Web Content Viewer
Actions
LX-MH502Z
All Projectors
Item Code: 3576C002AA
PROJECTORS.USA.CANON.COM is our website dedicated solely to Canon Projectors.
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
See the contact information for the Canon Projector Account Manager that covers your state.
Features
  • 4K UHD Resolution (3840 x 2160)
  • 5000 Lumens and 50,000:1*3 Contrast Ratio Deliver Bright, Engaging Images
  • Laser Light Source Provides Longevity, Versatile Installation and a Wide Color Range
  • 1-chip DLP® Technology
  • Multiple Image Modes including DICOM Simulation Mode*4 for Optimal Image Quality Reproduction
  • Advanced Adjustment Options for Customizable Image Characteristics
  • Installation Versatility with Lens Shift and More Install-Friendly Functions
  • Versatile Connectivity - HDBaseT™, Dual HDMI, Component USB Type A, RJ-45, RS-232 and Audio Inputs
  • Network Management including Compatibility with Crestron RoomView and AMX Device Discovery
  • Backed by Canon's 5-Year Limited Warranty including the Advanced Warranty Service Exchange Program and Service Loaner Program*5
This is to make Misc appear on the page when needed.
Specifications
Projector Specifications
Imaging Device
.47" / 1-chip DLP
Aspect Ratio
16:9
Native Resolution
3840 x 2160 | 1920 x 1080 (4K shift function: ON/OFF)
Brightness
5000/3750lm*1*2*7
Uniformity
80%
Contrast Ratio
50,000:1*3
Digital Keystone
V: ±30°
Optics
F Number, Focal Length
F1.81 - F2.10, f=14.3mm - 22.9mm
Zoom
1.6x (Manual)
Focus
Manual
Image Size
Wide: 60" - 300", Tele: 60" - 200"
Throw Distance:
Wide: 1.80 - 8.98m, Tele: 2.87 - 9.56m
Throw Ratio
1.36 - 2.18:1
Lens Shift
V:±60%, H:±23%
Image Adjustments
Image Modes
Presentation, Standard, sRGB, Cinema, DICOM, User 1, User 2
Color Adjustment
Color Temperature, Color, Tint, 6-Axis Color Adjustment, MoviePro
Screen Color Correction
Off, Light Yellow, Pink, Light Green, Blackboard
Mounting
360°
Adjustable Feet
4
Image Adjustments
Scanning Frequency
V: 24Hz - 119.989Hz, H: 15.63kHz - 112.5kHz
Analog PC Input
WUXGA, WSXGA+, UXGA, SXGA+, WXGA+, FWXGA, XGA, SXGA, SVGA, VGA, MAC
Digital PC Input
3840 x 2160, WUXGA, WSXGA+, UXGA, SXGA+, WXGA+, FWXGA, XGA, SXGA, SVGA, VGA
Digital Video Input
2160p, 1080p, 1080i, 720p, 576p, 480p (supports audio input)
Dot Clock
594 MHz (Maximum)
Terminals
Mini Dsub15
Input Analog PC
HDMI
Digital PC / Digital Video Input
HDMI 2
Digital PC / Digital Video Input *8
RJ-45 (HDBaseT)
Network Connection (100BASE-TX/10BASE-T)(HDBaseT and normal network switched automatically)
Dsub9 (Control)
RS-232
USB Type A
Power Out (5V)
USB Mini B
Service Port
Mini Jack
Input Analog PC, Audio Output
Remote Control
Wireless Remote
IR
Built-In Sound
Internal Speaker
10W, Monaural
Light Source
Type
Blue Laser Diode/ Yellow Phosphor Wheel
Life
20,000 hours*5
Rating
Noise Level
39/37dB*7*4 (4K shift: ON), 37/35dB*7*4 (4K shift: OFF)
Power Consumption
550/400 W*7*4 AC 100 - 120V,  510/380 W*7*4 AC 220 - 240V
Standby Power Consumption
0.4/1.5 W*7 (LAN OFF/ON) AC 100 - 120V, 0.5/2.0W*7 (LAN OFF/ON)AC 220 - 240V
Power Voltage
AC 100 - 240V: 50/60Hz
Operating Temperature
32°F - 104°F (10% RH - 90% RH)
Dimensions (W x D x H)
17.7" x  14.9" x  6"
Weight
20.5 lbs.
Notes
*1: Brightness other than Normal is a calculated value and is not guaranteed as a specification
*2: For protection of product, light emission from light source may be decreased when external temperature rises
*3: Light source turns off when full black is projected. Dynamic contrast ratio
*4: Eco value is calculated only and is not guaranteed as specification
*5: Calculated value, not a guaranteed value
*6: When in Presentation mode
*7: Normal / Eco
*8: Not all video signals supported for HDMI terminal 1 are supported for HDMI terminal 2. See User Manual for supported video signals.
LX-MH502Z Box Contents
LX-MH502Z Box Contents LX-MH502Z Projector Power Cord (70.8" (1.8M)) Projector Remote Control: LV-RC08 (battery type: CR2025) Warranty Card
Brochures
Loading...
DISCLAIMERS
  1. This is an estimated value, actual hours may vary depending on usage and environment. This is not a guarantee of the life span of individual laser diodes.
  2. Maximum image side when Wide: 60 - 300" or Tele: 60 - 200".
  3. Full white, full black, Image mode set to presentation. Light source turns off when full black is projected. Dynamic contrast ratio.
  4. This projector includes a DICOM Simulation Mode. It has not been cleared or approved for medical diagnosis and should not be used for these purposes.
  5. Programs and service offerings subject to change without notice. For complete details, including terms and conditions for each program, or to learn more about Service and Support offerings for Canon professional projectors, please contact a Canon sales rep or call 1-800-OK-CANON.
 Return to Top
