Web Content Viewer
Actions
imagePRESS C7011VP
Color Sheetfed Digital Presses
Canon imagePRESS C7011VP/S Series Color Digital Press Overview
Graph Expo 2016
Get Your Free Show Pass Here
Workflow Solutions
Features
  • True 1,200 x 1,200 dpi with 256 levels of gray enable the highest near-offset quality for the most color critical environments.
  • The imagePRESS C7011VP runs at a rated speed on a vast variety of medias ranging from 16 lb. bond to 120 lb. cover.
  • Gloss Optimization technology enables the adjustment of the imaged area appearance to minimize deviations in gloss reflectance relative to media finish.
  • Closed-loop, real-time color controls coupled with new internal environmental controls help to keep high quality consistent - even throughout longer runs.
  • Air Suction, Air Separation, and Air Assist technologies provide reliable, accurate paper feeding, just like offset.
  • The imagePRESS C7011VP features 2,000 sheet input standard, with the ability to scale up to 10,000 sheets. All trays accommodate all supported media.
  • Canon's oil free V Toner enable one of the widest color gamuts and a lay-flat finish, just like offset inks, even on pages with high toner coverage.
  • On-the-fly replacements of paper, toner, and waste toner keeps jobs flowing through the press to maximize uptime.
  • Productivity enhancements enable increased performance for complex jobs, including jobs containing mixed-media and mixplex sheets.
  • The new imagePRESS C7011VP features increased part life of several key parts and components, increasing uptime and reliability to help your press meet the demands of deadline-oriented environments.
  • Modules for saddle-stitching, stapling, perfect binding, hole-punching, and in-line trimming can be quickly integrated with any imagePRESS model.
  • More durable parts, recyclable consumables, and energy-saving mode leverage on-demand printing sustainable; print on recycled stocks and produce output that can be easily de-inked and recycled.
  • The Media Library lets you create, edit, manage, and select medias from one central location. Once the details of the media are entered it's stored and the press is set for optimal performance and quality.
  • The flexible Customer Productivity Program (CPP) complements a standard service contract and enables trained operators to perform proactive maintenance procedures.
  • The new Rev Gen Services extend the range of the Essential Business Builder Program Portfolio to include a 12-week sales development program to increase customer revenue.
This is to make Misc appear on the page when needed.
Specifications
Model Name
imagePRESS C7011VP
Type
Laser Electrostatic Transfer System
Scanning Resolution
Up to 1200 x 1200 dpi
Halftone
256-Level Grayscale
Paper Size: 7.2 x 7.2 - 13 x 19.2
Letter
70
Legal
37
12 x 18: 35
13 x 19: 33C6011VP/C6011Letter: Up to 60
Legal: Up to 32
12 x 18: Up to 30
13 x 19: Up to 28
Standard Paper Capacity
2,000 Sheets (20 lb. Bond)
Maximum Paper Capacity
10,000 Sheets (20 lb. Bond)
Acceptable Paper Weights
Cassette
16 lb. Bond to 120 lb. Cover
Duplexing
Automatic Duplex/Perfect
Any Supported Stock
Power Requirements
C7011VP/C6011VP: 3-Phase 208V/30A
C6011: 1-Phase 208V/30A
Dimension
52.4 x 101.8 x 45.4
Estimated Toner Yield
CMYK: 35,500 impressions at 10% coverage (LTR pgs)
Feeders
Description
DADF (Duplex Automatic Document Feeder)-R1
Acceptable Originals
Statement to 11 x 17
Scanning Speed
Up to 80 ipm (300 dpi)
Up to 50 ipm (600 dpi)
Capacity
100 Sheets (20 lb. Bond)
Paper Weights
13 lb. Bond to 80 lb. Cover
Paper Supply Options
Description
POD Deck-A1
Paper Capacity
4,000 Sheets (20 lb. Bond)
Paper Sizes
7.2 x 7.2 to 13 x 19.2
Paper Weights
Power Source
208V/15A
Dimensions
43.1 x 38.7 x 31.2
Description
Secondary POD Deck-A1
Paper Capacity
Paper Sizes
Paper Weights
Dimensions
43.1 x 31.9 x 31.2
Description
Paper Deck-AC1
Paper Capacity
3,500 Sheets (20 lb. Bond)
Paper Sizes
Letter, Letter-R, Legal, 11 x 17, 12 x 18, 13 x 19
Paper Weights
17 lb. Bond to 110 lb. Cover
Dimensions
22.4 x 23.7 x 24.4
Description
Stack Bypass-A1
Paper Capacity
Paper Sizes
5.5 x 7.2 to 13 x 19.2
Paper Weights
17 lb. Bond to 140 lb. Index Color Image Reader-H1
Image Sensor: CCD
Document Size: Up to 11 x 17
Resolution: 600 x 600 dpi, 256 Gradations
Output Options
Finishers Output Trays
Description
Professional Puncher-B1/Integration Unit-A1
Paper Weights
20 lb. Bond to 80 lb. Cover
Paper Size
LTR, LTR-Tab Paper
Die Set Patterns: Loose Leaf 3-Hole/5-Hole, Velo Bind 11-Hole, Plastic Comb 19-Hole, Twin Loop 21-Hole/32-Hole, ProClick 32-Hole, Color Coil 44-Hole
Power Source
120V/15A
Dimensions
40.9 x 22 x 31.2*
Description
Finisher-AJ1/Saddle Finisher-AJ2
Paper Weights
16 lb. Bond to 120 lb. Cover**
Paper Size
Stapling: Executive, Letter-R, Letter, Legal, 11 x 17
Saddle Finisher: Letter-R, Legal, 11 x 17, 12 x 18, 13 x 19, Custom Size
Top Tray
3,000 Sheets (20 lb. Bond)
Lower Tray
Saddle Stitch Tray
30 Booklets or Limitless
Staple Capacity
Up to 100 Sheets
Booklet Stapling Capacity
Uncoated: Up to 25 Sheets
Coated: Up to 15 Sheets
Staple Positions
Corner Stapling, Double Stapling
Folding Capacity
V-Folding: Up to 5 Sheets without Stitch (20 lb. Bond)
Power Source
120V/15A
Dimensions
46.5 x 31.5 x 31.2High-Capacity Stacker-C1
Offset Stack Capacity: 5,000 Sheets (20 lb. Bond)
Top Tray Capacity: 1,000 Sheets (20 lb. Bond)
Paper Size: Up to 13 x 19.2
Paper Weight: 16 lb. Bond to 120 lb. Cover
Dimensions (H x W x D): 48.8 x 33.9 x 30.1
Power Source: 120V/15A
Perfect Binder-B1
Cutting Method: 3-Side Cut or 1-Side Cut
Finished Book Size: 5.4 x 7.99 to 8.5 x 11.69
Book Thickness: 10 to 200 Sheets (20 lb. Bond)
Body Paper Weight: 16 lb. Bond to 28 lb. Bond
Cover Paper Weight: 28 lb. Bond to 110 lb. Cover
Trim Range
Top/Bottom: .26 to 1.56
Side: .26 to 1.95
Dimensions (H x W x D): 53.5 x 36.3 x 31.1
Power Source: 208V/15APuncher Unit-BB1 (Option for Finisher/Saddle Finisher)
Paper Weight: 16 lb. Bond to 110 lb. Index
Paper Sizes
2-Hole: Legal, Letter-R
3-Hole: 11 x 17, Letter, Executive
Booklet Trimmers
Description
Booklet Trimmer-D1
Margin Trimming: Open-end Only
Trim Amount: 0.08 to 0.78
Trim Thickness: 50 Sheets
Paper Weight: 16 lb. Bond to 110 lb. Cover
Output Tray Capacity: 30 Booklets
Dimensions (H x W x D): 40.9 x 62 x 30.3
Description
Two-Knife Booklet Trimmer-A1Margin Trimming: Top and Bottom
Trim Amount: 0.08 to 0.59
Dimensions (H x W x D): 40.9 x 21.1 x 30.3
Power Supply: 120V/15A
Document Inserters
Description
Document Insertion Unit-C1 (Option for Finisher/Saddle Finisher)
Paper Weight
Paper Sizes
Upper Tray: 7.2 x 7.2 to 11.7 x 13
Lower Tray: 7.2 x 7.2 to 13 x 19.2
Feeder Capacity
200 Sheets x 2 (20 lb. Bond)* Size includes Professional Puncher Integration Unit-A1.
** Saddle-stitching cannot handle over 110 lb. Cover.
Supplies
IPQ- 2 Toner
Color: Black
Item Code: 0436B003AA
Estimated Toner Yield: 35,500 Copies/Bottle (Estimated @ 10% Coverage)
Color: Cyan
Item Code: 0437B003AA
Color: Magenta
Item Code: 0438B003AA
Color: Yellow
Item Code: 0439B003AA
IPQ- 2 Starter
Color: Black
Item Code: 0440B001AA
Estimated Toner Yield: 750,000 Copies/Bottle
Color: Cyan
Item Code: 0441B001AA
Color: Magenta
Item Code: 0442B001AA
Color: Yellow
Item Code: 0443B001AA
Accessories
Hardware Accessories
  • POD Deck (Up to 2)
  • High Capacity Stacker (Up to 2)
  • Unload-While-Run High Capacity Stacker (Up to 1)
  • Saddle Finisher
  • Staple Finisher
  • Professional Puncher
  • 2 and 3 Hole Puncher
  • Perfect Binder
  • Face Trimmer
  • Two-Knife Trimmer
  • Document Insertion Unit
  • SDD BLM300C Professional Booklet Maker
  • SDD Square Fold Module and Square Fold Module with Two-Knife Trimmer
  • Long Sheet Feeder
  • MAX Ring Binder
  • In-line UV Coater
Brochures
Loading...
Videos
  • Click here to view the Canon "Protecting Your Environment" In-Brief Video
 Return to Top
