Web Content Viewer
Actions
imagePRESS V1000
Color Sheetfed Digital Presses
Specifications
Model Name
imagePRESS V1000
Printing Resolution
2400 x 2400 dpi
Print Speed (BW/Color)
Letter
Up to 101 ipm
11” x 17”
Up to 52 ipm
12” x 18”
Up to 50 ipm
13” x 19”
Up to 50 ipm
13'' x 30''
Up to 28 ipm
Copy Specifications
Maximum Original Size
Standard 3.9'' x 5.8'' to 13'' x 19.2''
Optional 5.5'' x 7.2'' to 13'' x 51.2''
Standard Paper Capacity
Up to 1,100 Sheets
Maximum Up to 11,100 Sheets
Acceptable Paper Weights
Cassette
Standard 14 lb. Bond to 110 lb. Cover
Optional 14 lb. Bond to 150 lb. Cover
Duplexing
Paper Weight
Standard: 14 lb. Bond to 110 lb. Cover
Optional: 14 lb. Bond to 150 lb. Cover
Paper Size
Standard 3.9'' x 5.8'' to 13'' x 19.2”
Supplies
T11 Toner
Color: Black
Item Code: 5146C001AA
Estimated Toner Yield: 56,000 Copies/Bottle (Estimated @ 8.5% Coverage)
Color: Cyan
Item Code: 5147C001AA
Estimated Toner Yield: 39,500 Copies/Bottle (Estimated @ 8.5% Coverage
Color: Magenta
Item Code: 5148C001AA
Estimated Toner Yield: 39,500 Copies/Bottle (Estimated @ 8.5% Coverage)
Color: Yellow
Item Code: 5149C001AA
Accessories
Hardware Accessories
  • Duplex Color Image Reader-P1
  • Printer Cover-P1
  • ADF Access Handle-A1
  • POD Deck Lite-C1
  • POD Deck Lite XL-A2
  • Multi Drawer Paper Deck-E1
  • Stack Bypass-D1
  • Stack Bypass Tray-D1
  • Long Sheet Feeding and Catch Tray-B1
  • Tab Attachment-F1
  • Envelope Attachment-F1
  • Envelope Attachment-G1
  • Envelope Attachment-H1
  • Inspection Unit-B1
  • Sensing Unit-B1
  • Document Insertion Unit-R1
  • Multi Function Professional Puncher Unit-C1
  • GBC eWire Pro
  • Perfect Binder-F1
  • Perfect Binder Continuous Kit-B1
  • High Capacity Stacker-J1
  • HCS Long Sheet Tray-A1
  • PowerLift-A1
  • Paper Folding Unit-K1
  • Staple Finisher-AF1
  • Saddle Finisher-AF1
  • Long Sheet Tray-C1
  • Long Sheet Catch Tray XL-B1
  • Puncher Unit-BS1
  • Booklet Trimmer-G1
  • Two-Knife Booklet Trimmer-B1
  • DFD Adapter and Finisher Bridge-B1
  • DFD Adapter-B1
  • Finisher Bridge-A1
  • Plockmatic Multi Purpose Stacker
  • SDD Square Fold Booklet Maker
  • SDD Square Fold Booklet Maker with Two Knife Trim
  • Plockmatic BLM50/35 Professional Booklet Maker
Digital Front Ends
  • imagePRESS Server D3000
  • PRISMAsync Print Server
imagePRESS Server D3000 Accessories
  • Graphic Arts Pro Package
  • Removable HDD Kit
  • Fiery Impose
  • Fiery Compose
  • Fiery Job Master
  • Fiery Job Flow
  • Fiery Color Profiler Suite
  • Integrated Interface & Stand- NX GL
  • Integrated Interface & Stand- NX LS
PRISMAsync Print Server Accessories
  • E-Shredding
  • Advanced Imposition-H1
  • DP Link
This is to make Misc appear on the page when needed.
Brochures
Loading...
Videos
Introducing the Canon imagePRESS V1000
 Return to Top
