Web Content Viewer
Actions
varioPRINT 6000 TITAN Series
Monochrome Sheetfed Digital Presses
Workflow Solutions
Educational Guides for Production Printing Environments
Watch our Latest Testimonial and Product Videos Here!
Features
Four print speed models to meet various production printing requirements: varioPRINT 63301/varioPRINT 6270/varioPRINT 6220/varioPRINT 6180
Speed when you need it with optional field upgradeable speed licenses (temporary or permanent)
Integral Productivity
Gemini Instant Duplex Technology's ultra high-volume duplex printing performance combines with the PRISMAsync Print Server to boost production efficiency - providing up to 8 hours of job scheduling and remote management tools for workflow automation. Vast paper input capacity of up to 24,000 Letter size sheets2 offers hours of unattended printing providing the ability to do more.
Innovation-driven quality
Gemini Instant Duplex Technology's simultaneous double-sided black and white printing helps ensures near-perfect front to back registration, while Copy Press and ScreenPoint Technologies deliver a sharp, elegant, matte print output.
Application latitude
Capable of printing on media as light as 30 lb. Text (45 gsm) and sizes up to 13.8" x 19.7" ( 350 mm x 500 mm), the varioPRINT 6000 TITAN monochrome digital presses expand the range of applications supported by sheetfed digital black and white printing.
Sustainability beacon
Generates low ozone emissions and heat output, as well as virtually no toner waste
This is to make Misc appear on the page when needed.
MAIN UNIT SPECS
IMAGING TECHNOLOGY Copy Press and Gemini Instant Duplex Technology
PRINT SPEED 63301/6270/6220/6180
Up to 320/266/216/177 (Letter)
Up to 167/143/116/95 (Ledger)
MONTHLY DUTY CYCLE varioPRINT 6330 Up to 10 Million
varioPRINT 6270 Up to 8 Million
varioPRINT 6220 Up to 5 Million
varioPRINT 6180 Up to 2.5 Million
ENGINE RESOLUTION LED, 600 x 1200 dpi, 85/106/125/141/180 lpi
MAXIMUM PAPER CAPACITY Standard 4,600
Maximum 24,0002
PAPER SIZE
Standard
Maximum: 12.6" x 19.2" (320 mm x 488 mm)
Minimum: 8" x 8" (203 mm x 203 mm)
Optional: 7" x 10" (178 mm x 254 mm) with Statement-sized option
With PIM Flex-A1
Maximum: 13.8" x 19.7" (350 mm x 500 mm)
Minimum: 8" x 8.2" (203 mm x 208 mm)
PAPER WEIGHT Plain Paper: 13 lb. Bond to 110 lb. Cover (50 to 300 gsm)
Coated Media: 20 lb. Bond to 90 lb. Cover3 (80 to 250 gsm)
Light-Weight Media: 12lb Bond to 13 lb Bond (45 - 50 gsm) with the optional light-weight media module
PRINT SERVER PRISMAsync Print Server varioPRINT 6000
Accessories
Optional Hardware Accessories
  • Paper Input Module (Up to 3) – standard size or PIM FLEX-A1
  • High Capacity Stacker 2.1 with Top Cover (Up to 3 including one with Set Finisher)
  • High Capacity Stacker 2.1 with Set Finisher (Max 1)
  • Powerlift for iHCS (includes 5 pallets)
  • Media Enhancement Module
  • Form Assist Module II
  • Statement Size (7x10"option)
  • Copy Control Interface
  • DFS 30-N Tape Binder
  • SDD BLM 6200 Booklet Maker
  • Plockmatic BLM 550+ Booklet Maker
  • SDD BLM 6300 Booklet Maker
  • GBC Power Punch
  • Tecnau SheetFeeder VarioPrint 6000
  • SDD BGB3202 Perfect Binder
Brochures
Loading...
White Papers
Digital Printing: Where We Are Now?
Beyond the Press: Defining the Infrastructure for Operational Success
Optimizing Color Across Print Platforms
The Rise of the Digital Print Enhancement Opportunity
Best Practices in Digital Finishing
DISCLAIMERS
1. varioPRINT 6330 speed model available only in TITAN standard and TP TITAN models.
2. Maximum capacity of Letter-sized sheets based on 3 Paper Input Module (PIM) configuration including Duo Tray in all supported trays.
 Return to Top
