1/2 x 19 (512.5mm x 187.5mm x 475mm)
Weight
55 lb. (24.75kg)
Power Supply
Auto-switching 110/220V, 50/60Hz
Power Consumption
200W--682 BTU/Hr
Processor
Intel Pentium III @1GHz
Memory / RAM
256MB SDRAM
Hardware
100MHz512K40GBStandard (250MB)Standard Optional
System Bus
100MHz
Level 2 Cache
512K
Hard Drive
40GB
Zip Drive
Standard (250MB)
CD-ROM
Standard
Advanced Controller Kit
Optional
Networking
Simultaneous Auto-Switching Protocols
EtherTalk, TCP/IP, Novell IPX/SPX, 802.2, 802.3, Ethernet II and SNAP frame types, Novell NDS compliant
Autosensing Ports
RJ-45
10/100 Base-T Standard Support
Yes
Optional Token Ring Support
Optional
Peer-to-Peer Windows Printing
Yes
Automatic IP Configuration
Yes
Utilities
Command WorkStation Software Kit
Command WorkStation 4 - Standard
Fiery FreeForm
Standard
Member Printing
Yes
Custom Page Size
Yes
Tray Alignment
Yes
Fiery Scan
Yes
Fiery Downloader
Yes
Web Tools
Yes
Fiery Driver
Yes (with Automatic Configurator)
Color Management
ColorWise
ColorWise 3 - Standard
Document Printing Features
Load Balancing
Yes
Archiving
Yes
DocBuilder Pro
Optional
Brochures
Loading...
 Return to Top
