Web Content Viewer
Actions
varioPRINT 135/120/110
Monochrome Sheetfed Digital Presses
Workflow Solutions
Watch our Latest Testimonial and Product Videos Here!
Features
  • Océ DirectPress Technology provides uniform, stable and high print quality, consistently, by eliminating unstable variables such as charge,static and light.
  • Océ HeatXchange technology reduces energy consumption through clever reuse of energy, which provides for a smaller footprint and helps eliminate bricking, without the use of additional cooling.
  • Océ EnergyLogic technology helps provide maximum performance without sacrificing quality by efficiently using available energy. The result is a fast first print out time and optimal production of mixed media jobs.
  • Océ ScreenPoint® Technology for superb image quality and automated smooth grayscale reproduction from all files, black and white or color.
  • PRISMAsync's intuitive workflow and easy to learn user interface offers immediate control and management of the most complex jobs.
  • Intelligent scheduler for plan-ahead production and more efficient productivity.
  • Perfect-fit system that provides speed, input, in-line finishing and workflow configured to your needs.
  • A media based workflow combined with Océ Paper Logic® technology helps ensure first-time-right output.
  • Unique sustainability features - no ozone emissions, selenium, fuser oil or developer, and virtually no toner waste or particle emissions as well as reduced energy consumption, and EPA Energy Star rated with one of the lowest TEC (Typical Electricity Consumption) value in its class.
This is to make Misc appear on the page when needed.
Specifications
Model Name
Type
DirectPress
Printing Resolution
Engine: 600 x 2400 dpi / 200lpi
PCL: 600 x 600 dpi
Adobe PostScript 3: 600 x 2400 dpi, 1200 x 1200 dpi (Enhanced)
Letter
(Simplex / Duplex:) 120/110/100 ipm / 135/120/110 ipm
Ledger
(Simplex / Duplex:) 63/57/52 ipm / 70/63/57 ipm
First Copy Time
3.9 seconds
Maximum Original Size
12.6 x 19.2 (320 x 488 mm)
Standard Paper Capacity
4000 sheets (80 gsm)
Trays 1 & 2: 1500 sheets (Ltr, Statement**)
Tray 3: 500 sheets from 5.5 x 7.17 (140x 182mm) to 12.6 x 17 (320 x 432 mm)
Tray 4: 500 sheets from 5.5 x 7.17 (140 x 182 mm) to 12.6 x 19.2 (320 x 488 mm)Feeding Technology (iPIM - internal Paper Input Module): Roller fed 14 lb. bond - 110 lb. cover (50-300 gsm)
Acceptable Paper Weights
Duplexing
Up to 300 gsm
Power Requirements
208V/20A
Dimension
56.3 x 44.5 x 30.1
(1430mm x 1130mm x 765mm)
Weight
579.8 (263 kg)
Estimated Toner Yield
96,000 / per 2 bottles*
Feeders
Description
Color Image Reader (Single-pass Duplex Automatic Document Feeder and Black & White/Color Scanner)
Acceptable Originals
Statement, Letter, Legal, 11 x 17, Custom Sizes ADF: 5.5 x 5.04 (140 x 128mm) to 17 x 12 (432 x 305 mm)
Scanning Speed
BW/Color: Up to 120 ipm (300 x 300 dpi)
BW: Up to 100 ipm (600 x 600 dpi)
Color: Up to 105 ipm (600 x 300 dpi)
Up to 25 ipm (600 x 600 dpi)
Capacity
300 sheets (20 lb. bond)
Power Source
From main unit
Paper Supply Options
Description
ePIM (external Paper Input Module)
Paper Capacity
8,000 sheets with Duo Tray Option, (4,600 Standard)
Paper Sizes
8 x 8 (203 x 203 mm) to 12.6 x 19.2 (320 x 488 mm)
Paper Weights
14 lb. bond - 110 lb. cover (50-300 gsm)Feeding Technology: Air Separation, Suction Feeding
Power Source
120V/15A
Dimensions
40.9 x 38.6 x 29.5
(1040mm x 980mm x 750mm)
Weight
440.9 lbs (200 kg)
Description
Document Insertion Unit-F1 (Optional)
Paper Capacity
400 Sheets (200 x 2) (20 lb. Bond)
Paper Sizes
13 x 19.2
Paper Weights
14 lb. Bond to 110 lb. Cover (50gsm to 300gsm)
Power Source
120V/15A
Dimensions
55.37 x 29.37 x 31.25
(1407mm x 746mm x 793mm)
Weight
134 lb. (61kg)
Output Options
Finishers Output Trays
Description
Finisher-AK1/Saddle Finisher-AK2 (Optional)
Paper Weights
Saddle Finisher: 14 lb. Bond to 110 lb. Cover (50gsm to 300gsm)
Paper Size
Stapling: Executive, Letter-R, Letter, Legal, 11 x 17, Custom Size (8.26 x 7.16 to 11.69 x 17)
Sheet Stacking: Up to 13 x 19.2
Saddle Finisher: Letter-R, Legal, 11 x 17, 12 x 18, custom sizes 8.26 x 11 - 13 x 19.2
Number Of Trays
2/3
Top Tray
Up to 1,000 Sheets (20 lb. Bond)
Lower Tray
Up to 4 ,000 Sheets (20 lb. Bond)
Saddle Stitch Tray
30 Booklets or Limitless
Staple Capacity
Up to 100 Sheets (Letter (20lb), Maximum)
Booklet Stapling Capacity: Up to 25 Sheets, Saddle-Stitched
Staple Positions
Corner-Stapling, Double-Stapling
Power Source
120V/15A
Dimensions
Finisher: 48.75 x 31.5 x 31.25 (1239mm x 800mm x 792mm) / 48.75 x 35.4 x 31.25 (1239mm x 890mm x 792mm) (When the Extension Tray is Pulled Out)Saddle Finisher: 48.75 x 31.5 x 31.25 (1239mm x 800mm x 792mm) / 48.75 x 41.75 x 31.25 (1239mm x 1060mm x 792mm) (When the Extension Tray is Pulled Out)
Weight
Finisher: 287 lb. (130kg)
Saddle Finisher: 397 lb. (180kg)
Paper Folding
Description
Paper Folding Unit-F1 (Optional)
Paper Weight
14 lb. Bond to 28 lb. Bond (50gsm to 105gsm)
Fold Type
Double Parallel Fold: Legal, Letter-R
C/Accordion Fold: Letter-R
Z-fold: 11 x 17
Power Source: From Finisher
Dimensions (H x W x D): 46.87 x 13.25 x 31.25 (1190mm x 336mm x 793mm)
Weight: 157 lb. (71kg) Puncher Unit-BS1: (Option for Finisher-AF1/Saddle Finisher-AF2)
Paper Weight: 14 lb. Bond to 73 lb. Cover (50gsm to 200gsm)
Paper Sizes2-Hole: Legal, Letter-R, Custom / 3-Hole: 11 x 17, Letter, Executive, Custom
Punch Speed: Up to Speed of Marking Engine
Weight: 6.7 lb. (3kg)
Power Source: From Finisher-AK1/Saddle Finisher-AK2
Offset Stack Capacity: 10,000 Sheets (Letter) (20 lb. Bond)
Top Tray Capacity: 1,000 Sheets (20 lb. Bond)
Maximum Paper Size: 13 x 19.2
Paper Weight: 14 lb. Bond to 110 lb. Cover (50gsm to 300gsm)
Max. Connectivity: Up to 2 Units at Once
Dimensions (H x W x D): 53.62 x 39.25 x 31.25 (1362mm x 997mm x 792mm)
Weight: 463 lb. (210kg)
Power Source: 120V/15A
High-Capacity Stacker-G1 (Optional)
Offset Stack Capacity: 6,000 Sheets†† (20 lb. Bond)
Top Tray Capacity: 200 Sheets (20 lb. Bond)
Maximum Paper Size: 13" x 19.2"
Dimensions (H x W x D): 40.9" x 35.4" x 29.3" (1040mm x 899mm x 745mm)
Weight: 396.8 lb. (180kg)
Booklet Trimmer-D1 (Optional)
Margin Trimming: Fore-Edge Trim
Trim Amount: 0.08 to 0.78 (2mm to 20mm)
Trim Thickness: 100 Sheets
Waste Tray Capacity: 1,500 Sheets with 0.78 Trim(20 lb. Bond)
Output Tray Capacity: 30 Booklets
Dimensions (H x W x D): 41 x 62 x 30.37 (1040mm x 1575mm x 770mm)
Weight: 335 lb. (152kg)
Power Source: From Saddle Finisher-AK2 Two-Knife Trimmer-A1 (Optional)
Margin Trimming: Top and Bottom Trim
Trim Amount: 0.08 to 0.59 (2mm to 15mm)
Waste Tray Capacity: 750 Sheets (Two-Sided Trimmed)
Dimensions (H x W x D): 41 x 21.12 x 30.37 (1040mm x 536mm x 770mm)
Weight: 319 lb. (145kg)
Power Source: 120V/15A Professional Puncher-B1 and Integration Unit-A1 (Optional)
Paper Size: Letter, Tab
Supported Media Weights: 20 lb. Bond to 80 lb. Cover (75gsm to 216gsm)
Productivity: Up to Speed of Marking Engine
Chip Tray Capacity: 25,000 Sheets
Punch Patterns: 3H, 5H, Velo Bind 11H, Plastic Comb19H, Twin Loop 21H/32H, ProClick 32H, Color Coil 44H
Dimensions (H x W x D): 41" x 22.5" x 31.25" (1040mm x 560mm x 792mm)
Weight: 264 lb. (120kg) * Estimated yield based on Letter pages at 6% coverage.
** Requires bulk tray small format option.
Specifications subject to change without notice.
Supplies
Canon varioPRINT DP Toner
Color: Black
Item Code: 6117B005AA
Estimate Toner Yield: 96,000 Copies/2 Bottles (Estimated yield at 6.5% Coverage)
Accessories
Hardware Accessories
  •  External Paper Input Module-C1
  •  Duo Paper Tray Kit C1
  •  Form Assist Module II
  •  Finisher-AK1
  • Saddle Finisher-AK2
  • Puncher Unit-BS1
  • High Capacity Stacker-E1
  • Stacker Dolly-C1
  • High Capacity Stacker-G1
  • Powerlift for High Capacity Stacker-F1/G1
  • Document Insertion Unit-F1
  • Paper Folding Unit-F1
  • Professional Puncher-B1 (Includes Integration Unit-A1)
  • Booklet Trimmer-D1
  • Two-Knife Booklet Trimmer-A1
  • SDD Square Fold Booklet Maker
  • SDD Square Fold Booklet Maker with Two Knife Trimmer
  • SDD BLM-300C Booklet Maker
  • Decurler Unit-A1
  • Max Ring Binder MB-1000C
  • Bulk Tray small format – A1
  • Copy Control Device-C1
  • Operator Attention Light-C1
  • Removable HDD Kit-C1
  • Section 508-1-C1
  • Section 508-2-C1
  • Convenience Stapler-A1
PRISMAsync Accessories Doc Box-C1
  • Color scan to file/e-mail-C1
  • Remote User Interface-C1
  • Multiple Queue-C1
  • Streaming-C1
  • Accounting-C1
  • E-shredding-C1
  • DP Link-C1
  • KDK Link-C1
  • Microsoft XPS Standard Speed-C1
  • Microsoft XPS High Speed-C1
  • Chinese Simple PS3 Fonts-C1
  • Chinese Trade PS3 Fonts-C1
  • Japanese PS3 Fonts-C1
  • Korean PS3 Fonts-C1
Brochures
Loading...
Videos
  • Click here to view the Canon "Protecting Your Environment" In-Brief Video
 Return to Top
