Web Content Viewer
Actions
LX-P1300
Inkjet Label Printers
Item Code: 0659C002AA
To request more information about this product, click here!
Features
High-Quality Labels
With the Canon LX-P1300 2" Pigment-Based Inkjet Label Printer there is no need for pre-printed inventory labels. Utilizing a pigment-based inkjet printing system, you can quickly and easily produce affordable color labels that can help improve your organization efficiencies through visibility and identification. The pigment-based ink offers more durability and a higher weather resistance for your color labels. These inks won't run, smudge or fade away when used with inkjet compatible media. Pigment inks may not be as vibrant as dye-based inks but pigment inks produce labels that are far more durable.
Fast Performance for Increased Productivity
The LX-P1300 is a compact label printer not only built for high-quality labels but also for fast performance. When you have large multi-batch and different label jobs, you need a printer that can keep up and get the job done fast, and the LX-P1300 is ready when you are with a first label print out time of just 10 seconds.1 The Canon LX-P1300 2" label printer produces labels with a resolution as high as 1200 dpi, that means Labels with small barcodes, a high-information density, and even small icons can be produced clear and easy to ready for more accurate identification and error-free scans. The LX-P1300 also has an auto cutter unit built-in, that allows a label to be cut at set intervals, so they can be used immediately after printing.
Less Waste with Increased Security
Inkjet label printers are simply more efficient than thermal ribbon printers by how they use ink. While thermal transfer ribbons use an entire area of ribbon, including the parts which are not used, Inkjet printing is efficient and only uses ink on the parts to be printed. Not only is this more efficient by reduces waste, but it allows for faster print speeds allowing for increased productivity.
Regardless of the size and design of the label, thermal ribbon printing consumes the ribbon even if sections aren't used or printed on. Because Inkjet label printers only use the necessary ink for each the label size and design, it is more economical and reduces waste.Moreover, since the printed information will not be recorded on ribbons, it keeps sensitive information safe, whereas thermal ribbons need to be discarded which can leave customer, client and company information exposed.
Specifications
Printer
Printing Method
Pigment-based Inkjet
Print Speed (up to)
First Print Out Time: 2 x 3 Label: 10 seconds or less1
Default Print Speed: 120 mm/second (4.7 inches/second)1
Range: 50 - 120 mm/s1
Preset Options: 120, 80, 70, 60, 50 mm/s
Number of Nozzles
2,816 dots
Print Resolution (Up to)
1200x1200 dpi
Ink Compatibility
4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow)
Paper Sizes
Width: 28.4 - 63.0 mm (Including Liner)#60;br/> Length: 25.4 - 400.0 mm (Including Liner)
Maximum Printable Area
Width: 56.0 mm
Length: 397.0 mm
Minimum Margin
Top/Bottom Margin: 1.5 mm
Left/Right Margin: 3.5 mm
Paper Thickness
0.145 - 0.255 mm
Paper Compatibility
Label Roll Media with Roll Holder (IJ Coated: Matte or Glossy)
Roll Paper Maximum Outer Diameter
Outer Diameter: Up to 75 mm, Core/Inner Diameter: Up to 25.4 m
Body Durability
300,000 Sheets / 5 Years2
Estimated Output Number
Approx. 2,000 Sheets per cartridge set2
General
OS Compatibility
Windows 10 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit)3
Standard Interface
USB 2.0
Ethernet (10/100/1000Base-T)
Power Source
AC 100-240v, 50/60 Hz
Power Consumption (approx.)
Operating /Maximum: Approx. 22.0 W (Average)
Sleep Mode: Approx. 6.0 W or Less
Dimension (W x D x H)
5.3 (W) x 9.8 (D) x 9.8 (H)
Weight
11.02 lbs.
Operating Temperature:
Temperature: 41° - 95°F (5° - 35°C)
Operating Humidity:
Humidity: 10-90% RH (Non-Condensing)
Noise
Acoustic Information
Operating Noise (Max.): 50dB or less4
Standby Noise: 30dB or less4
Warranty
1 Year Warranty5
Auto Cutter Unit
Built-In
Cartridge Fill Volume
Black / Cyan / Magenta / Yellow: 14.5 ml
Maintenance Cartridge Info & Fill Volume
WT-X201 Maintenance Cartridge2
Approx. 24,000 Sheets2
Operational Method
LCD: No
Buttons/LEDs: 2 Buttons / 7 LEDs
Optional Hardware Module
RH-L02 Roll Holder
Certifications/Standards
RoHS Compliance
Canon LX-P1300 2" Dye-Based Inkjet Label Printer
Canon LX-P1300 2" Dye-Based Inkjet Label Printer Canon LX-P1300 2" Dye-Based Inkjet Label Printer Ink Cartridge Set (BK,C,M,Y, 14.5 ml/each) Power Cord Maintenance Cartridge (Installed) Printer Driver/User Guide CD Getting Started Guide Warranty Card
DISCLAIMERS
  1. Print speeds may vary depending on system configuration, interface, software, print complexity, print mode, page coverage, type of paper used, etc. Excludes pre-cleaning.
  2. Based upon standard print conditions and print size print size of 2"x3" inkjet coated matte label, 7.5% Duty/Color, 50 sheets x4 jobs/day, excludes manual cleaning.
  3. Operation can only be guaranteed on a PC with pre-installed Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit.
  4. Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
  5. Warranty and Support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  6. Printer weight measured excluding ink cartridges installed.
 Return to Top
