Web Content Viewer
Actions
imagePRESS C1+II
Color Sheetfed Digital Presses
Features
  • With EFI's ColorWise color management software, users are given pinpoint color matching control.
  • Auto-trapping delivers improved registration through a simple point-and-click operation to fill in the white spaces that sometimes appear between butting colored sections of an image.
  • Spot-On defines spot colors for increased flexibility when custom matching CMYK colors such as logos and package designs, without skewing other colors within a document.
  • The Command Workstation offers an intuitive graphical user-interface for complete control of document production from a centralized location.
  • Clear Toner: The unique clear toner feature of the Canon imagePRESS C1+ II introduces to the creative market a visual texture treatment that expands design capabilities. From subtle delicate suggestions to a bold creative image, this affect impacts the message to the market.
This is to make Misc appear on the page when needed.
Specifications
Model Name
imagePRESS C1+II
Imaging System
Laser Electrostatic Transfer System
Developing System
Dry Dual Component Developing System
Auto Carrier Refresh
Image Server Memory
80GB HDD + 1.5GB RAM
Max Mailboxes Supported
100 User Inboxes
Max. Stored Documents: 1,500 per Inbox
Max. Stored Pages: 3,000 Pages with Full Color
6,000 Pages with B/W
Scanning Resolution
600 x 600 dpi
Printing Resolution
1200 x 1200 dpi (Continuous Tone)
Halftone
256-Level Grayscale
Letter
Up to 14 ppm (Color)/Up to 60 ppm (B/W)
First Copy Time
7.6 Seconds (B/W), 14.1 Seconds (Color)
Multiple Copies
1 to 999
Magnification
25% - 400% (Between 25% and 400%, in 1% Increments
Preset Reductions
25%, 50%, 61%, 70%, 81%, 86%
Preset Enlargements
115%, 122%, 141%, 200%, 400%
Acceptable Originals
Sheets, Books, 3-Dimensional Objects
Maximum Original Size
11 x 17 (Ledger)
Standard Paper Capacity
550 Sheets
Paper Drawers x 4 (2,200 Sheets: 20 lb. Bond)
Stack Bypass (100 Sheets: 20 lb. Bond)
Optional: Paper Deck-AA1/AB1
(3,500 Sheets: 20 lb. Bond)
Output Sizes
Cassette
Executive, Statement-R, Letter-R, Letter, Legal, 11 x 17, 12 x 18, 13 x 19
Bypass
3-5/16 x 5-7/8 to 13 x 19
Acceptable Paper Weights
Cassette
17 lb. Bond to 110 lb. Index and Transparency
Bypass
17 lb. Bond to 140 lb. Index and Transparency
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
11 Minutes 40 Seconds Max. After Powering On
11 Minutes 40 Seconds From Sleep Mode
Power Requirements
120V AC, 60Hz (From Main Engine)
Power Plugs: 15A, 20A (Total Two Plugs for Main Unit)
Dimension
(Printer/Reader, w/o UI): 41-3/8 x 33-5/8 x 35-5/8
(Printer/Reader, with UI): 58-1/8 x 52-3/4 x 35-3/8
Weight
(Printer/Reader): Approximately 694 lb.
Estimated Toner Yield
CMYK: 16,000 impressions at 10% coverage (LTR pgs)
Clear: 31,500 impressions at 10% coverage (LTR pgs) One Pass / 22,500 impressions at 10% coverage (LTR pgs) Two Pass
Feeders
Description
DADF (Duplexing Automatic Document Feeder)-R1*
Statement to 11 x 17
Scanning Speed
Up to 80 Sheets per Minute (Letter)
Capacity
100 Sheets
Paper Weights
13 lb. Bond to 80 lb. Cover
Dimensions
5-5/8 x 25-1/2 x 22-3/8 (Excl. Document Output Tray)
Weight
Approximately 47.3 lb.
Paper Supply Options
Description
Side Paper Deck-AA1**
Paper Capacity
3,500 Sheets (20 lb. Bond)
Paper Sizes
Letter, Letter-R, Legal, 11x 17, 12 x 18, 13 x 19
Paper Weights
Non-Coated Media: 17 lb. Bond to 140 lb. Index
Coated Media: 28 lb. Bond to 140 lb. Index
Dimensions
22-1/2 x 23-5/8 x 24-1/2
Weight
Approximately 112.4 lb.
Description
Side Paper Deck-AB1
Paper Capacity
Paper Sizes
Letter
Paper Weights
Dimensions
22-5/8 x 12-7/8 x 23
Weight
Approximately 68.3 lb.
Output Options
Finishers Output Trays
Description
Finisher-AA1 and Saddle Finisher-AA2
Number Of Trays
3 Tray Capacity
Non-Collate Mode
Tray A: 250 Sheets (Letter, Statement-R, Executive)
125 Sheets (Legal, Letter-R, 11 x 17, 12 x 18, 13 x 19)
Tray B: 1,300 Sheets (Letter, Statement-R, Executive)
650 Sheets (Legal, Letter-R, 11 x 17, 12 x 18, 13 x 19)
Tray C: 2,450 Sheets (Letter, Executive)
1,700 Sheets (Statement-R)
Collate and Group Mode***
Tray B: 1,300 Sheets (Letter, Executive)
650 Sheets (Legal, Letter-R, 11 x 17)
Tray C: 1,700 Sheets (Letter, Executive)
Staple Mode***
Tray B/C: 1,300 Sheets/100 Sets (Letter, Executive)
650 Sheets/50 Sets (Legal, Letter-R, 11 x 17)
Staple Capacity
Corner/Double: 50 Sheets (Letter, Executive)
30 Sheets (Letter-R, Legal, 11 x 17)
Paper Sizes
Letter-R, Legal, 11 x 17, 12 x18
Capacity/Tray: 1 to 5 Sheets/25 Sets
6 to 10 Sheets/15 Sets
11 to 15 Sheets/10 Sets
Stapling Capacity
15 Sheets
Fold Type
V-Fold
Dimensions
43-3/8 x 25-1/2 x 25-7/8
Weight
Finisher-AA1: Approximately 106.9 lb.
Saddle Finisher-AA2: Approximately 158 lb.
Attachable Accessories: Puncher Unit-M1Puncher Unit-M1
(Option for Finisher-AA1/Saddle Finisher-AA2)***
Max. Paper Weight: 17 lb. Bond to 140 lb. Index
Paper Sizes
2-Hole: Letter-R, Legal, Executive
3-Hole: Letter, 11 x 17
Punch Method: Sequential Processing System (One Sheet at a Time)
Punch Dust Stock: 3,000 Sheets
Power Source:From Main Unit
Dimensions (H x W x D): 32-3/4 x 4-1/4 x 24-1/4
Weight: Approximately 15.4 lb.
Print Board
Description
Color UFR II/PCL/PS Printer Kit-P2
Processor
Canon Dual Custom Processors (Shared)
Standard Memory
1.5GB (Shared)
Hard Disk
80GB (Shared)
PDL Support
UF UFR II, PCL 5e, PostScript 3 Emulation
Interface Connections
10/100 Base-T (RJ-45), USB (2.0)
Other Features
Network OS: Windows 2000/XP/Windows Vista®/Windows Server 2003/2008/Mac OS X/Citrix Metaframe
Send Expansion Sets
Description
Color Universal Send Kit-G1
Sending Method
E-Mail, I-Fax, SMB, File Server, (FTP, IPX, WebDAV), User Inbox
Color Mode: Auto Color Select (Full Color/Gray Scale) Auto Color, Select (Full Color/B/W), Full Color, Grayscale, B/W
Address Book Capacity
Max. 1,800 Destinations (Includes 200 One-Touch Buttons), Max. 5 LDAP Servers
Communication Protocol
File: FTP (TCP/IP), SMB (TCP/IP), NCP (IPX), WebDAV
E-Mail/I-Fax: SMTP, POP3, I-FAX (Simple, Full)
Data Format
File, E-mail: TIFF, JPEG, PDF, PDF(Compact)†† PDF(Trace & Smooth)††, PDF(OCR)††, Encrypted PDF, Digital Signature PDF (Device, User)
I-Fax: B/W: TIFF(MH, MR, MMR)
Color: TIFF(Profile-C) Additional Accessories
Universal Send PDF Advanced Feature Set-A1♦ ♦Universal Send PDF Security Feature Set-A1Δ Δ ΔDigital User Signature PDFKit-A1♦ ♦Web Access Software-E1ϑSecure Watermark-A1Encrypted Secure Print Software-C1ϑHDD Data Encryption Kit-B1Voice Guidance Kit-B1♦Remote Operator Software Kit-A2HDD Data Erase Kit-A1♦ ♦Platen Cover Type K♦ ♦ ♦Stack Bypass Tray-B1Barcode Printing Kit-A1Card Reader Attachment-E1Voice Guidance Kit-B1Voice Guidance Attachment-B1Staple Cartridge-J1Staple Cartridge-D2Document Tray-J1Card Reader-C1ΟKey Switch Unit-A2Cassette-AE1ADFAccess Handle-A1Ο Ο imagePRESS Server Z1 imagePRESS Server T1 Ο Ο Ο Workflow Composer-B4Access Management System Kit-A1Braille Label Kit-E1imageWARE Suite* Power Supply Unit-S1 (for imagePRESS C1+II) is included.
** Requires power outlet independently.
*** Up to 11 x 17
† Up to 12 x 18
† † When configured on the imagePRESS C1+II, requires Universal Send PDF Advanced Feature Set-A1.
Δ When configured on the imagePRESS C1+II, requires Universal Send PDF Security Feature Set-A1.
Δ Δ When configured on the imagePRESS C1+II, requires Digital User Signature Kit-A1.
Δ Δ Δ Requires the Color Universal Send Kit-G1.
ϑ Cannot be installed with the imagePRESS Server T1/Z1 V2.
♦ Voice Guidance Attachment-B1 is required for installation.
♦ ♦ HDD Data Encryption Kit-B1 is required for installation.
♦ ♦ ♦ Cannot be installed with the DADF-R1.
Ο Requires Card Reader Attachment-E1.
Ο Ο Requires DADF-R1.
Ο Ο Ο Check with your local Authorized Canon Dealer for availability.
imagePRESS C1+ Demo Video
Clear Image Editor Demo Video
DICOM Printing Opportunity Video
  • Click here to view the Canon "Protecting Your Environment" In-Brief Video
Brochures
Loading...
 Return to Top
