Web Content Viewer
Actions
imagePRESS C650
Color Sheetfed Digital Presses
Watch our Latest Testimonial and Product Videos Here!
Features
  • High Quality, Even at High Speeds - Advanced Twin Belt Fusing unit enables a maximum speed of up to 65 letter-sized images per minute
  • Mixed Media - High-quality performance on mixed media jobs up to 110 lb. Cover and validated heavier stocks up to 130 lb. Cover*
  • Production Built - Can easily adapt to high-end office and CRD environments, thanks to its support of plain, coated, and heavy stocks; simple, on-the-fly replacement of toner; long-lasting parts; and an intuitive interface
  • Hard Working and Reliable - Designed to help print providers grow their business by delivering high uptime
  • Keep Work In-House - The productivity, quality, and media handling can help save enterprises time and money that would otherwise be spent on outsourcing print work
  • Integration With Output Management Solutions - Integrates with workflow solution options such as uniFLOW that provides the ability to carry out detailed tracking, reporting, and cost analysis
  • Automatic Color Correction - Helps ensure high color consistency and productivity with little or no manual labor when producing corporate colors and repeat jobs
  • Maintaining High Detail - Capable of generating a smaller laser dot than conventional infrared technology, the imagePRESS C650 can create high-definition images, leading to high-quality output
  • Eye-Catching Results - Delivered time after time with advanced technologies that help enable predictable color and high precision when printing images
imagePRESS C650
MAIN ENGINE
TECHNOLOGY Electrophotography
RESOLUTION Up to 2400 x 2400 dpi
HALFTONES 256-Level Grayscale
PRINT SPEED (SIMPLEX / DUPLEX)
8.5" x 11" Up to 65 ipm
11" x 17" Up to 34 ipm
12" x 18" Up to 32 ipm
13" x 19" Up to 30 ipm
PAPER SIZE 3.94" x 5.83" to 13" x 19.2"
PAPER FEEDING
STANDARD Up to 1,650 Sheets (20 lb. Bond)
MAXIMUM Up to 7,650 Sheets (20 lb. Bond)
PAPER WEIGHT 14 lb. Bond to 110 lb. Cover (52 gsm to 300 gsm)
Validated heavier stocks supported*
ENVELOPES** #10 Business, Monarch, 6" x 9", 9" x 12", 10" x 13"
DUPLEXING Automatic Duplex Any Supported Stock
POWER SOURCE Single-Phase 208 V/20 A
DIMENSIONS (H x W x D) 56.1" x 60.2" x 36.8"(Includes operator panel)
INPUT ACCESSORIES
MULTI-DRAWER PAPER DECK-C1
PAPER CAPACITY Up to 6,000 Sheets (20 lb. Bond)
PAPER SIZE 5.5" x 7.2" to 13" x 19.2"
DIMENSIONS (H x W x D) 40.9" x 37.4" x 31.4"
POD DECK LITE-C1
PAPER CAPACITY Up to 3,500 Sheets (20 lb. Bond)
PAPER SIZE 5.5" x 8.3" to 13" x 19.2"
DIMENSIONS (H x W x D) 22.5" x 28.2" x 27.0"
STACK BYPASS-B1
PAPER CAPACITY Up to 100 Sheets (20 lb. Bond)
PAPER SIZE 3.94" x 5.83" to 13" x 19.2" (Long Sheet up to 30"***)
ENVELOPES #10 Business, Monarch, 6" x 9",9" x 12", 10" x 13"
DUPLEX COLOR IMAGE READER-K1
IMAGE SENSOR CCD
DOCUMENT SIZE Statement to 11" x 17"
RESOLUTION Up to 600 x 600 dpi, 256 Gradations
TRAY CAPACITY Up 300 Sheets (20 lb. Bond)
SCAN SPEED Up to 300 dpi / Up to 600 dpi
BW (duplex/simplex) Up to 200/120 ipm / Up to 120/120 ipm
Color (duplex/simplex) Up to 140/120 ipm / Up to 70/70 ipm
FINISHING ACCESSORIES
STAPLE FINISHER-T1 / BOOKLET FINISHER-T1
TRAY CAPACITY
ESCAPE TRAY Up to 250 Sheets (20 lb. Bond)
TOP TRAY Up to 1,300 Sheets (20 lb. Bond)
LOWER TRAY Up to 2,450 Sheets (20 lb. Bond)
SADDLE-STITCH TRAY Up to 25 Booklets
STAPLE POSITIONS Corner Stapling, Double Stapling
PAPER WEIGHT
TOP / LOWER TRAY 14 lb. Bond to 110 lb. Cover (52 to 300 gsm)
ESCAPE TRAY 14 lb. Bond to 140 lb. Index (52 to 256 gsm)
PAPER SIZE
STAPLING Executive, Letter-R, Letter, Legal, 11" x 17"
SADDLE-STITCHING Letter-R, Legal, 11" x 17", 12" x 18"
STAPLING CAPACITY Up to 50 Sheets
BOOKLET STAPLING CAPACITY Up to 16 Sheets
DIMENSIONS (H x W x D) 44.1" x 30.0" x 25.8"
EXTERNAL 2/3-HOLE PUNCHER-C1
PUNCH TYPES
2 Holes: Legal, Letter-R
3 Holes: 11" x 17", Letter
PUNCH DISTANCE
2 Holes: 2.75" (70 mm)
3 Holes: 4.25" (108 mm)
DIMENSIONS (H X W X D)
32.5" x 4.2" x 24.2"
CONSUMABLES
TONER T01 Toner
TONER YIELD (ESTIMATED @ 8.5% COVERAGE) Black: 56, 000 Copies / Bottle
Color: 39, 500 Copies / Bottle
* For a list of validated stocks between 110 lb. Cover and 130 lb. Cover (301 gsm to 350 gsm), please consult the imagePRESS C850/C750/C650/C65 Series Specialty Media Handling Guide. Engine cassettes support up to 80 lb. Cover (220 gsm).
** Requires Envelope Attachment Kit.
*** With optional Stack Bypass-C2 and Long Sheet Tray. Paper sizes longer than 19.2" can be fed one sheet at a time.
This is to make Misc appear on the page when needed.
Supplies
T01 Toner
Color: Black
Item Code: 8066B001AA
Estimated Toner Yield: 56,000 Copies/Bottle (Estimated @ 8.5% Coverage)
Color: Cyan
Item Code: 8067B001AA
Estimated Toner Yield: 39,500 Copies/Bottle (Estimated @ 8.5% Coverage)
Color: Magenta
Item Code: 8068B001AA
Color: Yellow
Item Code: 8069B001AA
Accessories
Hardware Accessories
  • Copy Tray-R2
  • Duplex Color Image Reader-K1
  • Stack Bypass-B1
  • Stack Bypass Tray-C2
  • Long Sheet Tray-B1
  • Multi Drawer Paper Deck-C1
  • POD Deck Lite-C1
  • Envelope Attachment Kit-F1*
  • Envelope Attachment Kit-G1
  • Tab Attachment-F1*
  • Staple Finisher-T1
  • Booklet Finisher-T1
  • External 2/3H Puncher-C1
Digital Front End
  • imagePRESS Printer Kit (standard)
  • imagePRESS Server G100 (optional)
imagePRESS Server G100 Accessories
  • Fiery Productivity Package
  • Fiery Impose
  • Fiery Compose
  • Fiery Impose/Compose
  • Color Profiler Suite
System Connectivity Accessories
  • Web Access-H1
  • USB Device Port- A3
  • Remote Fax-A1
  • Multi Media Read/Write-A3
  • Send Advanced-G1E
  • Send Security-D1E
  • User Signature-C1E
  • Data Erase-C1E
  • Encrypted SP SW- D1E
  • AMS Kit-B1E
  • Voice Guidance-F2
  • 3.5 Inch/1 TB HDD-M1
  • HDD Encryption & Mirroring Kit-E2
  • Removable HDD Kit-AB2
  • Barcode Print Kit-D1
*One unit comes standard. Additional units are optional.
Brochures
Loading...
Videos
Canon Production Solution Case Study: Quantum Rehab
Canon Production Solutions Case Study: Hudson Printing
Canon Production Solutions Case Study: AJS Business Imaging Solutions
DISCLAIMERS
 Return to Top
