Web Content Viewer
Actions
IX-R7000 Card & Badge Printer
Card & Badge Printers
Item Code: 3189C002AA
Features
Outstanding Print Quality
With the IX-R7000 Dual-Sided ID Card Printer, you can expect to produce photo quality images. The crisp, clear and professional output is achieved with 600 dpi print resolution utilizing dye-sublimation technology. This technology also gives you the option to print double-sided and edge-to-edge, giving your ID cards the professional look and quality you expect from Canon.
Fast Performance with High-Quality
With fast performance for either single or dual-sided ID cards, the Canon IX-R7000 is ready to perform. Print up to 145 cards per hour, thanks to a 25 second fast print speed for a single-sided color ID card.1 Eliminate the need to refill frequently with a hopper capacity of up to 250 cards.2 Double covers on the feeding unit and a replaceable cleaning tape and cleaning roller at the transport protects against dust getting into the unit and onto your printed ID cards. Our uniquely designed feeding system allows users to refill cards without stopping printing, resulting in a seamless operation.
Simple and Straightforward
The IX-R7000 Dual-Sided ID Card Printer makes getting the job done easier. Its compact design is perfectly suited to fit in tight areas when you need the printer to do its job and small enough to fit underneath a counter or to be easily stored when not in use. The easy-to-read operation panel with its LCD display and operation buttons can allow for clear access and comfortable operation. With a thermal retransfer system, there are no messy inks to change out and you know the amount of cards you can print regardless of coverage.
Designed with Security in Mind
The last thing you want is your blank ID cards getting into the wrong hands. This is why we designed a slot so that a security wire lock can be attached. Additionally, the card feeding cassette can be removed and securely stored while not in use.
Specifications
Printer
Printing Method
Dye-Sublimation / Retransfer
Print Speed (up to)
Single Sided: 1
Approx. 25 Seconds/Card (YMCK)
Max. Print Speed 145 Cards Per Hour (YMCK)
Dual Sided: 1
Approx. 50 Seconds/Card (YMCKK)
Max. Print Speed 72 Cards Per Hour (YMCKK)
Print Resolution (Up to)
600 x 600 dpi
Paper Sizes
Card Size
CR-80 Size (2.1 x 3.4 / 54 x 86.5 mm)2
Maximum Printable Area
Width: 54 mm
Length: 86.5 mm
Paper Thickness
Card Thickness
30 mil - 39.3 mil (0.76 - 1.0 mm)2
Paper Compatibility
Card Types
PVC Plastic Cards
Body Durability
100,000 Cards / 5 Years1
Paper Handling
Hopper Capacity
250 Cards (30 mil (0.76 mm) Thickness/Card)2
General
OS Compatibility
Windows 10 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit), Server 2008 R2 (64 bit)3
Standard Interface
USB 2.0
Ethernet (10/100/1000Base-T)
RS-232C
Power Source
AC 100-240V, 50/60Hz
Power Consumption (approx.)
Maximum: Approx. 300 W
Dimension (W x D x H)
11.7 (W) x 13.4 (D) x 17.2 (H)
Weight
42.8 lbs.
Operating Temperature:
Temperature: 50° - 95°F (10° - 35°C)
Operating Humidity:
Humidity: 20-80% RH (Non-Condensing)
Noise
Acoustic Information
Operating Noise (Max.): 58dB or less4
Standby Noise: 35dB or less4
Warranty
2 Year Warranty5
Color/Monochrome
Full Color or Monochrome Printing
Print Modes
Single Sided (Simplex) / Dual Sided (Duplex)
Removable Card Hopper
Yes
Consumable Types
Ink Ribbons: IXR-YMCKK / IXR-YMCK
Retransfer Film: IXR-RFILM
Print Mode Detail
Single Sided (Simplex): Color / Monochrome
Dual Sided (Duplex): Side 1: Color (YMCK) / Side 2: Monochrome (YMCKK)
Print Yields
IXR-YMCK: 500 Cards (Single Sided: Color1)
IXR-YMCKK: 400 Cards (Double Sided: 1st Side Color, 2nd Side Monochrome)1
IXR-Film (Transfer Film): 500 Cards (Single Sided)1
Operational Method
LCD: Yes (2 Line LCD - 16 Character)
Buttons/LEDs: 4 Buttons / 1 LEDs
Anti-Theft Wire Lock Security Slot
Built-in
IX-R7000 Box Contents
Canon IX-R7000 Box Contents Canon IX-R7000 Dual Sided ID Card Printer IX-R7000 Printer Driver/User Guide CD Cleaning Card Card Hopper USB Cable Power Cord Getting Started Guide
Brochures
Loading...
DISCLAIMERS
  1. Based upon standard print condition print size of 2.1"x3.4" inkjet coated CR80 PVC card at 30 mil (0.76mm) thickness, 80 cards/day. Print speed based on click to drop, average print coverage, with USB connectivity, Cards Per Hour (CPH).
  2. Card material compatibility may vary. Supported card materials include; PVC,PET-G, PET, composite PVC and PC cards, CR-80 size, measured at 30 mil (0.76 mm) thickness, in regards to ISO 7810. Certain restrictions may apply.
  3. Operation can only be guaranteed on a PC with pre-installed Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit), or Windows Server 2008 (64-bit).
  4. Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
  5. Warranty and Support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  6. Printer weight measured excluding IXR-YMCK, IXR-YMCKK, or IXR-RFILM installed.
 Return to Top
