Web Content Viewer
Actions
CX-G2400 2” Card & Badge Printer
Card & Badge Printers
Item Code: 9054B002AA
Features
Superior Speed and Accuracy
The Canon CX-G2400 2" Inkjet Card Printer is made to keep up with the fast pace of your business - so you are never wasting time waiting and can get more jobs done in the same amount of time. This advanced printer can turn out paper or plastic CR80 ID Cards or business cards at speeds up to 50 cards per minute.1 All with an ultra-crisp inkjet print resolution of 1200 x 1200 dpi using dye-based inks for colorful graphics and vivid colors. Traditional thermal transfer printers simply don't compare.
High Resolution & Dual Media Printing
From increased security, to better first impressions, the 1200x1200 dpi high-resolution will allow your customers and clients to experience exceptional photo image quality. That means images and text on business cards always look sharp and crisp, ID badges are easier to identify, and barcodes scan on the first try. The Canon CX-G2400 2" Inkjet Card Printer is ready to meet the needs of a variety of markets and applications, including ID cards, business cards, personalized gift cards, membership & loyalty cards, and more. Unlike thermal printers, the Canon CX-G2400 Inkjet Printer prints on both paper and plastic. This versatility enables you to print business cards, visitor badges, and claim tickets on paper, as well as ID badges, membership, gift and loyalty cards on plastic- all on the same machine– and with fewer stops to load new media. That's because the CX-G2400 can hold up to 200 paper business cards or up to 100 plastic cards.2
High Output, Low Maintenance
Compared to cumbersome, hard-to-change, thermal printer ribbons that need to be replaced after a few hundred prints, the CX-G2400 uses easy-to-replace inkjet printer cartridges that last for thousands of prints. A great convenience during busy periods. Ribbons can leave client and customer information exposed, Inkjet unlike traditional ribbons offer a more secure and streamlined method to print secure ID card information. A standard wire lock slot feature make the Canon CX-G2400 ideal for your ID and business card printing solution.
Specifications
Printer
Printing Method
Dye-based Inkjet
Print Mode
Single Sided (Simplex)
Print Speed (up to)
First Print Out Time: Business Card: 10 seconds or less1
Business Card: 50 Cards/minute (3,000 Cards Per Hour (CPH))1
Plastic Card (CR80): 50 Cards/minute ((3,000 Cards Per Hour (CPH))1
Number of Nozzles
2,816 dots
Print Resolution (Up to)
1200x1200 dpi
Ink Compatibility
4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow)
Maximum Printable Area
Width: 57.4 mm
Length: 171.4 mm
Minimum Margin
Top/Bottom: 1.5 mm (Micro Margin: 0.3 mm)
Left/Right: 2.0 mm (Micro Margin: 0.3 mm)
Paper Thickness
0.21 – 0.76 mm (0.01 - 0.03)
Automatic Sheet Feeder
Paper: 200 Business Cards2 Plastic Card: 100 Cards (CR80)2
Paper Compatibility
Paper Card: 2.1 x 3.5 Business Cards (IJ Coated Matte/Glossy)
Plastic Card: 2.13 x 3.38 PVC (CR80)
Other: Thick Cards, Labels
Body Durability
500,000 Cards / 5 Years1
Estimated Output Number
Approx. 3,500 Cards per cartridge set2
Maximum Paper Size
Width: 58.0 mm
Length: 172.0 mm
Paper Weights
0.21 - 0.60 mm
General
OS Compatibility
Windows 10 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit)3
Standard Interface
USB 2.0
Ethernet (10/100/1000Base-T)
Power Source
AC 100v-240v, 50/60 Hz
Power Consumption (approx.)
Maximum: Approx. 150 W
Operating: Approx. 33 W
Sleep Mode: Approx. 5.6 W or Less
Dimension (W x D x H)
15.4 (W) x 7.09 (D) x 11.0 (H)6
Weight
17.63 lbs.
Operating Temperature:
41& - 95&F (5& - 35&C)
Operating Humidity:
10 - 90% RH (Non-Condensing)
Noise
Acoustic Information4:
Operating Noise (Max.): 58dB or less
Standby Noise: 35dB or less
Cartridge Fill Volume
Black / Cyan / Magenta / Yellow: 14.5 ml
Maintenance Cartridge Info & Fill Volume
WT-X201 Maintenance Cartridge 1
Approx. 35,000 Sheets1
Operational Method
LCD: No
Buttons/LEDs: 3 Buttons / 7 LEDs
Warranty
2 Year Warranty5
Canon CX-G2400 Box Contents
Canon CX-G2400 Box Contents Canon CX-G2400 2" Inkjet Card Printer Set of Ink Tanks (BK, C, M, Y, 14.5 ml/each) Maintenance Cartridge (Installed) Power Cord Stacker Printer Driver/User Guide CD Getting Started Guide Basic Operation Guide Warranty Card
Brochures
Loading...
DISCLAIMERS
  1. Based upon standard business card print conditions with no image and print size of 2"x3.5" inkjet coated matte business card, 7.5% Duty/Color, 50 sheets x 2 jobs/day. Print speed based on click to drop, average print coverage, with USB connectivity, Cards Per Hour (CPH).
  2. Based upon card weight thickness measured at 300gsm (0.3mm)
  3. Operation can only be guaranteed on a PC with pre-installed Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit).
  4. Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
  5. Warranty and Support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  6. Printer weight measured excluding ink cartridges installed.
 Return to Top
