Web Content Viewer
Actions
Canon CX-G6400 4" Inkjet Card Printer
Business Card/ID Card Printers
Item Code: 1749C002AA
Features
  • 4-Inch Card Size
  • Dye-Based Ink for Color Critical Graphics
  • Business Card Printing up to 6,000 Cards/Hour
  • 1200 x 1200 dpi Print Resolution
  • 400 Card Business Card Capacity
  • USB 2.0, & Ethernet Connectivity
Specifications
Printer
Printing Method
Inkjet – Dye Based
Print Speed (up to)
Business Cards: 6,000 Cards Per Hour (CPH)1
Credential Plastic Card/4x6 Card: 2,700 Cards Per Hour (CPH)1
Envelopes: 28 Envelopes/Minute1
FIRST PRINT OUT TIME
10 Seconds or less (Except Pre-Cleaning)
Number of Nozzles
5,097 (BK, C, M, Y each) / Total: 20,388
Print Resolution (Up to)
1200x1200 dpi
Ink Compatibility
BJI-P411BK (4PK) 4 x Black Ink Tanks (105 ml/each)
BJI-P411C (4PK) 4 x Cyan Ink Tanks (105 ml/each)
BJI-P411M (4PK) 4 x Magenta Ink Tanks (105 ml/each)
BJI-P411Y (4PK) 4 x Yellow Ink Tanks (105 ml/each)
WT-X401 Maintenance Cartridge
Maximum Printable Area
Length: 11.7
Width: 4.2
Minimum Margin
Top/Bottom Margin: 0.05
Left/Right Margin: 0.07
Paper Thickness
0.21 - 0.76 mm (0.01 - 0.03)
Automatic Sheet Feeder
Paper feed capacity2
Business Card: 400 Cards
4x6 Card: 400 Cards
Plastic Card: 100 Cards
Envelopes: 100 Envelopes
Stock capacity2
4x6 Card: 400 Cards
Paper Compatibility
Business Cards, ID Cards, Certificates, Envelopes, Matte Paper, Glossy Paper, Plastic Cards
Body Durability
Paper: 1.5 Million (Standard Business Card Size)
Plastic Card: 500,000 (Excluding Print Head)
General
OS Compatibility
Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit), Windows Server 2012 (64-bit) / 2008 (64-Bit)3
Standard Interface
USB 2.0
Ethernet (10/100/1000Base-T)
Power Source
AC 100v /240v, 50/60 Hz
Power Consumption (approx.)
Operating: 229 W (Maximum)
Sleep Mode: 8.5 W or less
Dimension (W x D x H)
16.34 (W) x 16.14 (D) x 18.27 (H)
Weight
55.12 lbs.
Operating Temperature:
Temperature: 60° - 122°F (15° - 50°C)
Operating Humidity:
Humidity: 10-80% RH (Non-Condensing)
Certifications/Standards
RoHS Compliance
Warranty
2-Year limited warranty. 2-Year toll-free 100% U.S.-based technical phone support.*
*Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
Canon CX-G6400 Box Contents
Canon CX-G6400 Box Contents Canon CX-G6400 4" Inkjet Card Printer Head Package Unit AC Adapter / Power Cord Set of Ink Tanks (BK, C, M, Y, 105 ml/each) Maintenance Cartridge (Installed) Printer Driver/User Guide CD v1.0 Getting Started Guide & Unpacking Instructions Installation Adjustment Paper (Postcard Size) Warranty Card
DISCLAIMERS
  1. Print speed based on click top drop, average print coverage, with USB connectivity, Cards Per Hour (CPH).
  2. "Business Card" and "4"x6" Card" capacity of 400 sheets is determined using card weights of 300 gsm.
  3. Operation can only be guaranteed on a PC with pre-installed Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit) or Windows Server 2012 (64-bit)/2008 (64-bit).
  4. Warranty and support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
 Return to Top
