Web Content Viewer
imagePASS Controllers
"SmartRIP technology" helps to increase print performance and throughput up to 77% faster* than the previous Fiery platform model.
*Based on EFI internal benchmark test
ImageViewer for Black and White optional plug-in provides controls to adjust the black tone curve and allows operators to preview with full-resolution print data in order to save time and reduce errors and waste.
  • Booklet Maker and Fiery VUE allow you to produce professional-looking, finished print materials, such as booklets, quickly, easily and cost-effectively, in-house.
  • Advanced Job Management tools provide operators with the necessary control to advance and schedule jobs to reduce bottlenecks and minimize down-time.
  • Automated job submission features such as Hot Folders and Virtual Printers reduce job setup time, automate manual tasks, and cut down on repetitive workflows with a simple drag-and-drop operation.
  • SeeQuence Impose optional plug-in offers visual imposition and document preparation capabilities to ensure accurate, finished documents on time.
  • Manage the security of your data effectively with Secure Erase.
  • Administrators can set three different access levels, LDAP-based user authentication, port blocking, and IP/MAC filters.
  • Offers multiple ways to securely print on the go - enabling users to print from mobile devices, in the office or at a remote location.
imagePASS-U2 Controller
Type: External
Supported Devices: imageRUNNER ADVANCE 8205/8295/8285/6275/6265/6255
Processor: Intel Pentium Processor E5300 2.6GHz
System: Fiery System 10
PDL Support: Adobe PS 3, PCL 5e/6
Print: 1200 x 1200 dpi
Resolution: 2400 dpi equivalent x 600 dpi
Memory: 2GB (Standard/Maximum)
HDD: 250GB
Interfaces (to LAN): 10Base-T/100Base-TX/1000Base-T
Dimensions (H x W x D): 12.5" x 5.5" x 15.5" (317.5mm x 139.7mm x 393.7mm)
Print Driver Supported OS
Adobe PS 3:
  • Windows (Windows 2000/XP/Server 2003/Server 2008/Windows Vista®/Windows 7)
  • Macintosh® (OS X 10.3.9 or later)
PCL 5e/6:
  • Windows (Windows 2000/XP/Server 2003/Windows Vista/Windows 7)
Image Quality
  • PDF/X Support
  • Speed Priority
  • Image Priority
Workflow and Print Management Features
  • Command WorkStation 5*
  • Native JDF Support
  • Mixed Media and Booklet-Maker V4
  • Paper Catalog
  • Compatibility with PDF 1.4, 1.5, 1.6, 1.7, PDF/X and PDF/VT-1
  • Hot Folders and Virtual Printers
  • Insert Tabs
  • Advanced Job Management features include Rush Printing, Schedule Print, Suspend on Mismatch, Job Reorder, Proof Print, Set Page Device Visual Mapping, and Quick Doc Merge
Command WorkStation 5 Supported Files
  • Adobe Acrobat®
  • PostScript
  • Microsoft® Office Documents
  • Simultaneous Auto-switching Protocols
  • EtherTalk II
  • TCP/IP
  • Novell® IPX Print
    - Exchange, Novell, Domino LDAPv3/RFC2251
    - E-mail Address Access and Authentication
    - User Password Validation
  • Certificate Management
    - SSL/TLS
    - X509 Standard
  • IPv6 Support
  • IPsec Support
  • Auto-sensing Ports
  • RJ-45 for on-board 10/100/1000Base-T
  • 10/100Base-T, Automatic IP configuration
  • SNMP Printing Support
    Mac Bonjour, AppleTalk®, SMB (peer to peer)
    Variable Data Printing
  • Fiery FreeForm v1 enhanced and v2.1
  • PPML
  • VPS Compatibility
  • PDF/VT-1
  • Security
    • Password Access in CWS
    • SNMPv3 System Updates
    • Secure Erase (Standard)
    • 802.1x Support
    • IP Filtering
    • User Authentication
    • MAC Filtering
    • IPsec Support
    • Port Blocking
    • SSL/TLS Support
    • SNTP
    • imagePASS-U2 Driver
    • WebTools
    • Remote Scan 5.3
    Power Supply and Consumption
    Auto-switching power supply with active PFC (Power Factor Connection)
    • CE Mark, CSA, TUV/GS, UL, CB Scheme, EU RoHS
    • EMC
      - EN55022 Part B (CE marked)
      - FCC Class B
      - VCCI II
    • SeeQuence Suite
      - Impose
      - Compose
    • Removable Hard Disk Drive
    • Integrated Interface and Stand (19" display, keyboard, mouse, and furniture stand)
    • Fiery ImageViewer
    * Available with optional free download at www.efi.com/CWS5.
This is to make Misc appear on the page when needed.
 Return to Top
