Web Content Viewer
Actions
imagePRESS C750
Color Sheetfed Digital Presses
Press For Success
Educational Guides for Production Printing Environments
BLI 2017 PRO AWARD
Workflow Solutions
prisma workflow solutions
Features
Vibrant and Consistent Image Quality
R-VCSEL Laser Scanner Unit
State-of-the-art, 32-beam Red VCSEL laser achieves 2400 x 2400 dpi and outputs crisp, clear color images with remarkable clarity and definition at high speeds. It also features various halftone screen patterns for increased flexibility and optimized quality closer to offset to deliver the required quality the most demanding environments.
Consistently Vivid (CV) Toner
The CV Toner improves transfer efficiency and provides consistent, quality output on a wide variety of media.
Advanced Image Transfer Belt (ITB)
Advance ITB helps achieve quality output on various types of media including media with rough surface such as textured media or envelopes.
Outstanding Stability
Calibration Tools
The imagePRESS C750 color digital presses offer automatic, real-time calibration and provide tools to help reduce calibration time to reliably deliver high-quality, repeatable, predictable output with minimal operator intervention.
Developer Unit
The developer uses internal air flow to maintain cool temperatures and vertical flow to efficiently use the developers which helps ensure stable color across the run.
Compact Registration Technology
With a compact design, the module helps achieves precise front-to-back registration for first time right output and maintain across the job.
Media Versatility
Long Sheet Duplex Printing
Auto-duplex long sheet printing of up to 13" x 30" paper formats to offer applications such as 6 panel brochures and dust jackets.
In-line Finishing
Achieve "white-paper-in, finished-product out" workflows with Canon's extensive in-line finishing options. Maintain high quality, even on half-folded spines with the in-line creasing feature of the optional Multi Function Professional Puncher*
* Not available at initial launch.
Maximized Uptime
Advanced Twin Belt Fusing
Induction heating and cooling technologies use two belts that allow the press to fuse at a lower temperature which helps the press to be kept productive on regular and mixed media jobs while controlling gloss and image quality.
Large Media Capacity
Maximum of up to 7,650-sheet input capacity with the Multi Drawer Paper Deck allows for unattended production runs. And with up to six different sources, operators can load many different media types for mixed-media jobs.
On-the-fly replacement
Keep the press running and maintain a steady workflow with the ability to replace paper, toner, and trim waste with the new Booklet Trimmer-F1 during a print run.
imagePRESS C750
MAIN ENGINE
TECHNOLOGY Electrophotography
RESOLUTION Up to 2400 x 2400 dpi
HALFTONES 256-Level Grayscale
PRINT SPEED (SIMPLEX / DUPLEX)
8.5" x 11" Up to 75 ipm
11" x 17" Up to 37 ipm
12" x 18" Up to 35 ipm
13" x 19" Up to 33 ipm
PAPER SIZE 3.94" x 5.83" to 13" x 19.2"
PAPER FEEDING
STANDARD Up to 1,650 Sheets (20 lb. Bond)
MAXIMUM Up to 7,650 Sheets (20 lb. Bond)
PAPER WEIGHT 14 lb. Bond to 110 lb. Cover (52 gsm to 300 gsm) Validated heavier stocks supported*
ENVELOPES** #10 Business, Monarch, 6" x 9", 9" x 12", 10" x 13"
DUPLEXING Automatic Duplex Any Supported Stock
POWER SOURCE Single-Phase 208 V/20 A
DIMENSIONS (H x W x D) 56.1" x 60.2" x 36.8"(Includes operator panel)
INPUT ACCESSORIES▪ ▪ ▪
MULTI-DRAWER PAPER DECK-C1
PAPER CAPACITY Up to 6,000 Sheets (20 lb. Bond)
PAPER SIZE 5.5" x 7.2" to 13" x 19.2"
DIMENSIONS (H x W x D) 40.9" x 37.4" x 31.4"
POWER SOURCE 120 V/15 A
STACK BYPASS-B1
PAPER CAPACITY Up to 100 Sheets (20 lb. Bond)
PAPER SIZE 3.94" x 5.83" to 13" x 19.2" (Long Sheet up to 30"***)
ENVELOPES #10 Business, Monarch, 6" x 9",9" x 12", 10" x 13"
DUPLEX COLOR IMAGE READER-K1
IMAGE SENSOR CCD
DOCUMENT SIZE Statement to 11" x 17"
RESOLUTION Up to 600 x 600 dpi, 256 Gradations
TRAY CAPACITY Up 300 Sheets (20 lb. Bond)
SCAN SPEED Up to 300 dpi / Up to 600 dpi
BW (duplex/simplex) Up to 200/120 ipm / Up to 120/120 ipm
Color (duplex/simplex) Up to 140/120 ipm / Up to 70/70 ipm
FINISHING ACCESSORIES
MULTIFUNCTION PROFESSIONAL PUNCHER-A1
PAPER WEIGHT
PLAIN 20 lb. Bond to 110 lb. Cover(75 gsm to 300 gsm)
COATED 20 lb. Bond to 110 lb. Cover(80 gsm to 300 gsm)
PAPER SIZE 12" x 18", 11" x 17", LTR, LGL, LTR-R, STMT
DIE SET PATTERNS Loose Leaf 3-Hole/5-Hole, Velo Bind, 11-Hole, Plastic Comb 19-Hole, Twin Loop, 21-Hole/32-Hole, Color Coil 44-Hole, Crease
DIMENSIONS (H x W x D) 40.9" x 17.5." x 31.2"
POWER SUPPLY 120 V/15 A
HIGH-CAPACITY STACKER-H1
OFFSET STACK CAPACITY Up to 6,000 Sheets (20 lb. Bond)
TOP TRAY CAPACITY Up to 200 Sheets (20 lb. Bond)
PAPER SIZE 7.2" x 7.2" to 13" x 19.2"
PAPER WEIGHT 14 lb. Bond to 110 lb. Cover(52 gsm to 300 gsm)
MAX. CONNECTIVITY 1 Unit
DIMENSIONS (H x W x D) 40.9" x 35.4" x 29.3"
STAPLE FINISHER-W1 / BOOKLET FINISHER-W1
TRAY CAPACITY
TOP TRAY Up to 1,000 Sheets (20 lb. Bond)
LOWER TRAY Up to 4,000 Sheets (20 lb. Bond)
SADDLE-STITCH TRAY Up to 30 Booklets or Limitless
STAPLE POSITIONS Corner Stapling, Double Stapling
PAPER WEIGHT 14 lb. Cover to 110 lb. Cover(52 gsm to 300 gsm)
PAPER SIZE
STAPLING 11" x 17", LGL, LTR-R, EXEC, LTR,12" x 18", 13" x 19.2", Custom Size(8.3" x 11" to 13" x 19.2")
SADDLE FINISHER 11" x 17", LGL, LTR-R, 12" x 18",13" x 19", Custom Size (8.3" x 11" to 13" x 19.2")
STAPLING CAPACITY Up to 100 Sheets
BOOKLET STAPLING CAPACITY (20 LB. BOND)
UNCOATED Up to 25 Sheets
COATED< Up to 10 Sheets
V-FOLDING Up to 5 Sheets without Stitch
STAPLE FINISHER 48.8" x 35.0" x 31.2"
BOOKLET FINISHER 48.8" x 41.7" x 31.2"
STAPLE FINISHER-T1 / BOOKLET FINISHER-T1
TRAY CAPACITY
ESCAPE TRAY Up to 250 Sheets (20 lb. Bond)
TOP TRAY Up to 1,300 Sheets (20 lb. Bond)
LOWER TRAY Up to 2,450 Sheets (20 lb. Bond)
SADDLE-STITCH TRAY Up to 25 Booklets
PAPER WEIGHT
TOP / LOWER TRAY 14 lb. Bond to 110 lb. Cover (52 to 300 gsm)
ESCAPE TRAY 14 lb. Bond to 140 lb. Index (52 to 256 gsm)
PAPER SIZE
STAPLING Executive, Letter-R, Letter, Legal, 11" x 17"
SADDLE-STITCHING Letter-R, Legal, 11" x 17", 12" x 18"
STAPLING CAPACITY Up to 50 Sheets
BOOKLET STAPLING CAPACITY Up to 16 Sheets
DIMENSIONS (H x W x D) 44.1" x 30.0" x 25.8"
PERFECT BINDER-E1
CUTTING METHOD 3-Side Cut/1-Side Cut/No Cut
FINISHED BOOK SIZE 5.4" x 7.99" to 8.5" x 11.69"
BOOK THICKNESS 10 to 200 Sheets (20 lb. Bond) (up to 0.98")
BODY PAPER WEIGHT 14 lb. Bond to 43 lb. Bond(52 gsm to 163 gsm)
COVER PAPER WEIGHT 28 lb. Bond to 110 lb. Cover(90 gsm to 300 gsm)
TRIM RANGE
TOP/BOTTOM 0.26" to 1.56"
SIDE 0.26" to 1.95"
DIMENSIONS (H x W x D) 53.5" x 36.3" x 31.1"
POWER SOURCE 208 V/15 A
BOOKLET TRIMMER-F1
MARGIN TRIMMING Front-edge Trim
TRIM AMOUNT 0.08" to 1.1"
TRIM THICKNESS 50 Sheets
OUTPUT TRAY CAPACITY 30 Booklets
DIMENSIONS (H x W x D) 40.9" x 62.1" x 30.3"
TWO-KNIFE BOOKLET TRIMMER-A1▲▲
MARGIN TRIMMING Top and Bottom
TRIM AMOUNT 0.08" to 0.59"
DIMENSIONS (H x W x D) 40.9" x 21.1" x 30.3"
PUNCHER UNIT-BS1 (OPTION FOR STAPLE FINISHER-W1 / BOOKLET FINISHER-W1
PAPER SIZES
2-Hole Legal, Letter-R, Custom Size(7.2" x 7.2" to 11.7" x 17")
3-Hole 11" x 17", Letter, Executive-R, Custom Size (9.4" x 7.2" to 11.7" x 17")
DOCUMENT INSERTION UNIT-N1
TRAY CAPACITY
UPPER TRAY Up to 200 Sheets (20 lb. Bond)
LOWER TRAY Up to 200 Sheets (20 lb. Bond)
PAPER SIZE 11" x 17", 12" x 18", 13" x 19", LGL, LTR, LTR-R, EXEC, Custom Size (7.2" x 7.2" to 13" x 19.2")
PAPER FOLDING UNIT-J1
DOUBLE PARALLEL FOLD Legal, Letter-R
C/ACCORDION FOLD Letter-R
Z-FOLD 11" x 17"
SUPPORTED MEDIA
WEIGHTS 14 lb. Bond to 28 lb. Bond(50 gsm to 105 gsm)
POWER SOURCE From Finisher
DIMENSIONS (H x W x D) 46.87" x 13.25" x 31.25"
WEIGHT 157 lb. (71 kg)
CONSUMABLES
TONER T01 Toner
TONER YIELD (ESTIMATED @ 8.5% COVERAGE) Black: 56, 000 Copies / Bottle
Color: 39, 500 Copies / Bottle
FOOTNOTES
* For a list of validated stocks between 110 lb. Cover and 130 lb. Cover (301 gsm to 350 gsm), please consult the imagePRESS C850/C750/C65 Series Specialty Media Handling Guide. Engine cassettes support up to 80 lb. Cover (220 gsm).
** Requires Envelope Attachment Kit.
*** With optional Stack Bypass-C2 and Long Sheet Tray. Paper sizes longer than 19.2" can be fed one sheet at a time.
▲ Must connect to Booklet Finisher-W1.
▲▲ Must connect to Booklet Trimmer-F1.
This is to make Misc appear on the page when needed.
Supplies
T01 Toner
Color: Black
Item Code: 8066B001AA
Estimated Toner Yield: 56,000 Copies/Bottle (Estimated @ 8.5% Coverage)
Color: Cyan
Item Code: 8067B001AA
Estimated Toner Yield: 39,500 Copies/Bottle (Estimated @ 8.5% Coverage)
Color: Magenta
Item Code: 8068B001AA
Color: Yellow
Item Code: 8069B001AA
Accessories
Hardware Accessories
  • Staple Finisher-W1
  • Booklet Finisher-W1
  • Copy Tray-R2
  • Puncher Unit-BS1
  • Puncher Unit-BT1
  • Multi Function Professional Puncher*
  • Perfect Binder-E1
  • Paper Folding Unit-J1
  • Booklet Trimmer-F1
  • 2-Knife Trimmer-A1
  • Document Insertion Unit-N1
  • Duplex Color Image Reader-K1
  • Stack Bypass-B1
  • Stack Bypass Tray-C2
  • Long Sheet Tray-B1
  • Multi Drawer Paper Deck-C1
  • POD Deck Lite-C1
  • Envelope Attachment Kit-F1
  • Envelope Attachment Kit-G1
  • Tab Attachment-F1
  • High-Capacity Stacker-H1
  • SDD BLM300C Professional Booklet Maker
  • MAX Ring Binder MB-1000C
  • Staple Finisher-T1
  • Booklet Finisher-T1
  • External 2/3H Puncher-C1
  • Plockmatic BLM50/35 Professional Booklet Maker
  • Square Fold Booklet-Maker
  • Square Fold Booklet-Maker With Two-Knife Trimmer
Digital Front End Options
  • PRISMAsync Controller for imagePRESS C850/C750
  • imagePRESS Server H300
  • imagePRESS Server G100
  • imagePRESS Printer Kit
PRISMAsync Controller Accessories
  • E-Shredding-G1
  • Integrity Checker-G1
  • DP Link-G1
  • Fontset Japanese-G1
  • Fontset Korean-G1
  • Fontset Simplified Chinese-G1
  • Fontset Traditional Chinese-G1
imagePRESS Server H300 Accessories
  • Removable Hard Drive
  • Graphic Arts Package, Premium Edition
  • Fiery Impose
  • Fiery Compose
  • Fiery Impose/Compose
  • Fiery Job Master
imagePRESS Server G100 Accessories
  • Fiery Productivity Package
  • Fiery Impose
  • Fiery Compose
System Connectivity Accessories
  • Web Access-H1
  • USB Device Port- A3
  • Remote Fax-A1
  • Multi Media Read/Write-A3
  • Send Advanced-G1E
  • Send Security-D1E
  • User Signature-C1E
  • Data Erase-C1E
  • Encrypted SP SW- D1E
  • AMS Kit-B1E
  • Voice Guidance-F2
  • 3.5 Inch/1 TB HDD-M1
  • HDD Encryption & Mirroring Kit-E2
  • Removable HDD Kit-AB2
*Not Available at initial launch
Brochures
Loading...
Videos
Canon Production Solution Case Study: Quantum Rehab
Canon Production Solutions Case Study: Hudson Printing
Canon Production Solutions Case Study: AJS Business Imaging Solutions
Videos
Canon imagePRESS C850 Series Overview
 Return to Top
