Web Content Viewer
Actions
Océ VarioPrint i300
Color Sheetfed Digital Presses
Océ VarioPrint i300 Introduction
Graph Expo 2016 MUST SEE 'EM Winner
Workflow Solutions
prisma workflow solutions
Features
  • Océ iQuarius technologies empower high-speed, sheet-fed inkjet versatility:
  • iQuarius proprietary CMYK inks provide outstanding quality and productivity with a broad color gamut, print robustness, and media compatibility at low inkjet cost.
  • Optional Magnetic Ink Character Recognition (MICR) integrated print heads to support both high-volume color inkjet printing and MICR applications on a singleplatform.
  • Sheet Entry Control via the Sentry unit provides full-speed automated detection of any paper deformations that could lead to a print head touch, purging sheets without interrupting production.
  • Precision Sheet Control is provided by a seamless metal belt that holds inkjet imaged sheets flat with air suction, helping move them smoothly, precisely and at high speed through the press.
  • An iQuarius Drying System uses four distinct drying principles at once: induction-heated drum; carbon infrared radiation (CIR); air impingement; and air suction - producing a high-quality, robust printed product.
  • An Inline Quality Control system prints a test/nozzle failure detection sheet at regular intervals (operator configurable) and scans it in-line applying compensation when needed, automatically to help maintain quality.
  • Print head technology from the industry leading Océ ColorStream delivers up to 80 million drops per second while providing precision imaging at 600 x 600 dpi with multilevel drop size modulation for image quality with the visual perception of 1,200 dpi.
  • Media input and output technologies from the market proven Océ VarioPrint 6000+ series provides reliable, high-performance feeding with air separation and suction feeding along with seamless tray switching and true "all media from all trays" capability*.
  • Proven PRISMAsync controller platform offers intuitive operation and intelligent media management helping drive maximum productivity. PRISMAsync handles native PDF and IPDS/AFP data input and combined with Océ PRISMA workflow software it enables workflow alignment within the shop for maximum efficiency and productivity.
  • Auto-maintenance routines including automatic print head refresh modes and print head maintenance during operation help maintain optimal quality and productivity while helping reduce operator intervention.
  • "Sense and Support" predictive maintenance helps to minimize operator intervention and maximize uptime.
This is to make Misc appear on the page when needed.
Specifications
MAIN UNIT
Main Engine
Printer Type:
Sheetfed color inkjet press
Technology:
Drop-on-demand piezoelectric inkjet technology
Ink:
iQuarius aqueous pigment inks
Colors:
CMYK standard; MICR Optional
Print Resolution:
600 x 600 dpi, with drop size modulation (up to 5 sizes)
Monthly Target Volume:
1 to 10 Million letter images
Maximum Print Speed (ipm):
Duplex printing/simplex printing
Letter (8.5" x 11"):
294 ipm / 147 ipm
Ledger (11" x 17"):
150 ipm / 80 ipm
Tabloid Extra (12" x 18"):
142 ipm / 76 ipm
Max (13.9" x 19.7"):
132 ipm / 70 ipm
Paper Size*:
Minimum:
8" x 8"
Maximum:
12.6" x 19.2"
Optional Support:
Statement size (7" x 10")
13.9" x 19.7"**
Maximum Imageable Area:
12.7" x 19.5"
Print Distance from Edge:
.08" (2 mm) from each edge
Paper Weight*:
40lb Offset to 110lb Cover (60-300 gsm)***
Substrates:
Offset uncoated, Offset coated, Inkjet treated, Inkjet pigmented and Inkjet coated
Paper Input
Maximum 3 PIM, any combination PIM or PIM-XL****
Paper Input Module (PIM)
Paper Feeding Technology:
Air Separation, Suction Feeding, Paper Conditioning
Capacity:
4,600 Sheets (20 lb. Bond)
Tray 1 and 2:
Tray 3 and 4:
1,700 Sheets Standard (20 lb bond)
Maximum:
13,800 sheets (3 x 4600 20 lb. bond)
Paper Sizes (all trays):
8" x 8" to 12.6" x 19.2"
Dimensions (H x W x D):
37.2" x 30.3" x 23.5" (1150 mm x 922 mm x 716mm)
Weight:
485lbs (220kg)
Paper Input Module (PIM XL)
Air Separation, Suction Feeding, Paper conditioning
Capacity:
Tray 1 and 2:
Tray 3 and 4:
Maximum:
Paper Sizes:
Tray 1:
Tray 2,3, and 4:
13.9" x 19.7" (Fixed)
Weight:
485lbs (220kg)
Paper Output
High-Capacity Stacker
Main Trays:
6,000 Sheets(2 Stacks x 3,000 Sheets - 20 lb. Bond)
Top Tray:
200 Sheets
Maximum 2 High-Capacity Stackers:
12,000 Sheets
DFD Interface (Optional):
For Integration with Third-party Finishing
34.1" x29.5" x 24.4" (1040mm x 899mm x 745mm)
With tray ejected:
34.1" x 41.0" x 24.4" (1040mm x1250mm x 745mm)
Weight:
265 lbs. (120 kg)
Environment
Temperature:
Optimal range 68°-79° F (20° to 26° C)
Relative Humidity:
Optimal range 30-50% RH
Atmospheric Pressure Range:
840-1,060mbar (maximum altitude 5,000 ft. (1500m) above sea level)
Noise Emissions:
Operation:
73 dB
Standby:
61dB
Electrical Requirements
Power Consumption
During Printing:
< 50 kW
Print Operation Management
PRISMAsync Controller
Server Type:
External
Operating System:
Windows 7
RIP Clients:
2 Standard (Up to 2 Optional, 4 Max)
Supported PDLs:
Document Printing:
PDF 1.7, Extension Level 3 (for Acrobat 9); PDF/X (APPE 3.2 RIP support)
Variable Data Printing:
PDF/VT (Level 1)
Transactional Printing:
Native IPDS (IS/3 compliant; APPE 3.1 for PDF color management in transaction mode)
Standard License Bundle:
1 x PDL (PDF or IPDS); Scheduler; Remote Viewer; Trapping; Streaming; Accounting; Hot Folders; Remote Service; E-shredding; Advanced Color Management
Optional Licenses:
Additional PDL (PDF or IPDS); PDF for IPDS
PRISMA Workflow Modules (optional):
Océ PRISMAproduction
Océ PRISMAprepare
Network Connectivity:
2 x 10 gigabit Ethernet (10/100/1000 Base T), TCP/IP (LPR/LPD,9100 Socket,SMB),Static IP/Auto IP (DHCP), IPv4, IPv6 (only in Document Printing mode)
Protocols:
SNMP v1, SNMP v3, Host Resources MIB, MIB II, Printer MIB, Job Monitoring MIB, Job Management MIB
Physical Data
Physical Data
1 PIM/1 HCS
Dimensions (H x W X D):
7.5' x 30.5' x 9.2' (2.3 m x 9.3m x 2.8 m)
Minimal Space Required (service clearance):
Floor Space (W x D):
34.8' x 21.3' (10.5 m x 6.5 m)
Height:
9.8' (3 m)
Volume:
7239.5 ft3 (205 m3)
Weight:
17,968 lbs (8150 kg)
Maximum Floor Load (Point load):
12N/mm2 or 1,740 psi
* Paper size and weight specifications apply for PIM, Main Engine and HCS
** Requires PIM XL option
*** Supported media weight depends on used media.
**** 2nd PIM Optional
Supplies and Accessories
Supplies
  • VarioPrint i-Series Ink Cyan
  • VarioPrint i-Series Ink Magenta
  • VarioPrint i-Series Ink Yellow
  • VarioPrint i-Series Ink Black
Hardware Accessories
  • Paper Input Module
  • Paper Input Module XL
  • 7", 10", statement size support
  • Power Lift
Brochures
Loading...
Videos
Océ iQuarius Technologies
 Return to Top
