Web Content Viewer
Actions
imagePROGRAF PRO-4100
Professional Photo & Fine Art
Item Code: 3869C002AA
Everything Large Format at your fingertips. Download the App today.
Introduction to the imagePROGRAF PRO Series Large Format Printers
Click here to receive free print samples printed on the 11-color imagePROGRAF PRO Series Large-Format printers.
Features
Intelligent Media Loading
For the first time ever, an imagePROGRAF printer can load and recognize paper without the need for human intervention. Simply set the roll holder in the printer and let the media automatically feed into the print. The built-in multi-sensor measures the surface reflection and the media thickness to determine media type, without the need to manually enter it.
Remaining Media Estimation
Accurately measure the remaining media on a roll, without the need to print a bar code - saving both ink and media!
New Operation Panel
The large 4.3" LCD operation panel utilizes smart phone touch screen technology for easy operation. The top three most-used commands: Load, Feed and Cut, now have their own buttons below the operation panel for ease of use.
Enhanced Security
Developed with advanced security features, including support of secure PIN printing to protect data and the ability to disable printing, increasing administrative control of end-user printing.
LUCIA PRO Ink Set
The LUCIA PRO ink set adopts 11-color pigment inks and a Chroma Optimizer. Designed specifically to meet the demands of even the most critical photographer, the LUCIA PRO ink formulation includes microencapsulated colorants that enable smooth gradients, an expanded color gamut, and deeper color expression. This system helps you achieve stunning color reproduction, image clarity, and enhanced darker areas. A first for the Canon large format printers is the addition of a Chroma Optimizer. Used when printing on glossy and semi-glossy paper, this acts as a clear coat, improving color performance and gloss characteristics enriching the dark areas of a print.
This ink set helps:
  • Enhance gloss uniformity
  • Improve scratch resistance
  • Enhance dark area reproduction
  • Reduce graininess
No Switching of Black Inks
The PRO Series is designed to work seamlessly when changing media types. Matte black and Photo black inks have their own dedicated nozzles, so no manual switching between ink tanks is necessary. You can print on fine art paper then glossy paper with no worries, no changes, and no waste.
PF-10 Print Head
The PF-10, a 1.28”-wide print head with 18,432 nozzles equipped with anti-clogging FINE technology, generates fast print speeds while reducing the possibility of clogging. Ink ejection conditions are precisely checked by 27 sensors, and if a clog is detected, another nozzle will provide back-up. This print head is wider than previous imagePROGRAF print heads requiring models to only have one instead of two. Having only one print head means a more compact printer that achieves faster print speeds while maintaining high print quality.
L-COA PRO High-Speed Image Processing Engine
The imagePROGRAF printers are powered by the L-COA PRO high-speed image processing engine. With three processing chips, this high-precision control engine performs the processing of massive image data, and controls the optimal ink layout that produces high resolution prints.
Color Calibration
The color calibration function is designed to produce consistent color reproduction. This new printer includes an upgraded, built-in color densitometer that offers precise calibration and color matching. Using a three-color LED and condenser lens the sensor enables accurate recalibration of the device, allowing you to maintain a low average printer-to-printer color difference. The color calibration is finished quickly after a few simple steps on the printer’s operation panel. A single color calibration performed with one type of media is used to make adjustments on the other Canon supported media.
Device Management Console
The Device Management Console software, ideal for fleet management, lets you perform color calibrations remotely.  This software lets you monitor the printer status of up to 50 units from any location in the world, be notified via email when an error has occurred, or check the amount of ink left in the printers without ever having to leave the comfort of your desk.
High Precision Mechanical Platform
The unibody structure provides a strong platform for stable print head scanning, resulting in precise ink droplet placement. The perfect combination of speed and high-quality printing is achieved with this new design.
Multifunction Roll System
The optional Multifunction Roll System, which also utilizes Canon's new intelligent media handling, is a versatile media handling solution system that enables either a second roll of media to be loaded on the printer, or the unit can be configured as a bi-directional media Take-up unit. Dual –Roll Feeding: The dual-roll feeding mechanism enables users to load a second roll of a different media type and size so that users can simultaneously switch from printing on matte to gloss paper without pausing their work to reload. Additionally, the second roll can be used to support high-volume printing be enabling two rolls of the same media to be fed to the printer. Bi-Directional Rewinding: The Multifunction Roll System may also be configured by the operator as a take-up unit to rewind longer printouts. The user can choose to rewind media with the printed surface on the outside or the inside of the roll, thereby supporting “bi-directional rewinding”.
WiFi Connection
Stay Connected. Wi-Fi® connectivity is standard with the PRO Series printers.
Print From USB Thumb Drive
PDF and JPEG files can be directly printed on the imagePROGRAF PRO-4100 from a USB thumb drive. Simply input the thumb drive into the USB port on the printer, preview the image on the operation panel, and print! Fast and easy printing without the use of a computer.
High Capacity Ink Tanks
Available in 160ml, 330ml, and 700ml ink tanks, you have the flexibility to purchase ink based on your printing needs. 700ml photo black ink tanks can be purchased for those often printing nightscapes and 160ml magenta ink tanks for the occasional sunset image, giving you the power to purchase ink based on the color frequency at which you print.
Sub-Ink Tank System
The Sub-Ink Tank System allows all of the available ink in a tank to be used before having to replace it, helping eliminate any wasted ink. The empty tanks can also be replaced on-the-fly without stopping the printer. This is extremely useful during your long print jobs.
Multipositional Basket
The imagePROGRAF PRO-4100 features a multipositional basket that can be freely adjusted to enable various output positions and options: Catch Basket Flatbed Stacking Slope (can be used to display a print)
500GB Hard Drive
A built-in 500 GB hard drive within the printer increases productivity by relieving workload from the host Mac or PC, while providing a large capacity for print job data storage and retrieval. This 500 GB hard drive enables job data to be stored in protected mailboxes for easy access via web browser or at the printer for job re-printing. The embedded hard disk is ideal for medium to large workgroups to share a printer efficiently with multiple users, offering sample job storage space.
Software
Quick Utility Toolbox is a portal to where all of the Canon printer software and tools can be accessed.
This Windows® and Macintosh® drivers incorporate simplified page setup options, one-touch borderless printing, expanded color settings, and much more into a printer driver that is intuitive and easy-to-operate while still giving even the most advanced users the tools needed to stay productive. The Real Preview feature lets users ensure that the print setting and the layout on the roll paper is correct by providing real time preview, allowing users to change the print setting even after clicking on "print." The Free Layout feature enables nesting and custom layouts of images or files of nearly any type (available for both Windows and Mac driver).
In today's printing environment, it is more important than ever to understand how much ink and media each print job is costing your business. Both Mac® and Microsoft® compatible, Accounting Manager serves as a powerful feature, used for accurately managing your print costs. With the Accounting Manager feature you can track how much ink and paper is being consumed when printing in large format of up to 50 printers! Each individual ink tank can have its own cost associated to it, as well as a variety of different paper types. Costs can be assigned to ink and paper to determine expenses based on your own “Cost of Goods”. The user can also input a variable cost that will be added to the total of the print cost. The data is exportable to a .csv format for Microsoft Excel so the data can be used for billing purposes. This feature will allow you to determine the cost of each print based on your actual cost. Features include: Job Cost (ink, Media and variable cost inputted by user) Ink Consumed per Job* Media Consumed per Job Job Completion time And more
Recognizing the expanding array of media options for large format printers and to further improve the versatility of these new imagePROGRAF models, Canon has developed a Media Configuration Tool, which allows customers to not only utilize Canon-branded media, but provides the ability to make adjustments to printer settings to enhance the precision and quality of output achieved with third party media. Settings that can be configured using media parameter adjustment features include: Media weight and thickness Ink drying Automatic cutting settings Borderless printing Paper feed amount Print-head height Vacuum strength Maximum ink usage
Nest, tile and create custom layouts before printing your files with this print utility. Use the plug-in feature to print directly from Microsoft Office programs.
Creating large format prints is now easier with the introduction of Professional Print & Layout for imagePROGRAF large format printers. This software offers features that streamline your printing workflow. Compatible with Canon Digital Photo Professional® software, Adobe Photoshop® software, and Adobe Lightroom® software, Professional Print & Layout offers versatility never before seen with Canon Large Format printing. Features include: Create and save custom layouts Nesting of images Import multiple images and make batch edits that apply to all Create “Favorites” settings Crop images
Specifications
Printer Type
11-Color plus Chroma Optimizer 44-inch Printer
Number of Nozzles
Total: 18,432
All colors: 1,536 nozzles
Nozzle Pitch
600 dpi x 2
Non-firing nozzle detection and compensation
Print Resolution (Up to)
2400×1200dpi (Max)
OS Compatibility
32bit: Windows® (7/8.1/10)
64bit: Windows 7, Windows 8.1, Windows 10Windows Server 2008R2, Windows Server 2012/2012R2Windows Server 2016, Windows Server 2019
Mac (OS 10.11.6), (Mac OS 10.12 – 10.15)
Standard Interfaces
USB 2.0 High-Speed
10/100/1000 Base-T/TX
Wireless LAN (IEEE 802.11 b/g/n)
USB Thumb Drive
Ink Droplet Size
minimum 4 picoliter
Ink Capacity
160, 330, or 700ml per color*
Ink Droplet Size
Pigment based LUCIA PRO Ink
Color Set
Photo Black, Matte Black, Cyan, Magenta, Yellow, Photo Cyan, Photo Magenta, Gray, Photo Gray, Red, Blue, +Chroma Optimizer
Hard Drive
500GB
Media Width
Cut Sheet - 6- 44
Roll Feed - 6 - 44
Media Thickness
Roll: 0.07 - 0.8 mm (2.8 - 31.5mil)
Maximum Roll Print Length
Roll Feed - 59' (18 meters)**
Maximum Media Roll Diameter
6.7 (170mm)
Borderless Printing Width
Custom roll width 6 – 44 with micro margin technology
Paper Feed Method
Roll Feed: One Roll, Front-loading, Front Output
Manual Feed: Front-loading, Front Output
Languages
Swift Graphic Raster (SGRaster)
Noise Level Approx
Operation: 48 dB (A) or less
Accoustic Power: 6.6 Bels or less
Physical Dimensions
46.0 (H) x 62.7 (W) x 38.7 (D) (with basket open)
Weight
approx.271 lbs (roll holder included, no inks, no print heads)
Power Source
AC 100-240V(50-60Hz)
Power Consumption
Maximum: 107 W or less
Standby 2.0 W or less
Power Off: 0.3 W or less
Operating Environment
Temperature: 59 - 86°F
Relative Humidity: 10-80% (No Condensation)
User-replaceable items
  • Print Head (PF-10)
  • Maintenance Cartridge (MC-30)
  • Ink Tanks (PFI-1100/PFI-1300/PFI-1700)
Software Included
imagePROGRAF Printer Driver, Professional Print & Layout, Quick Utility Toolbox, Accounting Manager, Device Management Console, Media Configuration Tool, PosterArtist Lite (PC only), Printer Driver Extra Kit (Free Layout and Advanced Preview), Gallery Wrap Feature, Direct Print & Share4
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imagePROGRAF PRO-4100 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Use the Media Compatibility Guides to find the perfect media for your Canon machine.
Fine Art Natural
230gsm
14mil
German Etching by Hahnemuhle
310gsm
18mil
Fine Art Bright White
230gsm
14mil
330gsm
20mil
Artistic Satin Canvas
350gsm
19mil
Artistic Matte Canvas
340gsm
21mil
Water Resistant Matte Canvas
400gsm
24mil
Fine Art Photo Rag by Hahnemuhle
188gsm
11.5mil
Fine Art Enhanced Velvet
225gsm
14mil
255gsm
21mil
Photo Paper Pro Premium Matte
210gsm
12mil
Premium Fine Art Smooth
310gsm
16.5mil
Satin Photo Paper
170gsm
7mil
Satin Photo Paper
200gsm
8mil
Satin Photo Paper
240gsm
10mil
Glossy Photo Paper
170gsm
7mil
Glossy Photo Paper
200gsm
8mil
Glossy Photo Paper
240gsm
10mil
Premium RC Photo Matte
255gsm
10mil
Premium RC Photo Luster
255gsm
10mil
Premium Glossy Photographic Paper 2
280gsm
11mil
Premium Semi-Glossy Photographic
Paper 2
280gsm
11mil
Photo Paper Pro Premium Platinum
300gsm
12mil
Photo Paper Pro Luster
260gsm
10mil
Back Print Backlit Film
165gsm
5mil
Durable Matte Polypropylene Banner
130gsm
7mil
Durable Backlit Film
250gsm
7mil
Adhesive Matte Vinyl
290gsm
11mil
Scrim Banner Vinyl
460gsm
15mil
Water Resistant Matte Polypropylene
115gsm
6mil
Water Resistant Adhesive Matte Vinyl
330gsm
13mil
Water Resistant Matte Banner Vinyl
480gsm
13.8mil
Premium Gift Wrapping Paper
95gsm
4mil
Economy Bond Papper
75gsm
4mil
Premium Plain Paper (2 Rolls per box)
80gsm
4mil
High Resolution Coated Bond
120gsm
6mil
Heavyweight Coated Paper
140gsm
7mil
Heavyweight Coated Paper HG
145gsm
6mil
Double Matte Film
160gsm
5mil
Matte Coated Paper
90gsm
5mil
Matte Coated Paper
170gsm
8mil
Heavyweight Matte Coated Paper
230gsm
10mil
20lb. Bond, 150ft
75gsm
4mil
20lb. Bond, 3000ft
75gsm
4mil
20lb Recycled Uncoated Bond, 150ft
75gsm
4mil
20lb Recycled Uncoated Bond, 300ft
75gsm
4mil
24lb Bond, 150ft
90gsm
4mil
24lb Bond, 300ft
90gsm
4mil
24lb Premium Coated Bond, 150ft
90gsm
4mil
24lb Premium Coated Bond, 300ft
90gsm
4mil
What's In The Box
What's In The Box imagePROGRAF PRO-4100 Stand Tools and Screws US AC Power Cable Print Head PF-10 330ml Starter Ink Tanks (MBK/BK/C/M/Y/PC/PM/GY/PGY/R/B/CO) 2" Roll Holder with 3" Core Adapters Quick Set-up Guide Safety and Environmental Sheet Printer Stand Setup Guide Print Head Alignment Sheet User Manual USB Connection Sheet Software Discs (Windows Drivers, PosterArtist Lite - 32/64 bit) Sample media (12 sheets of Heavy Weight Coated HG paper A4 size) Call Center Notice Card (USA) User Registration Card Printer and Print Head Warranty Cards (USA and Canada) Canon USA Media Compatibility Sheet iWR Service Terms Leaflet
Brochures
Loading...
Videos
Introduction to Color
Professional Print and Layout Software Overview
How To Nest Images In Professional Print & Layout
How To Do Basic Prints Using Professional Print & Layout
How To Create Job Settings In Professional Print & Layout
How To Create Slots and Templates in Professional Print & Layout
How To Use Advanced Digital Image Tools In Professional Print & Layout
How To Use Color Management in Professional Print & Layout
Introduction to Professional Print & Layout
Print Plug-In for Adobe Photoshop
Understanding the Media Configuration Tool Software
Layout Plug-In (Gallery Wrap)
Learn how to calculate Large-format Printer’s Cost per print
Learn how to print and share your large format files using Canon Direct Print & Share
Learn how to nest and print images
using canon imagePROGRAF Free Layout
How to print on an Canon imagePROGRAF LF Printer
How to make a Poster Using Canon PosterArtist
Introduction to Canon’s Water Resistant Media
How to print using the imagePROGRAF Free Layout Tool
How to print a poster from a PDF file
using the imagePROGRAF Printer Driver
How to print a banner using the imagePROGRAF
Print Plug-in for Microsoft Powerpoint
How to create and print posters using
Canon PosterArtist Lite
How to Use Canon’s Print Plug-in for Microsoft office
Color Calibration Management Console Software
Adjustment Pattern Settings
Introduction to Professional Print and Layout with Eddie Tapp
ImagePrint Red Overview
How to Install a blade on the Graphtec Cutter
How to set the Course Adjustment on the Graphtec Cutter
How to set the Course Adjustment on the Graphtec Cutter - Method 2
How to load paper in the Graphtec Cutter
How to set speed on the Graphtec Cutter
How to cut using the Graphtec Cutter
How to set the fine adjustments on the Graphtec Cutter
How to install the cutting pen on the Graphtec Cutter
PRO Series Borderless Printing Video
This is to make Misc appear on the page when needed.
DISCLAIMERS
Recycled paper and chlorine-free paper can be used with this product.
Canon and imagePROGRAF are registered trademarks and LUCIA PRO logo are trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. All other referenced product names and marks are trademarks of their respective owners. Prices, specifications, and availability are subject to change without notice. Actual prices are set by individual dealers and may vary. All printout images and effects are simulated.
  1. Professional Print & Layout software is compatible with Adobe Photoshop CC 2015 – CC 2019, Adobe Photoshop Lightroom V6.X, CC2016, Classic CC, Photoshop Elements 15, 2018, 2019 and Canon Digital Photo Professional 4.92 or later.
  2. Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  3. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
  4. Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud providers current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
*The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
**The maximum printable length varies, depending on application, OS, and RIP used.
 Return to Top
