Web Content Viewer
Actions
imagePRESS C6000VP
Color Sheetfed Digital Presses
Features
  • The imagePRESS C6000VP prints letter sized jobs at 60ppm, 11x17 jobs at 30ppm, regardless of media weight.
  • With up to 1200 x 1200 dpi resolution, you get finer image quality, higher quality characters, and smooth corners.
  • The press handles a variety of media weights and types up to 13" x 19.2" in size and 17lb. bond (64gsm) to 110lb. cover (300gsm) in weight.
  • The optional POD Decks holds up to 4,000 sheets each of any supported media in any tray. They are equipped with Advanced Air Feeding Technologies to help ensure every media is fed reliably.
  • The imagePRESS C6000VP is equipped with Auto Press Calibration to set your color densities automatically and Real Time Calibration performs live tests to maintain the high image quality throughout the day.
  • The Advanced Image Transfer Belt (AITB), similar to the blanket on an offset press accepts the image from the drum then transfers all four colors to the media in a single pass which produces better solids on plain, coated, and textured and specialty medias.
  • Suction Feeding technology picks up the top sheet with air, not rollers, for more stability as the sheet is fed into the press.
  • "On The Fly" technology lets you maintain and even boost productivity without stopping the press. Now you can refill media trays, remove and replace the toner bottle, and remove the waste toner bottles without stopping or pausing the press.
  • Multi-feed detection prevents two or more sheets from entering the press at the same time are diverted to the escape tray on top of the POD deck without ever stopping the press.
  • The Media Library lets you create, edit, manage, and select medias from one central location. Once the details of the media are entered it's stored the press is set for optimal performance and quality.
This is to make Misc appear on the page when needed.
Specifications
Model Name
imagePRESS C6000VP
Type
Laser Electrostatic Transfer System
Printing Resolution
Up to 1200 x 1200 dpi
Halftone
256-Level Grayscale
Maximum Original Size
13 x 19.2
Standard Paper Capacity
2,000 Sheets (20 lb. Bond)
Maximum Paper Capacity
10,000 Sheets (20 lb. Bond) with Optional 2 POD Decks
Acceptable Paper Weights
Cassette
17 lb. Bond to 110 lb. Cover (All Trays)
Duplexing
Automatic Duplex/Perfect Any Supported Stock
Power Requirements
3-Phase 208V/30A
Dimension
Approx. 52.4 x 101.8 x 44.7
Weight
2,645 lb.
Feeders
Description
DADF (Duplex Automatic Document Feeder)-R1
Acceptable Originals
Statement to 11 x 17
Scanning Speed
Up to 80 ipm (300 dpi) Up to 50 ipm (600 dpi)
Capacity
100 Sheets (20 lb. Bond)
Paper Weights
13 lb. Bond to 80 lb. Cover
Power Source
From Marking Engine
Dimensions
Approx. 5.6 x 25.4 x 22.4
Weight
Approx. 47.3 lb.
Paper Supply Options
Description
POD Deck-A1
Paper Capacity
4,000 Sheets (1,000 x 2 + 2,000) (20 lb. Bond)
Paper Sizes
Minimum Paper Size: 7.2 x 7.2
Maximum Paper Size: 13 x 19.2
Paper Weights
Power Source
208V/15A
Dimensions
Approx. 43.1 x 38.9 x 31.2
Weight
Approx. 551 lb.
Description
Secondary POD Deck-A1
Paper Capacity
Paper Sizes
Paper Weights
Power Source
From POD Deck-A1
Dimensions
Approx. 43.1 x 31.9 x 31.2
Weight
Approx. 507 lb
Description
Paper Deck-AC1
Paper Capacity
3,500 Sheets (20 lb. Bond)
Paper Sizes
Letter, Letter-R, Legal, 11 x 17, 12 x 18, 13 x 19
Paper Weights
Power Source
From Marking Engine
Dimensions
Approx. 22.4 x 23.7 x 24.4
Weight
Approx. 112 lb. Stack Bypass-A1
Paper Capacity: 100 Sheets (20 lb. Bond)
Minimum Paper Size: 5.5 x 7.2
Paper Weight: 17 lb. Bond to 140 lb. Index Color Image Reader-H1
Image Sensor: CCD
Document Size: Statement to 11 x 17
Resolution: 600 x 600 dpi, 256 Gradations
Dimensions (H x W x D): Approx. 4.1 x 28.8 x 23.4
Weight: Approx. 38.5 lb.
Power Source: From Marking Engine
Output Options
Finishers Output Trays
Description
Finisher-AB1/Saddle Finisher-AB2
Paper Weights
Finisher: 17 lb. Bond to 110 lb. Cover
Saddle Finisher: 17 lb. Bond to 110 lb. Cover
Paper Size
Executive, Statement-R, Letter-R, Letter, Legal, 11 x 17
Sheet Stacking: Up to 13 x 19.2
Saddle Finisher: Letter-R, Legal, 11 x 17, 12 x 18
Number Of Trays
2 to 3
Top Tray
3,000 Sheets (20 lb. Bond)
Lower Tray
Saddle Stitch Tray
30 Booklets or Limitless
Staple Capacity
Up to 100 Sheets
Max. Booklet Stapling Capacity: Up to 20 Saddle-Stitched Sheets
Staple Positions
Corner Stapling, Double Stapling
Power Source
208V/15A
Dimensions
Approx. 46.5 x 31.5 x 31.2
Weight
Finisher: Approx. 278 lb.
Saddle Finisher: Approx. 392 lb. High-Capacity Stacker-C1
Offset Stack Capacity: 5,000 Sheets (20 lb. Bond)
Top Tray Capacity: 1,000 Sheets (20 lb. Bond)
Acceptable Paper Weight: 17 lb. Bond to 110 lb. Cover
Number of Units Connected at Once: Up to 2
Dimensions (H x W x D): Approx. 48.8 x 33.9 x 30.1
Weight: Approx. 440 lb.
Power Source: 115V/15A (Second Stacker Receives Power from First Stacker)Perfect Binder-B1
Cutting Method: Stack Rotation 3-Direction or 1-Direction Cut
Finished Book Size (After 3-Direction Cutting): 5.41 x 7.95 to 8.98 x 11.69
Book Thickness: 10 to 200 Sheets (20 lb. Bond)
Glue Warm-Up Time: 440 Seconds
Trim Range
Side: 26 to 1.56
Top and Bottom: 26 to 1.95
Dimensions (H x W x D): 53.5 x 36.3 x 31.1
Weight: Approx. 697 lb.
Power Source: 208V/15APuncher Unit-V1 (Option for Finisher/Saddle Finisher)
Punch Method: Press Punch System
Max. Paper Weight: 17 lb. Bond to 110 lb. Index
Paper Sizes
2-Hole: Legal, Letter-R
3-Hole: 11 x 17, Letter
Punch Speed: Up to 70 ppm (Depends on Speed of Marking Engine)
Power Source: From Finisher
Booklet Trimmers
Description
Booklet Trimmer-C1
Margin Trimming: Open-end Only
Trim Amount: 0.08 to 0.78
Trim Thickness: 40 Sheets
Waste Tray Capacity: 1,500 Sheets of Trimmed Strip
Output Tray Capacity: 30 Booklets
Dimensions (H x W x D): Approx. 40.9 x 62 x 30.3
Weight: Approx. 335 lb.
Document Inserters
Description
Document Insertion Unit-C1 (Opt.)
Paper Weight
Paper Sizes
Upper Tray: 7.2 x 7.2 to 11.6 x 13
Lower Tray: 7.2 x 7.2 to 13 x 19.2
Feeder Capacity
Upper Tray: 200 Sheets
Lower Tray: 200 Sheets
Dimensions (H x W x D): Approx. 8.4 x 24.6 x 26.3
Weight: Approx. 37.5 lb.
  • Click here to view the imagePRESS C7000VP Product Tour
  • Click here to view the Canon "Protecting Your Environment" In-Brief Video
Brochures
Loading...
 Return to Top
