Web Content Viewer
Actions
Océ PRISMAaccess
Workflow Solutions
Benefits
  • Improve customer satisfaction by making it easier to do business with you.
  • Expand your service offering and grow your business.
  • Customizable job tickets eliminates job requirement confusion, improves customer satisfaction and results in fewer outsourced jobs.
  • Simplified pre-flighting improves production turn-around time.
  • Improved control over production processes and costs.
  • Improves ROI through a scalable, flexible configuration offering end-to-end job management, and automation of workflow steps all based on open market standard Adobe Acrobat PDF.
This is to make Misc appear on the page when needed.
HARDWARE
  • CENTRAL SERVER
  • WEB SERVER
  • Oce PRISMAaccess Archive Module and Remote Operator Console
HARDWARE PREFERRED
Processor >= Intel® Pentium Core® 2 Duo 3.0 GHz, or equivalent
Operating System 64-bits OS
Memory >= 6 GB DDR3
Add 1 GB if optional Océ PRISMAprepare
is installed
Hard Disk >= 200 GB (UDMA, SATA or SCSI U320) RAID-0 (striping)
A redundant disk configuration is recommended
for the Océ PRISMAaccess Archive Module. For example: RAID-1, 5, 10…) The size of the hard disk depends on the size and number of jobs in the archive.
DVD Reader Required
Video Card >= 1280 x 1024, True Colors (24/32-bit)
Screen 19"
Network TCP/IP (IPv4)
100/1000 Mbit/s
VIRTUAL HARDWARE INSTALLATION PREFERRED
Processor One processor with two cores, or two processors with one core each
Frequency >= 2 Ghz
Memory >= 6 GB
Add 1 GB if optional Océ PRISMAprepare is installed
General Performance Pass Mark Rating >= 800
Use the "Performance Test 7.0" tool
Hard Disk Performance Disk Mark >= 1000
Use the "Performance Test 7.0" tool.
A redundant disk configuration is recommended for the Océ PRISMAaccess Archive Module. For example: RAID-1, 5, 10…) The size of the hard disk depends on the size and number of jobs in the archive.
Hard Disk Latency DPC Latency <= 1000 us
Use the "DPC Latency Checker V1.30" tool
SOFTWARE: CENTRAL SERVER
Infrastructure
Operating System
32-bit:
Windows® Server® 2003 (Standard, Enterprise) R2 + SP2
Windows Server 2008 (Standard, Enterprise)
For Configurations Without Job Submission
(Configuration E ):
Windows XP SP3, Vista® SP2, Windows 7 SP1 or Windows 8
64 bits:
Windows Server 2008 (Standard, Enterprise) R2 SP1
Windows Server 2012 (Datacenter, Standard,
Essential, Foundation)
For configurations without submission (E):
Windows Components Microsoft®.NET® Framework v3.5 SP1 and 4.5 IIS 6.0, or higher
ASP.NET
Microsoft SQL Server®
Local installation, 32-bit/64-bit:
Microsoft SQL Server 2005 Express Edition
with Advanced Services SP3
Microsoft SQL Server 2008 Express Edition
with Advanced Services SP2, or SP3
Microsoft SQL Server 2008 R2 Express
Edition with Advanced Services
Microsoft SQL Server 2012 Express Edition
Required Applications:
- Windows Installer 4.5 or higher
- Windows PowerShell
Remote installation, 32-bit/64-bit:
Microsoft SQL Server 2005, all editions
Microsoft SQL Server 2008, all editions
Microsoft SQL Server 2008 R2, all editions
Microsoft SQL Server 2013, All Editions
Note:
For a remote SQL server, you must enable:
Remote Connections, Reporting Services and SQL Server Browser. Named instances and default instances are supported.
Microsoft Office Excel® Microsoft Office Excel 2003 with KB 907417 installed, 2007 SP2, 2010 or Microsoft Office Excel 2013
Note: Required for Job Cost Settings Editor
File System NTFS
>= 40 GB free space
Miscellaneous Latest Microsoft Windows updates
SOFTWARE: WEB SERVER
Infrastructure
Operating System 32-bit:
Windows Server 2003 (Standard, Enterprise) R2 + SP2
Windows Server 2008 (Standard, Enterprise) SP2
64-bit:
Windows Server 2012 (Datacenter, Standard, Essential, Foundation)
Windows Components Microsoft .NET Framework v3.5 and 4.5 installed
Microsoft Message Queuing (MSMQ) IIS 7.0, or higher
ASP.NET
Microsoft Office Excel Microsoft Office Excel 2003 with KB 907417 installed, 2007 SP2, or 2010
Native Document Conversion OpenOffice.org 2.4 Novell Edition
OpenOffice 3.1 - 3.3
Neevia® Document Converter Pro 5.2 - 6.2x
SOFTWARE: REMOTE OPERATOR CONSOLE
Infrastructure
Windows XP Professional SP3
Windows Vista® (Enterprise, Business, Ultimate) SP2
Windows 7 (Professional, Enterprise, Ultimate SP1
Windows 8 (Professional, Enterprise)
64-bit:
Windows 7 (Professional, Enterprise, Ultimate) SP1
Windows Server 2008 (Standard, Enterprise) SP1
Windows Server 2012 (Datacenter, Standard, Enterprise, Foundation)
Windows Components Microsoft .NET Framework v3.5 SP1 and v4.5
Network Enable the LPR protocol
Microsoft Office® Microsoft Office 2003, 2007 SP2, or 2010
Microsoft Office Outlook 2003, 2007 SP2, 2010 or 2013
Note:
Microsoft Office must be installed when you use native document conversion for Office documents.
Microsoft Office Outlook must be installed when you use e-mail submission.
Adobe® Acrobat® Professional Version 9.3, or higher
Version X, XI
Software requirements for installing the Point-and-Print Web driver on the Print Server
INFRASTRUCTURE
Operating System Network
32-bit:
Windows Server 2003
R2 + SP2
Windows Server 2008
64-bit:
Windows Server 2003
Windows Server 2008
(Standard, Enterprise) R2+ SP1
Windows Server 2012 (Datacenter, Standard, Essential Foundation)
TCP/IP (IPv4)
100/1000 Mbit/s
LPR protocol-enabled
LPR port of the Point and Print Web driver of the print server must be configured to print jobs to the queue of the Web driver of the PRISMAaccess server.
Customers can submit documents via the Océ PRISMAaccess Point-and-Print Web driver, Web Submission, or e-mail. Web driver/Web Submission requires PRISMAaccess Client.
BROWSER
Internet Explorer®
Safari®
FireFox®
Operating System
9.x
10
5.1x
23.0x
Windows 2003 R2 SP2
Windows 2008 R1 SP2
Windows 2008 R2 SP1 (64-bit)
Windows 2012
Windows XP SP3
Windows Vista SP2 (32-bit)
Windows 7 SP1 (32-64-bit)
Windows 8 (32-64-bit)
Windows XP SP3
Mac OSX 10.5, 10.6
Linux 2.4, 2.6 (both 32-bit)
Citrix 3.x and up
Brochures
Loading...
 Return to Top
