Web Content Viewer
Actions
imagePRESS C710CA
Color Sheetfed Digital Presses
Features
  • High-resolution imaging at 2400 x 2400 dpi with R-VCSEL laser technology
  • Produce vibrant images on a wide variety of media with translucent CV Toner
  • Consistent, stable output with automatic calibration for reproducible proofs and comps
  • Professional color matching tools for accurate simulations and predictable reproduction of colors
  • Precise registration with the Compact Registration Module
  • Attention-getting stock variety, including thick, thin, uncoated, coated, textured, and recycled, in weights up to 130 lb. Cover1
  • Canon's Gloss Optimization technology tailors the gloss level of the toner image so final output can give the true appearance of the media chosen for the desired creative expression
  • Up to 7,650-sheet feeding capacity2 with up to six different sources1
  • Array of optional in-line, post-processing accessories for the finishing touch of presentation pieces and samples
1. Optional accessories required.
  • Output speeds of up to 70 images per minute
  • Automatic duplexing on up to 130 lb. Cover1
  • Maintains rated speed on uncoated stocks up to 80 lb. Cover
  • Readily available with fast warm-up and first-print-out times
  • Fiery powered imagePRESS Server H350 and imagePRESS Server G250 deliver the quality performance studios demand
imagePRESS C710A
Print Speed (Simplex/Duplex)
8.5" x 11" Up to 70 ipm
11" x 17" Up to 35 ipm
12" x 18" Up to 35 ipm
13" x 19" Up to 33 ipm
13” x 30” Up to 19 ipm
Scan Speed (Letter, 300 dpi)1
BW Up to 230 opm
Color Up to 150 opm
Print Resolution Up to 2400 x 2400 dpi
Paper Capacity2
Standard Up to 1,650 sheets
Maximum3 Up to 7,650 sheets
Paper Size
Standard 3.94" x 5.83" to 13" x 19.2"
Optional 3.94" x 5.83" to 13" x 51.2"
Paper Weight
Standard 14 lb. Bond to 110 lb. Cover
Optional 14 lb. Bond to 130 lb. Cover
Automatic Duplexing
Media Size Up to 13" x 30"
Media Weight Up to 130 lb. Cover
Envelopes #10 Business, Monarch, DL, ISO-C5, 6" x 9", 9" x 12", 10" x 13
Print Servers imagePRESS Server H350
imagePRESS Server H250
Canon Printer Board
Consumables
Toner T01 Toner
Toner Yield (ESTIMATED @ 8.5% COVERAGE) Black: 56,000 / Color: 39,5000 Images
FOOTNOTES
  1. Optional
  2. Capacity based on 20 lb. Bond
  3. Multi Drawer Paper Deck required
This is to make Misc appear on the page when needed.
Supplies
T01 Toner
Color: Black
Item Code: 8066B001AA
Estimated Toner Yield: 56,000 Copies/Bottle (Estimated @ 8.5% Coverage)
Color: Cyan
Item Code: 8067B001AA
Estimated Toner Yield: 39,500 Copies/Bottle (Estimated @ 8.5% Coverage
Color: Magenta
Item Code: 8068B001AA
Estimated Toner Yield: 39,500 Copies/Bottle (Estimated @ 8.5% Coverage)
Color: Yellow
Item Code: 8069B001AA
Accessories
Hardware Accessories
  • Duplex Color Image Reader-M1
  • Printer Cover-H1
  • Stack Bypass-C1
  • Stack Bypass Tray-D1
  • Long Sheet Tray-B1
  • Envelope Attachment-F1
  • Envelope Attachment-G1
  • Tab Attachment-F1
  • POD Deck Lite-C1
  • POD Deck Lite XL-A1
  • Multi Drawer Paper Deck-C1
  • Copy Tray-R2
  • Document Insertion Unit-N1
  • Multi Function Professional Puncher Unit-B1
  • Paper Folding Unit-J1
  • Staple Finisher-AC1
  • Booklet Finisher-AC1
  • Jogger Kit-A1
  • 2/3 Hole Puncher-A1
  • Staple Finisher-W1
  • Booklet Finisher-W1
  • Puncher Unit-BS1
  • Long Sheet Tray-C1
Digital Front End
  • imagePRESS Printer Kit
  • imagePRESS Server G250
  • imagePRESS Server H350
imagePRESS Server G250 Accessories
  • Productivity Package
  • Fiery Impose
  • Fiery Compose
  • Fiery Color Profiler Suite
  • X-Rite i1Pro2 Spectrophotometer
imagePRESS Server H350 Accessories
  • Graphics Art Package, Premium Edition
  • Removable HDD Kit
  • Fiery Impose
  • Fiery Compose
  • Fiery Job Master
  • Fiery Job Flow
  • Integrated Interface & Stand
System Connectivity Accessories
  • Web Access-H1
  • USB Device Port- A3
  • Remote Fax-A1
  • Multi Media Read/Write-A3
  • Send Advanced-G1E
  • Send Security-D1E
  • User Signature-C1E
  • Data Erase-C1E
  • Encrypted SP SW- D1E
  • AMS Kit-B1E
  • Voice Guidance-F2
  • 3.5 Inch/1 TB HDD-M1
  • HDD Encryption & Mirroring Kit-E3
  • Removable HDD Kit-AB2
  • Barcode Print Kit-D1
Brochures
Loading...
White Papers
Digital Printing: Where We Are Now?
Beyond the Press: Defining the Infrastructure for Operational Success
Optimizing Color Across Print Platforms
The Rise of the Digital Print Enhancement Opportunity
Best Practices in Digital Finishing
 Return to Top
