Web Content Viewer
Actions
ColorPASS-Z7400
ColorPass Controllers
Features
The ColorPASS-Z7400 features Dual Intel® Xeon™ 2.8GHz processors, a 320GB Hard Drive, and 1GB RAM, giving it the power to quickly process some of the largest graphic files quickly so that catalogs, posters and other color-critical files can be produced with ease.
The standard Graphic Arts Feature Set is ideal for users who require features like Spot-On® Color Matching to reproduce PANTONE® colors accurately, Auto Trapping to ensure proper registration, and Hot Folders to eliminate the time-consuming task of configuring print settings for multiple jobs.
Equipped with EFI Job Monitor, the ColorPASS-Z7400 gives users the ability to track the status of any job that is sent to an EFI-driven device and will alert users to errors that would prevent a job from printing.
With Command Workstation™ 4.1 standard, the ColorPass-Z7400 allows users to easily navigate through its windows, instantly tracking, editing and merging jobs. Users can also preview PDF files and scale images to fit various paper sizes. Also included in the ColorPASS-Z7400 is Command WorkStation LE 4.0, giving MAC users access to the software's most basic features.
The ColorPASS-Z7400 ships standard with ColorWise® 3, the color management software that lets users utilize ICC profiles and customize color curves.
With NetWise™ 3, the ColorPASS-Z7400 can be easily integrated into your existing network, and thus can serve as the hub of your network printing system.
With DocBuilder Pro™ 2.2 standard and the optional Nagel finisher users have a complete solution for the production of professionally saddle stitched and trimmed booklets.
Specifications
Product Specifications
Model Name
ColorPASS-Z7400
Dimensions (H x W x D)
29 x 11 x 23.5 (280mm x 737mm x 597mm)
Weight
61 lbs. (27.7kg)
Power Supply
Auto Switching 110/220V, 50/60Hz
Power Consumption
200W 682 BTU/Hr
Processor
Dual Intel Xeon 2.8GHz CPU
Memory / RAM
1GB Dual DDR-SDRAM
Hardware
512K 320GB IDE 250MB ATAPI DVD-ROM Drive Optional
Level 2 Cache
512K
Hard Drive
320GB IDE
Zip Drive
250MB
CD-ROM
ATAPI DVD-ROM Drive
Advanced Controller Kit
Optional
Networking
Simultaneous Auto-Switching Protocols
EtherTalk, TCP/IP, Novell IPX/SPX, 802.2, 802.3, Ethernet II and SNAP Frame types, Novell NDS-compliant
Autosensing Ports
RJ-45
10/100 Base-T Standard Support
Yes with Gigabit Support
Peer-to-Peer Windows Printing
Yes
Automatic IP Configuration
Yes
Utilities
Member Printing
Yes
Custom Page Size
Yes
Tray Alignment
Yes
Fiery Scan
Yes
Fiery Downloader
Yes
Web Tools
Yes
Fiery Driver
Yes (with Automatic Configurator)
Color Management
ColorWise
ColorWise® 3 - Standard
Document Printing Features
Load Balancing
Standard
Archiving
Standard
DocBuilder Pro
Standard
Brochures
Loading...
 Return to Top
