Web Content Viewer
Actions
imagePRESS C65
Color Sheetfed Digital Presses
Workflow Solutions
Press For Success
Educational Guides for Production Printing Environments
Watch our Latest Testimonial and Product Videos Here!
Features
CV Toner
The CV Toner helps deliver graphic design quality by providing vibrant and highly consistent quality with a wide color gamut on a broad range of media.
R-VCSEL
State-of-the-art, 32-beam Red VCSEL laser achieves 2400 x 2400 dpi and outputs crisp, clear color images with remarkable clarity and definition at high speeds. It also features several halftone screen patterns for increased flexibility and optimized quality on various types of images.
Compact Registration Technology
With a compact design, the module helps achieves precise front-to-back registration for first time right output and maintain across the job.
Advanced ITB
Advance ITB helps achieve quality output on various types of media including media with rough surface such as textured media or envelopes.
Fast Output
With a start-up time of six minutes or less and a first-copy-out speed of under 7.7 seconds, the imagePRESS C65 is ready when you need it. Production speeds of up to 65 ipm on a wide range of media help keep you on track.
Calibration Tools
The imagePRESS C65 color digital presses offer automatic, real-time calibration and provide tools to help reduce calibration time to reliably deliver high-quality, repeatable, predictable output with minimal operator intervention.
Developer Unit
The developer uses internal air flow to maintain cool temperatures and vertical flow to efficiently use the developers which helps ensure stable color across the run.
Long Sheet Duplex Printing
Auto-duplex long sheet printing of up to 13” x 30” paper formats for proofs and design studies, for example 6-panel brochures, fold outs, dust jackets for books or larger packaging
In-line Finishing
Achieve “white-paper-in, finished-product out” workflows with Canon’s extensive in-line finishing options. Maintain high quality, even on half-folded spines with the in-line creasing feature of the optional Multi Function Professional Puncher
imagePRESS C65
MAIN ENGINE
TECHNOLOGY Electrophotography
RESOLUTION Up to 2400 x 2400 dpi
HALFTONES 256-Level Grayscale
PRINT SPEED (SIMPLEX / DUPLEX) 8.5" x 11": Up to 65 ipm
11" x 17": Up to 34 ipm
12" x 18": Up to 32 ipm
13" x 19": Up to 30 ipm
PAPER SIZE 3.94" x 5.83" to 13" x 19.2"
PAPER FEEDING
STANDARD Up to 1,650 Sheets (20 lb. Bond)
MAXIMUM Up to 7,650 Sheets (20 lb. Bond)
PAPER WEIGHT 14 lb. Bond to 110 lb. Cover (52 gsm to 300 gsm) Validated heavier stocks supported*
ENVELOPES** #10 Business, Monarch, 6" x 9", 9" x 12", 10" x 13"
DUPLEXING Automatic Duplex Any Supported Stock
POWER SOURCE Single-Phase 208 V/20 A
DIMENSIONS (H x W x D) 56.1" x 60.2" x 36.8"(Includes operator panel)
INPUT ACCESSORIES▪ ▪ ▪
MULTI-DRAWER PAPER DECK-C1
PAPER CAPACITY Up to 6,000 Sheets (20 lb. Bond)
PAPER SIZE 5.5" x 7.2" to 13" x 19.2"
DIMENSIONS (H x W x D) 40.9" x 37.4" x 31.4"
POWER SOURCE 120 V/15 A
POD DECK LITE-C1
PAPER CAPACITY Up to 3,500 Sheets (20 lb. Bond)
PAPER SIZE 5.5" x 5.83" to 13" x 19.2"
ENVELOPES** #10 Business, Monarch, 6" x 9",9" x 12", 10" x 13"
DIMENSIONS (H x W x D) 22.5" x 28.2" x 27.0"
STACK BYPASS-B1
PAPER CAPACITY Up to 100 Sheets (20 lb. Bond)
PAPER SIZE 3.94" x 5.83" to 13" x 19.2" (Long Sheet up to 30"†)
ENVELOPES #10 Business, Monarch, 6" x 9",9" x 12", 10" x 13"
DUPLEX COLOR IMAGE READER-K1
IMAGE SENSOR CCD
DOCUMENT SIZE Statement to 11" x 17"
RESOLUTION Up to 600 x 600 dpi, 256 Gradations
TRAY CAPACITY Up 300 Sheets (20 lb. Bond)
SCAN SPEED Up to 300 dpi / Up to 600 dpi
BW (duplex/simplex) Up to 200/120 ipm / Up to 120/120 ipm
Color (duplex/simplex) Up to 140/120 ipm / Up to 70/70 ipm
FINISHING ACCESSORIES▪ ▪ ▪
MULTIFUNCTION PROFESSIONAL PUNCHER-A1†††
PAPER WEIGHT
PLAIN 20 lb. Bond to 110 lb. Cover(75 gsm to 300 gsm)
COATED 20 lb. Bond to 110 lb. Cover(80 gsm to 300 gsm)
PAPER SIZE 12" x 18", 11" x 17", LTR, LGL, LTR-R, STMT
DIE SET PATTERNS Loose Leaf 3-Hole/5-Hole, Velo Bind, 11-Hole, Plastic Comb 19-Hole, Twin Loop, 21-Hole/32-Hole, Color Coil 44-Hole, Crease
DIMENSIONS (H x W x D) 40.9" x 17.5." x 31.2"
POWER SUPPLY 120 V/15 A
STAPLE FINISHER-W1 / BOOKLET FINISHER-W1
TRAY CAPACITY
TOP TRAY Up to 1,000 Sheets (20 lb. Bond)
LOWER TRAY Up to 4,000 Sheets (20 lb. Bond)
SADDLE-STITCH TRAY Up to 30 Booklets or Limitless
STAPLE POSITIONS Corner Stapling, Double Stapling
PAPER WEIGHT 14 lb. Cover to 110 lb. Cover(52 gsm to 300 gsm)
PAPER SIZE
STAPLING 11" x 17", LGL, LTR-R, EXEC, LTR,12" x 18", 13" x 19.2", Custom Size(8.3" x 11" to 13" x 19.2")
SADDLE FINISHER 11" x 17", LGL, LTR-R, 12" x 18",13" x 19", Custom Size (8.3" x 11" to 13" x 19.2")
STAPLING CAPACITY Up to 100 Sheets
BOOKLET STAPLING CAPACITY (20 LB. BOND)
UNCOATED Up to 25 Sheets
COATED Up to 10 Sheets
V-FOLDING Up to 5 Sheets without Stitch
STAPLE FINISHER 48.8" x 35.0" x 31.2"
BOOKLET FINISHER 48.8" x 41.7" x 31.2"
STAPLE FINISHER-T1 / BOOKLET FINISHER-T1
TRAY CAPACITY
ESCAPE TRAY Up to 250 Sheets (20 lb. Bond)
TOP TRAY Up to 1,300 Sheets (20 lb. Bond)
LOWER TRAY Up to 2,450 Sheets (20 lb. Bond)
SADDLE-STITCH TRAY Up to 25 Booklets
PAPER WEIGHT
TOP / LOWER TRAY 14 lb. Bond to 110 lb. Cover (52 to 300 gsm)
ESCAPE TRAY 14 lb. Bond to 140 lb. Index (52 to 256 gsm)
PAPER SIZE
STAPLING Executive, Letter-R, Letter, Legal, 11" x 17"
SADDLE-STITCHING Letter-R, Legal, 11" x 17", 12" x 18"
STAPLING CAPACITY Up to 50 Sheets
BOOKLET STAPLING CAPACITY Up to 16 Sheets
DIMENSIONS (H x W x D) 44.1" x 30.0" x 25.8"
CONSUMABLES
TONER T01 Toner
TONER YIELD (ESTIMATED @ 10% COVERAGE) Black: 44,500 Copies / Bottle
Color: 27,000 Copies / Bottle
FOOTNOTES
* For a list of validated stocks between 110 lb. Cover and 130 lb. Cover (301 gsm to 350 gsm), please consult the imagePRESS C850/C750/C65 Series Specialty Media Handling Guide. Engine cassettes support up to 80 lb. Cover (220 gsm).
** Requires Envelope Attachment Kit.
▪▪▪ Optional
† With optional Stack Bypass-C2 and Long Sheet Tray. Paper sizes longer than 19.2" can be fed one sheet at a time. †† Must connect to Staple Finisher-W1 or Booklet Finisher-W1
This is to make Misc appear on the page when needed.
Supplies
T01 Toner
Color: Black
Item Code: 8066B001AA
Estimated Toner Yield: 44,500 Copies/Bottle (Estimated @ 10% Coverage)
Color: Cyan
Item Code: 8067B001AA
Estimated Toner Yield: 27,000 Copies/Bottle (Estimated @ 10% Coverage)
Color: Magenta
Item Code: 8068B001AA
Color: Yellow
Item Code: 8069B001AA
Accessories
Hardware Accessories
  • Staple Finisher-W1
  • Booklet Finisher-W1
  • Copy Tray-R2
  • Puncher Unit-BS1
  • Puncher Unit-BT1
  • Multi Function Professional Puncher
  • Duplex Color Image Reader-K1
  • Stack Bypass-B1
  • Stack Bypass Tray-C2
  • Long Sheet Tray-B1
  • Multi Drawer Paper Deck-C1
  • POD Deck Lite-C1
  • Envelope Attachment Kit-F1
  • Envelope Attachment Kit-G1
  • Tab Attachment-F1
  • Staple Finisher-T1
  • Booklet Finisher-T1
  • External 2/3H Puncher-C1
Digital Front End Options
  • imagePRESS Server H300
  • imagePRESS Server G100
imagePRESS Server F200 Accessories
  • Removable Hard Drive
  • Graphic Arts Package, Premium Edition
  • Fiery Impose
  • Fiery Compose
  • Fiery Impose/Compose
  • Fiery Job Master
imagePRESS Server G100 Accessories
  • Fiery Productivity Package
  • Fiery Impose
  • Fiery Compose
System Connectivity Accessories
  • Web Access-H1
  • USB Device Port- A3
  • Remote Fax-A1
  • Multi Media Read/Write-A3
  • Send Advanced-G1E
  • Send Security-D1E
  • User Signature-C1E
  • Data Erase-C1E
  • Encrypted SP SW- D1E
  • AMS Kit-B1E
  • Voice Guidance-F2
  • 3.5 Inch/1 TB HDD-M1
  • HDD Encryption & Mirroring Kit-E2
  • Removable HDD Kit-AB2
Brochures
Loading...
 Return to Top
