Web Content Viewer
Actions
imagePRESS 1110+
Monochrome Sheetfed Digital Presses
Workflow Solutions
Features
  • Twin Sleeve Development:
    A dual sleeve design that delivers toner to the photoreceptive drum. This design produces blacks that are solid and avoids uneven distribution of toner.
  • ITB:
    The image transfer belt is responsible for transferring the latent image to the media. This is similar to how an offset blanket work on a offset lithographic press. The advantage is with this design it is possible to run thick stocks without the concern the stock will jam in the engine.
  • Multiple Pick Points:
    It's feasible to have up to 13 pick points with this engine. Up to 3 POD decks can be integrated, as well as one Multi Insertion unit that has 3 pick points. This configuration is beneficial for those customers that run complex jobs which would include multiple call trays for different types of papers, tabs, covers and pre-printed color inserts.
  • Paper Handling:
    The imagePRESS 1135+/1110+ has enhanced air assist technologies to ensure the reliable feeding for all medias. The suction feeding, enhanced air assist and air separation technologies provide reliable feeding and maximum productivity.
  • Image Quality:
    With 1200 X 1200 dpi imaging technology, produce near lithographic halftone images, crisp text, full solids that are free from mottle and fine lines.
  • Accurate Registration:
    With a tolerance of +/-0.5mm, the imagePRESS 1135+/1110+ produces a professional looking product that is correctly aligned from front to back.
  • Media Versatility:
    The imagePRESS 1135+/1125+/1110+ has the advantage of being able to print accurately on thin and thick stocks. This press can print on the stocks as thin as 14lb. bond and as thick as 110lb. cover.
  • Durability:
    This engine was designed with longevity in mind. The photoreceptive developing drum is composed of a very durable Amorphous Silicon, also known as a-Si. This material has a long life span of 6 million impressions.
  • Productivity:
    The imagePRESS 1135+/1110+ prints at rated speed on all uncoated LTR media. Regardless if you're printing on a 28lb. (LTR) bond media or a thick 110lb. (LTR) cover, the engine will print without a decrease in speed.
This is to make Misc appear on the page when needed.
Specifications
Model Name
imagePRESS 1110+
Imaging System
Laser Electrostatic Transfer System
Printing Resolution
Up to 1200 x 1200 dpi
Halftone
256-Level Grayscale
Letter
Simplex: 110
Duplex/Perfect: 55
Ledger
Simplex: 68
Duplex/Perfect: 34
Maximum Original Size
13 x 19.2
Standard Paper Capacity
2,000 Sheets (20 lb. Bond)
Acceptable Paper Weights
Cassette
Uncoated: 14 lb. Bond to 110 lb. Bond Cover
Coated: 24 lb. Bond to 90 lb. Cover
Duplexing
Automatic Duplex/Perfect
Any Supported Stock
Power Requirements
208V/30A+208V/15A
Dimension
(H x W x D): 54.12 x 54.62 x 31.87
Weight
1,103 lb.
Estimated Toner Yield
69,000 impressions at 6% coverage (LTR pgs)
Feeders
Description
Color Image Reader-L1 (Opt.) (Includes DADF (Duplex Automatic Document Feeder)
Acceptable Originals
Statement to 11 x 17
Resolution: Up to 600 x 600 dpi, 256 Gradations
Scanning Speed
B/W: Up to 200 ipm (300 dpi)
Up to 120 ipm (600 dpi)
Color: Up to 80 ipm (300 dpi)
Up to 40 ipm (600 dpi)*
Capacity
300 sheets (20 lb. Bond)
Paper Weights
14 lb. Bond to 120 lb. Index
Power Source
From Main Unit
Dimensions
(H x W x D): 7.12 x 23.25 x 25
Weight
81.6 lb.
Paper Supply Options
Description
POD Deck-C1 (Std.)
Paper Capacity
4,000 Sheets (1,000 x 2 + 2,000) (20 lb. Bond)
Paper Sizes
13 x 19.2
Paper Weights
Uncoated: 14 lb. Bond to 110 lb. Bond Cover (All Trays)
Coated: 24 lb. Bond to 90 lb. Cover (All Trays)
Power Source
120-127VAC, 60Hz, 15A
Dimensions
43.12 x 29.37 x 31.25
Weight
499 lb.
Description
POD Deck-C1 and Secondary POD Deck-C1 (Opt.)***
Paper Capacity
Paper Sizes
13 x 19.2
Paper Weights
Power Source
120-127VAC, 60Hz, 15A x (2)
Dimensions
43.12 x 61.5 x 31.25
Weight
997 lb.
Description
POD Deck-C1 & Sec. POD Deck-C1 (2) (Opt) ***
Paper Capacity
Paper Sizes
13 x 19.2
Paper Weights
Dimensions
43.12 x 93.62 x 31.25
Weight
1,495 lb.⟩
Output Options
Finishers Output Trays
Description
Finisher-AF1/Saddle Finisher-AF2 (Opt.)
Paper Weights
Finisher: 14 lb. Bond to 110 lb. Cover
Saddle Finisher: 14 lb. Bond to 110 lb. Cover
Paper Size
Stapling: Executive, Letter-R, Letter, Legal, 11 x 17
Sheet Stacking: Up to 13 x 19.2
Saddle Finisher: Letter-R, Legal, 11 x 17, 12 x 18, 13 x 19
Number Of Trays
2/3
Top Tray
Up to 3,000 Sheets (20 lb. Bond)
Lower Tray
2,000 (20 lb. Bond)
Saddle Stitch Tray
30 Booklets or Limitless
Staple Positions
Corner-Stapling, Double-Stapling
Stapling Capacity
Up to 100 Sheets (LTR)
Max. Booklet Stapling Capacity: Up to 25 Sheets Saddle-Stitched (20 lb. only)
Power Source
120V/15A
Dimensions
46.5 x 31.25 x 35.37
Weight
Finisher: 287 lb.
Saddle Finisher: 396 lb. Puncher Unit-BB1 (Option for Finisher-AF1/Saddle Finisher-AF2)
Acceptable Paper Weight: 14 lb. Bond to 73 lb. Cover
Paper Sizes
2-Hole: Legal, Letter-R
3-Hole: 11 x 17, Letter, EXE
Punch Speed: Up to 135 ppm (Depends on Speed of Marking Engine)
Weight: 6.7 lb.
Power Source: From Finisher High-Capacity Stacker-E1 (Opt.)♦♦
Offset Stack Capacity: 10,000 Sheets (Letter) (20 lb. Bond)
Top Tray Capacity: 1,000 Sheets (20 lb. Bond)
Maximum Paper Size: 13 x 19.2
Acceptable Paper Weight: 14 lb. Bond to 110 lb. Cover
Number of Units Connected at Once: Up to 2
Dimensions (H x W x D): 53.62 x 39.25 x 31.25
Weight: 463 lb.
Power Source: 120V/15ATwo-Knife Trimmer-A1 (Opt.)
Margin Trimming: Top and Bottom Trim
Trim Amount: 0.08 to 0.59
Trim Thickness: 100 Sheets
Waste Tray Capacity: 750 Sheets (Two-Sided Trimmed)
Output Tray Capacity: 30 Booklets
Dimensions (H x W x D): 21.12 x 30.37 x 41
Weight: 319 lb.
Booklet Trimmers
Description
Booklet Trimmer-D1 (Opt.)
Sheet Capacity
Waste Tray Capacity: 1,500 Sheets (With 0.78 Trim, 20 lb. Bond)
Margin Trimming: Fore-Edge Trim
Trim Amount: 0.08 to 0.78
Dimensions (H x W x D): 41 x 62 x 30.37
Weight: 335 lb.
Power Source: From Saddle Finisher Perfect Binder-C1 (Opt.)
Cutting Method: Stack Rotation 3-Direction or 1-Direction Cut
Finished Book Size
Width: 8 to 11.62
Length: 5.37 to 8.5
Body Paper Weight: 14 lb. Bond to 90 lb. Index
Cover Weight: 24 lb. Bond to 110 lb. Cover
Book Thickness: 10 to 200 Sheets
Glue Warm-Up Time: 440 Seconds
Trim Range: Adjustable in .0197 (0.5mm) Increments
Side: 0.26 to 1.94
Top and Bottom: 0.52 to 3.11
Dimensions (H x W x D): 51.25 x 36.97 x 31.12
Weight: 674.6 lb.
Power Source: 208V/15A
Document Inserters
Description
Multi-Drawer Document Insertion Unit-A1 (Opt.)
Paper Weight
Paper Sizes
13 x 19.2
Feeder Capacity
Dimensions (H x W x D): 43.12 x 42.5 x 31.25
Weight: 554 lb.
Power Source: 120V/15AProfessional Puncher and Integration Unit-B1 (Opt.)
Paper Size: Letter, Tab
Supported Media Weights: 20 lb. Bond to 80 lb. Cover
Productivity: Up to 135 ppm (Depends on Speed of Marking Engine)
Chip Tray Capacity: 25,000 Sheets
Punch Patterns: 3H, 5H, Velo Bind 11H, Plastic Comb, 19H, Twin Loop 21H/32H, ProClick 32H, Color Coil 44H
Dimensions (H x W x D): 41 x 22.5 x 31.25
Weight: 258.5 lb.
Paper Folding
Description
Paper Folding Unit-F1 (Opt.)♦♦♦
Fold Type
Z-fold: 11 x 17, Legal, Letter-R
C/V/Accordian Fold: Letter-R
Parallel double Fold: Letter-R, Legal
Supported Media Weights: 14 lb. Bond to 28 lb. Bond
Dimensions (H x W x D): 46.87 x 13.25 x 31.25
Weight: 157 lb.* System Upgrade RAM-B1 required for 600 dpi color scanning
** Combined weight of the POD Deck-C1 and Secondary POD Deck-C1
*** Requires either the imagePRESS 1135+ or the imagePRESS 1125+ to connect three (3) POD Decks. Combined weight of the POD Deck-C1 and Secondary POD.
⟩ Deck-C1 (2)
♦ 890mm when the extension tray is pulled out for Saddle Finisher-AF1. 1060mm when the extension tray is pulled out for Saddle Finisher-AF2.
♦♦ Only one additional High Capacity Stacker-E1 attaches to the imagePRESS 1110+.
♦♦♦ Requires either the Finisher-AF1 or the Saddle Finisher-AF2.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imagePRESS 1110+ that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Supplies
IPQ- 4 Toner
Color: Black
Item Code: 2784B003AA
Estimated Toner Yield: 69,000 Copies/Bottle  (Estimated yield at 6% Coverage)
Brochures
Loading...
 Return to Top
