Web Content Viewer
Actions
LX-MU500Z
All Projectors
Item Code: 2632C002AA
PROJECTORS.USA.CANON.COM is our website dedicated solely to Canon Projectors.
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
See the contact information for the Canon Projector Account Manager that covers your state.
Features
Canon's WUXGA resolution brings bright, true widescreen display of highly detailed HD video content and still images with outstanding color richness to large-room installations in high resolution WUXGA (1920 x 1200) at a competitive price. Widescreen graphics, text and other visual content from laptops and desktop computers are shown in accurate proportions from edge to edge with sharp detail.
This projector projects bright 5000 lumen images with a 50,000:1*2 contrast ratio that helps ensure deep blacks, bright whites and excellent color. They feature clear depth and dimension, and great color accuracy, which is critical to those with discerning needs.
*2 Full white, full black, Image mode set to presentation. Light source turns off when full black is projected. Dynamic contrast ratio.
The projector's laser light source provides up to 20,000*1 hours in standard use of continuous, reliable, high-quality projection. Operation is virtually maintenance-free with minimal downtime, as the light source doesn't require routine replacement. This keeps running costs relatively low when looking at the total life of the product – a key consideration for challenging and hard-to-reach installations.
Other advantages of the laser light source include installation flexibility and more.
360° Projection*5
Because this projector uses a laser light source instead of a conventional lamp it can be installed at any angle on a 360° axis facing in any direction.
Wider Color Gamut
Because the laser light source produces a wide range of colors, the projector covers the sRGB color space to deliver millions of colors.
*1 This is an estimated value, actual hours may vary depending on usage and environment. This is not a guarantee of the life span of individual laser diodes.
*5 Air vents should not be blocked. See User Manual for recommended installation.
This projector utilizes Single-chip Digital Light Processing (DLP®) technology which is a widely utilized projection technology that creates natural and lifelike images. The DLP® technology utilizes a color wheel along with a reflective Digital Micromirror Device (DMD) to produce video and images with high brightness. The resulting high-resolution video and images maintain the details inherent in what you are showing.
The projector includes pre-set Image Modes and additional customizable Image Modes to suit a wide range of user preferences and projection environments.
Multiple Image Modes
Image Modes provide different variations of color reproduction characteristics suitable for the image type and projection environment. They include:
Standard: Ideal for bright rooms, and when using content from computer screens or motion picture content.
Presentation: Ideal for somewhat bright rooms when text needs to be clear, such as when part of a video presentation.
sRGB: Ideal for projecting images from sRGB-supported digital cameras.
Video: Ideal for rooms that are somewhat dark, and for video content.
2 Customizable Modes: Ideal for custom set-ups. Provides up to 2 user-selected combinations of image quality settings that can be stored in the memory and selected as an image mode.
DICOM Simulation Mode*3: Ideal for displaying medical images in non-diagnostic settings. Both Blue Base and Clear Base settings are supported.
*3 This projector includes a DICOM Simulation Mode. It has not been cleared or approved for medical diagnosis and should not be used for these purposes.
The projector offers extensive image quality adjustments to help users customize the image to meet their specific projection needs.
Image Adjustments
The Image Adjustment settings allow users to customize the image and color characteristics to fulfill their specific imaging needs. These include:
Brightness
Contrast
Sharpness
Gamma
Color Adjustments
  • BrilliantColor
  • Tint
  • Color Temperature
  • Screen Color
Advanced Image Adjustments
These adjustments provide greater flexibility to professional users with more options to adjust the image as desired. These settings include:
6-Axis Color Adjust: This technology lets users fine-tune the hue and saturation of each of the primary and secondary colors, providing a high degree of control that can make each projected image a "masterpiece."
Lens Shift
Manual vertical (±50%) and horizontal (±23%) lens shift allows for adjustment of the image with virtually no distortion.
360-degree Vertical Installation*5
360-degree projection*5 allows the projector to be positioned anywhere on the vertical axis. Fan speed can also be adjusted to help optimize results (depending on projector positioning).
*5
1. A third-party stand must be used for portrait orientation. Do not place the projector directly on the floor.
2. Operational life of optical components will be shortened when the projector is installed in the following conditions:
When the lens is pointing a downward direction.
When the air-intake vent is pointing a downward direction in portrait orientation.
Corner Adjustment
Allows the corners of the image to be independently adjusted to help ensure optimal image reproduction.
Screen Color Correction
Enables users to fine-tune the colors of images based on the color of the projection surface. Adjustments can be made from Normal and Greenboard, as well as additional tuning for projecting onto virtually any other colored surface.
Connections include: HDMI, HDMI/MHL and analog RGB computer connectors; S-Video input; RCA inputs; and a LAN connection terminal which relays data to a built-in HDBaseT receiver for transmission of video and audio signals from a source device. Industry-standard control and networking inputs include a network-ready RJ-45 port enabling authorized users to manage and control multiple projectors from any PC on a network, an RS-232 serial connection for monitoring the projector locally through a third-party control system, a USB Type A port for power output and a USB mini B port for easy installation of firmware upgrades.
Compatibility with Crestron RoomView and AMX Device Discovery helps ensure seamless integration into many systems or infrastructures and smooth network management.
Canon Laser Projector Warranty
All Canon Laser Projectors offer peace of mind as they are backed by Canon USA's Laser Projector Limited Warranty, which guarantees that the projector will be free from defects in workmanship and materials for 5 years from the date of original purchase or 12,000 hours of use (whichever occurs first). For complete terms and conditions click here.
Advanced Warranty Exchange Service Program*4
The Canon Advanced Warranty Exchange Service Program*4 provides you with enhanced warranty service in addition to traditional “mail-in” repair service. The exchange program provides a replacement unit in exchange for your eligible inoperative Canon Projector if repair service is required during the product's limited warranty period.
Service Loaner Program*4
The Canon Service Loaner Program*4 provides a loaner product in the event that your eligible Canon Projector is in need of repair during the limited warranty period. The loaner projector may be used while your inoperative unit is being serviced via Canon's “mail-in” repair service.
CarePAK PRO AV Extended Service Plan*4
The Canon CarePAK PRO AV Extended Service Plan*4 offers options for one year or two years additional coverage for up to five full years of service and support from the date the Projector is purchased (only available on select models).
*4 Programs and service offerings subject to change without notice. For complete details, including terms and conditions for each program, or to learn more about Service and Support offerings for Canon professional projectors, please contact a Canon sales rep or call 1-800-OK-CANON.
Main Unit Spec
Projector Specifications
Imaging Device
.48" / 1-chip DLP
Aspect Ratio
16:10
Native Resolution
1920 x 1200 (WUXGA)
Brightness
5000/3750lm (Normal/Eco)*1*2
Uniformity
80%
Contrast Ratio
50,000:1*3
Digital Keystone
V: ±30°, H: ±30°
Optics
F Number, Focal Length
F1.81 - F2.10, f=14.3mm - 22.9mm
Zoom
1.6x
Focus
Manual
Image Size
Wide: 60" - 300", Tele: 60" - 200"
Throw Distance
Wide: 1.75 - 8.74m, Tele: 2.80 - 9.32m
Throw Ratio
1.36 - 2.18:1
Lens Shift
V:±50%, H:±23%
Image Adjustments
Image Modes
Presentation, Standard, sRGB, Movie, DICOM, User 1, User 2
Color Adjustment
Color Temperature, Color, Tint, 6-Axis Color Adjustment, BrilliantColor
Off, Light Yellow, Pink, Light Green, Blackboard
Mounting
360°
Adjustable Feet
4
Image Signals
Scanning Frequency
V: 24Hz - 119.989Hz, H: 15.63kHz - 101.563kHz
Analog PC Input
WUXGA, WSXGA+, UXGA, SXGA+, WXGA+, FWXGA, XGA, SXGA, SVGA, VGA, MAC
Digital PC Input
Component Video Input
1080p, 1080i, 720p, 576p, 576i, 480p, 480i
Digital Video Input
1080p, 1080i, 720p, 576p, 480p (supports audio input)
Dot Clock
162 MHz (Maximum)
Video Input/ S-video Input
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL-60
Terminals
Mini Dsub15
Input Analog PC, Output Component Video
HDMI
Digital PC / Digital Video Input
HDMI/MHL
Mini DIN4
S-Video
RCA x3
Video Input / Audio-L / Audio-R
RJ-45 (HDBaseT)
Network Connection (100BASE-TX/10BASE-T)(HDBaseT and normal network switched automatically)
Dsub9 (Control)
RS-232
USB Type A
Power Out (5V)
USB Mini B
Service Port
Mini Jack
Input Analog PC/Component, Output Audio
Remote Control
Wireless Remote
IR
Built-In Sound
Internal Speaker
10W, Monaural
Light Source
Type
Blue Laser Diode/ Yellow Phosphor Wheel
Life
20,000 hours*5
Ratings
Fan Noise
37/35dB (Normal / Eco)
Power Consumption
530W/415W (100 -~ 120V) (Normal / Eco), 490W/395 (220 ~240V) (Normal/Eco)*4
Standby Power Consumption
0.4/1.5W (100 -~ 120V), 0.5/2.0W (220 ~ 240V)(Network Settings OFF/ON)
Power Voltage
AC 100 - 240V: 50/60Hz
Operating Temperature
32°F - 104°F (10% RH - 90% RH)
Weight
19.6 lbs.
Dimensions (W x H x D)
17.7" x 6" x 14.9"
Notes
*1: Brightness other than Normal is a calculated value and is not guaranteed as a specification
*2: For protection of product, light emission from light source may be decreased when external temperature rises
*3: Full white, full black, Image mode set to presentation. Light source turns off when full black is projected. Dynamic contrast ratio.
*4: Eco value is calculated only and is not guaranteed as specification
*5: Calculated value, not a guaranteed value
This is to make Misc appear on the page when needed.
LX-MU500Z Box Contents
LX-MU500Z Box Contents LX-MU500Z Projector Power Cord (70.8" (1.8M)) Projector Remote Control: LV-RC08 (battery type: CR2025) Warranty Card
Brochures
Loading...
DISCLAIMERS
This product has not been tested for compliance with the performance standards for laser products under 21 CFR Part 1040. The product is not, and may not be, offered for sale or sold or leased in the United States until performance standard certifications have been completed.
 Return to Top
