Web Content Viewer
Actions
ColorStream 6000 Series Inkjet Printers
Color Continuous Feed Digital Presses
Questions?
  • Advanced print head calibration
  • Canon PreFire refresh technology
  • High-Speed monochrome option
  • Top-notch printing productivity
  • DigiDot imaging technology
  • Seamless workflow integration
This is to make Misc appear on the page when needed.
Technology
Inkjet DigiDot drop-on-demand, piezoelectric
Ink Water based dye and pigment, InkSafe™ technology (contact your local sales representative for details)
Operating next generation look & feel user interface
Paper Transport Pinless, tight web, automatic tension control
Paper Input tight web unwinder (included in basic unit)
Paper Output Open post-processing interface with Type1 connectivity
Print Resolution 600 × 600 dpi with 2-bit multilevel option
Page Composition Simplex configuration: 2-up simplex I-Twin / L-Twin / H-Twin: 2-up duplex
Print Speed Letter Images Per Minute Simplex configuration: 536 I-Twin / L-Twin / H-Twin: 1,073
Duty Cycle Per Month Simplex configuration: 46-128 million letter images
Duplex Configuration: 5-65 million letter images
Paper
Print Width 6.5"-21.25"
Page Length 6"- 54"
Paper Width Simplex 6.5"-21.25"
Paper Width Duplex 6.5"-21.25"
Printer Configuration I-Twin / L-Twin / H-Twin Simplex configuration: not applicable
Paper Weight 60–160 gr/m2
Extended paper weight 30 – 300 GSM (with testing)
Substrates Preprinted, inkjet, laser and recycled newspaper
Reel Shafts 70 mm, 3", 5" and 6"
Physical Data (Roll to Roll)
Length (without paper) Simplex configuration: 137 inches
I-Twin: 357 inches
L-Twin: 283 inches
H-Twin: 268inches
Width (without paper) Simplex configuration: 55 inches
I-Twin: 55 inches
L-Twin: 197 inches
H-Twin: 283 inches
Height 78.74 inches
Weight (without paper) Simplex configuration: 5,512 lbs
I-Twin / L-Twin / H-Twin: 11,685 lbs
Power Requirements
USA 60Hz Simplex printer configuration: 208v 100 Amp
I-Twin / L-Twin / H-Twin printer: 2 - 208v 100 Amp connections
Environmental
Temperature Optimal range 68–79 °F, limited range 61–84 °F
Humidity Optimal range 40–60%, limited range 30–80%
Operating noise Maximum 75 dB
Workflow
Controller SRA MP third-generation, high-performance blade processors
Printer Data Format AFPDS, PDF, PCL , Line Data* , LCDS*, Metacode*, PostScript*, PPML*, TIFF*, VIPP* * Via PRISMAproduction
Print Manager (optional) PRISMAproduction®
Connectivity Gigabit Ethernet
Available Color Configurations Simplex configuration: 1/0–6/0 I-Twin / L-Twin / H-Twin: 1/1–6/6
MICR and Special Colors Available for all configurations.
Web Inspection Camera Available for all configurations.
Rewind Unit Available for all configurations.
Operator Attention Light Available for all configurations.
Paper Dust Elimination System Available for all configurations.
Adobe PDF Print Engine 2.5 Available for all configurations.
Operator Calibration Available for all configurations.
2-bit Multilevel Available for all configurations.
Brochures
Loading...
 Return to Top
