Web Content Viewer
Actions
imagePRESS C10010VP/C9010VP
Color Sheetfed Digital Presses
Press For Success
Educational Guides for Production Printing Environments
Workflow Solutions
Features
  • Dual Fixing Technology helps maintain high productivity even on complex jobs
  • Ultrasonic Multisheet Detection and automatic sheet purging to an escape tray helps keep the press running1
  • Wide range of productive, in-line feeding and finishing options for white-paper-in, and finished-product-out
  • Up to eight different paper sources2 with an 11,000-sheet paper feed capacity3 enables long, unattended print jobs
    1. POD Deck-D1 required
    2. Optional accessories required
  • In-Line Spectrophotometric Sensors provide automatic color calibration, media profiling2, and profile verification2
  • Multi D.A.T. helps to maintain consistent color across long runs automatically
  • The flexible Advanced Image Transfer Belt and Simple Transfer Adjustment combine to help produce brilliant solids
  • The R-VCSEL Laser helps create offset-like quality with 2400 x 2400 dpi print resolution
    2. Optional accessories may be required
  • Supports stocks up to 150 lb. Cover and various specialty medias including synthetics.
  • Diversify your application offerings by printing on stocks up to 51.2" in length2
  • Generate precise and consistent front-to-back registration with the Active Registration System
  • A choice of powerful, digital front-ends, including Canon's PRISMAsync Print Server and Fiery powered imagePRESS Servers, help deliver high performance
Print Speed (Simplex/Duplex)
8.5" x 11" Up to 100/90 ipm
11" x 17" Up to 56.2/50.6 ipm
12" x 18" Up to 53.5/48.1 ipm
13" x 19" Up to 51/45.9 ipm
13" x 30" Up to 28.3/235.5 ipm
Scan Speed1 (Letter, 300 dpi)
BW: Up to 240 opm
Color: Up to 220 opm
Print Resolution
2400 x 2400 dpi
Paper Capacity2
Standard: Up to 2,000 Sheets
Maximum:1 Up to 11,000 Sheets
Paper Size Standard: 7.2" x 7.2" to 13" x 19.2"
Optional: 5.5" x 5.83" to 13" x 51.2"
Paper Weight
Standard: 16 lb. Bond to 150 lb. Cover
Optional: 16 lb. Bond to 150 lb. Cover
Automatic Duplexing
Media Size: 7.2" x 7.2" to 13" x 30"1
Media Weight: 16 lb. Bond to 150 lb. Cover
Long Sheets1
Media Size: Up to 13" x 51.2"
CONSUMABLES
TONER
T02 Toner
TONER YIELD (ESTIMATED @ 10% COVERAGE) Black: 44,000
Color: 43,00
FOOTNOTES
  1. Optional accessories required
  2. Capacity based on 20 lb. Bond
This is to make Misc appear on the page when needed.
Supplies
T02 Toner
Color: Black
Item Code: 8529B001AA
Estimated Toner Yield: 44,000 Copies/Bottle (Estimated @ 10% Coverage)
Color: Cyan
Item Code: 8530B001AA
Estimated Toner Yield: 43,000 Copies/Bottle (Estimated @ 10% Coverage
Color: Magenta
Item Code: 8531B001AA
Estimated Toner Yield: 43,000 Copies/Bottle (Estimated @ 10% Coverage)
Color: Yellow
Item Code: 8532B001AA
Accessories
Hardware Accessories
  • Color Image Reader-M2
  • Printer Cover-K1
  • ADF Access Handle-A1
  • POD Deck-D1
  • Secondary POD Deck-D1
  • POD Deck Lite-C1
  • POD Deck Lite XL-A2
  • Long Sheet Tray-D1
  • BDT VX 370-790 Long Sheet Feeder
  • Tab Feeding Attachment-E1
  • Document Insertion Unit-N1 Set
  • Multifunction Professional Puncher-B1
  • Loose Leaf 3-Hole Punch
  • Loose Leaf 5-Hole Punch
  • Velo Bind 11-Hole Punch
  • Plastic Comb 19-Hole Punch
  • Twin Loop 21-Hole Punch
  • Twin Loop 32-Hole Punch
  • Color Coil 44-Hole Punch
  • High Durability Color Coil 44-Hole Punch
  • High Durability Loose Leaf 3-Hole Punch
  • High Durability Plastic Comb 19-Hole Punch
  • Crease Die
  • Perfect Binder-E1
  • Perfect Binder Continuous Kit-A1
  • High Capacity Stacker-H1
  • HCS End Module Cover
  • HCS Long Sheet Tray-A1
  • PowerLift-A1
  • Paper Folding Unit-J1
  • Finisher-AN1
  • Saddle Finisher-AN2
  • Long Sheet Tray-C1
  • Canon Finisher Long Sheet Catch Tray-A1
  • Puncher Unit-BS1
  • DFD Adapter and Finisher Bridge-A1
  • Booklet Trimmer-F1
  • Square Fold Booklet Maker
  • Square Fold Booklet Maker with Two-Knife Trimmer
  • 2-Knife Trimmer & Conveyor Set
  • Ring Binder MB-1000C
  • Plockmatic BLM35 Booklet Maker
  • SDD BLM300C Professional Booklet Maker
Digital Front End Options
  • PRISMAsync Print Server
  • imagePRESS Server B7000 V2
  • imagePRESS Server B6000 V2
PRISMAsync Controller Options
  • DP Link
  • Fontset Simplified Chinese
  • Fontset Traditional Chinese
  • Fontset Japanese
  • Fontset Korean
imagePRESS Server Options
  • Graphic Arts Pro Package
  • Integrated Interface & Stand-NX GL
  • Integrated Interface & Stand-NX LS
  • Fiery Job Master
  • Fiery JobFlow
  • Fiery Color Profiler Suite
  • Removable HDD Kit
System Connectivity Options
  • Color Universal Send Kit-AB1
  • Universal Send PDF Advanced Feature Set-G1
  • Universal Send PDF Security Feature Set-D1
  • Data Erase Kit-C1
  • Voice Guidance Kit-F2
  • HDD Data Encryption and Mirroring Kit-E1
  • 3.5INCH/250GB HDD
Brochures
Loading...
 Return to Top
