Web Content Viewer
Actions
ProStream 1000 Series
Color Continuous Feed Digital Presses
Features
The ProStream merges the best of digital and offset printing. You'll find offset-quality print along with the high productivity and flexibility of inkjet. Take over previously offset-printed jobs and improve cost or personalize. Get ahead of the crowd by stepping up the quality in your digital work. Enable your customers wider reach by expanding campaign sizes. With the ProStream, you can offer your customers high-quality, 1200 dpi output with the cost efficiency and variable value-add of inkjet.
The ProStream is an inkjet engine with outstanding print quality. It prints fully variable content on a wide range of uncoated, treated, and matte, silk, or gloss coated papers. It produces up to 1,144 letter size or 35 million pages per month in 2-up duplex production speed at a speed of 262 ft/min. It follows in the footsteps of the other web-fed engines, which are well-known for their reliability, stability, and uptime.
The ProStream has a revolutionary new engine design with the latest generation piezo drop-on- demand print head, our proprietary ColorGrip, and a new polymer pigment ink set. The results of that combination of innovations are vibrant colors, smooth shadings, and ultra-fine details – even in dark tones. With extremely high-quality output, the question is no longer what will you print, but what can’t you print with inkjet.
The web is kept free floating for optimal image quality, process control, and consistency – on a very wide range of media. The result is an appealing look and feel, flatlaying prints, and homogeneous gloss levels.
PRISMAproduction® and SRA® MP controller technology have become the efficiency benchmark in heavy-volume variable content printing. The ProStream can also be directly integrated into your PDF workflows with the new PRISMAcontrol digital front end. And let’s not forget the many connectable adjacent systems, to manage anything from content creation to tracking and tracing. Either way, you have the flexibility to manage your production at the engine – right where it happens!
Based on over 1,200 inkjet printers installed, this press benefits from Canon Solutions America’s extensive experience in delivering excellence in inkjet. The ProStream is designed for high quality, versatility, efficiency, and reliability. Every installed engine is backed by an expert team to service your new press and integrate it into your production environment.
Standard: 1,185 Sheets Maximum: 6,335 Sheets
ProStream 1000
MAIN UNIT
TYPE Monochrome Laser Multifunctional
PRODUCTIVITY
Print speed 262 ft/min (80m/min)
Configuration I-Twin (duplex) CMYK
Pages per minute (letter size) 1,144 in duplex mode
Max. duty cycle per month (letter size) 35 million in duplex mode
TECHNOLOGY
Print head technology DigiDot® piezoelectric drop-on-demand
Resolution at nominal speed 1200 × 1200 dpi with multilevel droplet modulation
Drop sizes Variable, 2 – 5 picoliters
Ink set ColorGrip, polymer pigment ink set CMYK with InkSafe® technology
PAPER & PRINT IMAGE
Print width 21.89” (540 mm)
Web width 16 – 22” (406 – 558 MM)
Substrates Offset uncoated, matt and gloss coated, inkjet-optimized (according to released paper list)
Paper weight 60 – 160 gr/m², extended range after tests possible
Paper transport Pinless, tight web, automatic tension control
PHYSICAL DATA
Length × Width (print tower) 19’ x 8.5’ (5,800 x 2,550 mm)
Length × Width (duplex roll-to-roll) 55.5’ x 8.5’ (16,850 x 2,550 mm)
Height 6.6’ (2000 mm)
Weight (print tower) 14,333 lb (6,500 kg)
POWER CONNECTION PRINTER
Connection Twin engine (2 towers) 2 x 400V/250A
Controller 400V/16A
Climate Control Unit 400V/16A
ENVIRONMENTAL REQUIREMENTS
Temperature Optimal range 68 - 80° F (20 - 26° C)
Humidity Optimal range 40 – 50%, limited range 40 – 80%
Operating noise Maximum 75 dB
DATA WORKFLOW
Page length 6 – 60” (152 – 1520 mm)
Controller SRA MP controller with Adobe APPE 4
Printer data format1 PDF (PDF/X), PDF/VT, PPML, TIFF, VIPP, AFP/IPDS (IS/3), and more
Front end print manager
PRISMAcontrol, PRISMAproduction or other qualified output management system
Connectivity 2 × 10 Gigabit Ethernet (RJ45 copper) with PRISMAcontrol
2 × 10 Gigabit Ethernet (optical short range) with PRISMAcontrol
10 Gigabit Ethernet (copper, optic MMF/SR, optic SMF/LR)
Operating Touch based next generation look & feel user interface
PRE- AND POST-PROCESSING
Standard online configuration Roll-to-roll
Paper input Partner unwinder with integrated web cleaning system
Paper output Partner rewinder; barcode-controlled offline or nearline finishing
All information is subject to change without notice.
¹ Partly in combination with PRISMAcontrol or PRISMAproduction
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
