Web Content Viewer
Actions
Canon CX-G2400 2" Inkjet Card Printer
Business Card/ID Card Printers
Item Code: 9054B002AA
Features
  • 2-Inch Card Size
  • Dye-Based Ink for Color Critical Graphics
  • Business Card Printing up to 3,000 Cards/Hour
  • 1200 x 1200 dpi Print Resolution
  • 200 Card Business Card Capacity
  • USB 2.0 & Ethernet Connectivity
Specifications
Printer
Printing Method
Inkjet – Dye Based
Longer Lasting Color
Color/Monochrome
Full Color and Monochrome Printing
Print Speed (up to)
Business Cards: 3,000 Cards Per Hour (CPH)1
Plastic Card: 3,000 Cards Per Hour (CPH)1
FIRST PRINT OUT TIME
10 Seconds or less (Except Pre-Cleaning)
Number of Nozzles
2,766 (BK, C, M, Y each) Total: 11,064
Print Resolution (Up to)
1200x1200 dpi
Ink Compatibility
BJI-P211BK (4PK)  4 x Black Ink Tanks (14.5 ml/each)
BJI-P211C    (4PK)  4 x Cyan Ink Tanks (14.5 ml/each)
BJI-P211M   (4PK)  4 x Magenta Ink Tanks (14.5 ml/each)
BJI-P211Y    (4PK)  4 x Yellow Ink Tanks (14.5 ml/each)
WT-X201   Maintenance Cartridge
Maximum Printable Area
Length: 6.7
Width: 2.26
Minimum Margin
Top/Bottom Margin: 0.01
Left/Right Margin: 0.01
Paper Thickness
0.21 – 0.76 mm (0.01 - 0.03)
Automatic Sheet Feeder
Business Card: 250 Cards Plastic Card: 100 Cards
Paper Compatibility
Business Cards, Plastic Cards
Body Durability
Paper: 500,000 Standard Business Card Size (Excluding Print Head)
General
OS Compatibility
Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit), Windows Server 2012 (64-bit) / 2008 (64-Bit)3
Standard Interface
USB 2.0
Ethernet (10/100/1000Base-T)
Power Source
AC 100v /240v, 50/60 Hz
Power Consumption (approx.)
Operating: 229 W (Maximum)
Sleep Mode: 8.5 W or less
Dimension (W x D x H)
15.67 (W) x 7.09 (D) x 10.98 (H)
Weight
17.64 lbs.
Operating Temperature:
60° - 122°F (15° - 50°C)
Operating Humidity:
10-80% RH (Non-Condensing)
Certifications/Standards
RoHS Compliance
Warranty
2-Year limited warranty. 2-Year toll-free 100% U.S.-based technical phone support.*
*Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
Canon CX-G2400 Box Contents
Canon CX-G2400 Box Contents Canon CX-G2400 2" Inkjet Card Printer AC Adapter / Power Cord Set of Ink Tanks (BK, C, M, Y, 14.5 ml/each) Maintenance Cartridge (Installed) Stacker Printer Driver/User Guide CD v1.0 Getting Started Guide Basic Operation Guide Basic Operation Guide
DISCLAIMERS
  1. Print speed based on click top drop, average print coverage, with USB connectivity, Cards Per Hour (CPH).
  2. "Business Card" capacity of 200 Sheets is determined using card weights of 300 gsm.
  3. Operation can only be guaranteed on a PC with pre-installed Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit) or Windows Server 2012 (64-bit)/2008 (64-bit).
  4. Warranty and support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
 Return to Top
