Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
LX-D5500 Inkjet Label Printer
Label Printers
Canon Store: $
LX-D5500 is compatible with Bartender.
4” Label Printer for High-Quality, Fast Performance & Versatility
The Canon LX-D5500 4" Dye-based Inkjet Label Printer is built for improved productivity, high quality output, and increased security. There is no need to spend time, money, and storage space on pre-printed product, information, and logistic labels. The Canon LX-D5500 4" Dye-based Inkjet label printer provides increased productivity and flexibility, higher-quality labels with fast performance, and less waste with increased security.
Product Core Features:
- Ideal For: Product Labels, Distribution/Logistic Labels, Retail Inventory and Warehouses
- Dye-Based Inkjet for colorful and vivid prints
- Print up to 4" Wide Labels in matte or glossy using Roll or Fan Folded Media
- Fast Print Speed: 7.9 Inches per Second1
- High 1200 x 1200 DPI Print Resolution
- Up to 200mm Roll Capacity
Supported Media & Ink Benefits:
- 4" Wide Labels in matte or glossy using Roll or Fan Folded Media
Ideal for:
- Product Labels
- Distribution & Logistic Labels
- Retail Inventory Labels
- Warehouses Labels
Features
On-Demand Label Printing with Increased Productivity and Flexibility
The Canon LX-D5500 4" Dye-based Inkjet Label Printer can use both blank roll paper and fanfold paper, and it supports a variety of paper such as matte paper and glossy paper. This allows specific labels to be created for the correct application at the same time. There is no need to keep multiple types of pre-printed labels in inventory since you are able to print only what is needed for each task - this eliminates the need to store preprinted label inventory- saving valuable office space, as well as a reduction in individual label costs.
With Inkjet printing you can individually create labels that are specific to each product or task. For example, this means that items can have color coded inventory labels, allowing items to be retrieved faster since it has an increased visibility to improve operational efficiencies.
High-Quality and Fast Performance
The Canon LX-D5500 4" Dye-based Inkjet Label Printer is capable of 1200 x 1200 dpi High-resolution printing and fast print speeds of up to 200mm per second.1 High-resolution printing allows for the sharp reproduction of high-density bar codes and small text, that allows for more accurate, faster scanning and identification that is consistently clear. The LX-D5500 is an Inkjet Label Printer that utilizes dye-based ink. Dye-based ink is ideal for creating brilliant and expressive labels that can capture a customer's attention and make your products stand out. The colors are brighter and more vivid than pigment inks, and the blacks they produce can be much deeper. The LX-D5500 4" Dye-Based Inkjet label printer can give you professional print quality for all your on-demand labels. This helps your sales team and customers, allowing for the ability to print on demand eye-catching product, information and promotional labels. Also, since it can handle labels with a minimum length of 6 mm to a large label of 500 mm, it is possible to create a wide range of specific labels for various applications and industries.
Less Waste with Increased Security
Inkjet label printers are simply more efficient than thermal ribbon printers by how they use ink. While thermal transfer ribbons use an entire area of ribbon, including the parts which are not used, Inkjet printing is efficient and only uses ink on the parts to be printed. Not only is this more efficient by reducing waste, but it allows for faster print speeds allowing for increased productivity.
Regardless of the size and design of the label, thermal ribbon printing consumes the ribbon even if sections aren't used or printed on. Because Inkjet label printers only use the necessary ink for each the label size and design, it is more economical and reduces waste. Moreover, since the printed information will not be recorded on ribbons, it keeps sensitive information safe, whereas thermal ribbons need to be discarded which can leave customer, client and company information exposed.
Specifications
Printer
Printing Method
Print Speed (up to)
Default Print Speed: 200 mm/second (7.9 inches/second)
Range: 50 - 200 mm/s
Preset Options: 200 mm/s, 160 mm/s, 120 mm/s, 100 mm/s, 90 mm/s, 80 mm/s, 70 mm/s, 60 mm/s, 50 mm/s
Number of Nozzles
Print Resolution (Up to)
Ink Compatibility
Paper Sizes
Length: 6.0 - 500 mm (Including Liner)
Maximum Printable Area
Length: 3.0 - 397 mm (with AIS On)
Minimum Margin
Left/Right: 2.7 mm (with AIS On)
Paper Thickness
Paper Compatibility
Roll Paper Maximum Outer Diameter
Fanfold Media: Media Height: Up to 850 mm
Body Durability
Estimated Output Number
General
OS Compatibility
Standard Interface
Ethernet (10/100/1000Base-T)
RS-232C (For External Devices)
Power Source
Power Consumption (approx.)
Operating: Approx. 21 W
Sleep Mode: Approx. 8 W or Less
Dimension (W x D x H)
Weight
Operating Temperature:
Operating Humidity:
Noise
Operating Noise (Max.): 55dB or less4
Standby Noise: 35dB or less4
Warranty
Cartridge Fill Volume
Maintenance Cartridge Info & Fill Volume
Operational Method
Buttons/LEDs: 4 Buttons / 8 LEDs
Optional Hardware Module
RH-L03 Roll Holder
LX-D5500 Box Contents
Brochures
DISCLAIMERS
- Print speeds may vary depending on system configuration, interface, software, print complexity, print mode, page coverage, type of paper used, etc. Excludes pre-cleaning.
- Based upon standard print conditions and print size of 4"x3" inkjet coated matte label, 7.5% Duty/Color, 100 sheets x 50 jobs/day, excluding manual cleaning.
- Operation can only be guaranteed on a PC with pre-installed Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit), or Windows Server 2012 (64-bit)/2008 (64-bit).
- Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
- Warranty and Support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
- Printer weight measured excluding print head or ink cartridges installed.
