Web Content Viewer
Actions
LX-MU700
All Projectors
Item Code: 0905C002AA
PROJECTORS.USA.CANON.COM is our website dedicated solely to Canon Projectors.
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
See the contact information for the Canon Projector Account Manager that covers your state.
Features
7500 Lumens*1 of brightness will keep audiences engaged in a wide variety of large venue applications – from classrooms to boardrooms, houses of worship and more. This high level of brightness, combined with a contrast ratio of up to 2100:1, allows this projector to produce deep blacks and balanced whites for a high level of detail and clarity when showing both still images and video.
Engineered for dependability, the LX-MU700 employs a dual lamp system that utilizes two independent lamps. When one lamp reaches its end of life the other can quickly be used, helping to minimize projector downtime and removing the need for the immediate changing of a lamp. This feature makes the LX-MU700 ideal for important applications where projector downtime must be virtually eliminated – a key factor for units installed in areas that may be challenging to access.
Canon's WUXGA resolution brings bright, true widescreen display of intricately detailed HD video content and still images with outstanding color richness to large-room installations in high resolution WUXGA (1920 x 1200) at a competitive price. Content is projected without compression. Widescreen graphics, text and other visual content from laptops and desktop computers are shown in accurate proportions, just as it appears on most monitor screens.
This projector utilizes Single-chip Digital Light Processing (DLP) technology which is a widely utilized projection technology that creates natural and lifelike images. The DLP technology utilizes a 6-segment color wheel along with a reflective Digital Micromirror Device (DMD) to produce video and images with high brightness. The resulting high-resolution video and images maintain the details inherent in what you are showing.
This projector is up to the challenges of a variety of installation applications given the wide assortment of optional lenses available to help achieve optimal image quality. The eight interchangeable lens options range from a Short Fixed Lens to an Ultra Long Zoom Lens, covering a variety of throw ratios. Screen sizes up to 500-inches*3 are possible with this projector. Please refer to the chart below for the throw ratio, zoom ratio, lens shift and screen sizes available with each optional lens.
For added convenience, this model features a quick release button to quickly install and uninstall lenses.
Lens Ultra Wide
Zoom Lens
LX-IL01UW
Short Fixed
Lens
LX-IL07WF
Wide Zoom
Lens
LX-IL08WZ
Wide Zoom
Lens
LX-IL02WZ
Standard
Zoom Lens
LX-IL03ST
Middle
Zoom Lens
LX-IL04MZ
Long Zoom
Lens
LX-IL05LZ
Ultra Long
Zoom Lens
LX-IL06UL
Throw
Distance
5.31 – 6.69 ft
(1.62 – 2.04m)
- 5.24 ft.
(- 1.66m)
7.57 – 11.38 ft.
(2.31 – 3.47m)
8.89 – 12.72 ft.
(2.71 – 3.88m)
12.23 – 16.14 ft.
(3.73 – 4.92m)
15.74 – 26.24 ft.
(4.8 – 8m)
25.36 – 38.38 ft.
(7.73 – 11.7m)
37.66 – 59.28 ft.
(11.48 – 18.07m)
Throw
Ratio*4
0.75 – 0.93:1 0.76:1 1.07 – 1.61:1 1.25 – 1.79:1 1.73 – 2.27:1 2.22 – 3.67:1 3.58 – 5.38:1 5.31 – 8.26:1
Zoom
Ratio
1.25x
Optical Zoom
Fixed 1.41x
Optical Zoom
1.5x
Optical Zoom
1.3x
Optical Zoom
1.65x
Optical Zoom
1.5x
Optical Zoom
1.55x
Optical Zoom
Size*3
40 – 500 in. 40 – 500 in. 40 – 500 in. 40 – 500 in. 40 – 500 in. 40 – 500 in. 40 – 500 in. 40 – 500 in.
F Number F1.96 – 2.3 F1.85 F1.85 – 2.5 F2.11 – 2.37 F1.7 – 1.9 F1.86 – 2.48 F1.85 – 2.41 F1.85 – 2.48
Focal
Length
11.3 – 14.1mm 11.6mm 18.7 – 26.5mm 15.73 – 23.59mm 26 – 34mm 32.9 – 54.2mm 52.8 – 79.1mm 78.5 – 121.9mm
Lens
Shift*5
V: 0 – 50%
H: ±6.7%
V: 0%
H: ±0%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
Lens Standard
Zoom Lens
LX-IL03ST
Middle
Zoom Lens
LX-IL04MZ
Long Zoom
Lens
LX-IL05LZ
Ultra Long
Zoom Lens
LX-IL06UL
Throw
Distance
12.23 – 16.14 ft.
(3.73 – 4.92m)
15.74 – 26.24 ft.
(4.8 – 8m)
25.36 – 38.38 ft.
(7.73 – 11.7m)
37.66 – 59.28 ft.
(11.48 – 18.07m)
Throw
Ratio *4
Zoom
Ratio
1.3x
Optical Zoom
1.65x
Optical Zoom
1.5x
Optical Zoom
1.55x
Optical Zoom
Size *3
F Number F1.7 – 1.9 F1.86 – 2.48 F1.85 – 2.41 F1.85 – 2.48
Focal
Length
Lens
Shift *5
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
This projector is equipped with a built-in HDBaseT receiver facilitating uncompressed HD video, audio and control signals to be transmitted over one single LAN cable with a maximum distance of 100m. This reduces complex wiring schemes used for a typical setup as well as maximizing long cable runs with minimal image quality degradation.
HDBaseT operation may vary when connected to other third-party HDBaseT devices. Please consult with a Canon representative for a full compatibility list.
Motorized Lens Shift
Motorized vertical and horizontal lens shift allows for adjustment of the image with virtually no distortion. Most lenses can shift up to 0–50% vertically*7,8 and ±10% horizontally*7,8. This model is also equipped with motorized zoom and focus – all of which can be adjusted through the included remote control.
Lens Position Memory
Up to 10 different custom lens presets can be stored and memorized. Each preset includes information for a variety of lens settings such as lens shift, lens zoom and focal length. This makes it easy to switch from one projection set-up to another.
For added convenience, other standard lens settings are also included, such as a Center Lens setting that moves the lens shift, zoom ratio and focal length of the lens to the center position.
Position Flexibility including 360-degree Installation on the Vertical Axis*6
This model can be used in multiple positions to suit a wide variety of applications and environments. Settings to maximize lamp life relative to position and environment are also available, including a High Altitude Mode which increases fan speed for efficient running in high altitude environments.
Two interchangeable color wheels are included to help ensure different types of content are displayed at their best. The pre-installed 6-Segment BRT color wheel adds white to the wheel to emphasize brightness. In an environment with bright ambient light this color wheel increases the clarity and sharpness of charts, graphs and text. The 6-Segment COL color wheel emphasizes color accuracy by adding magenta (instead of white) to the color wheel for true color reproduction with great balance of mid-tones and gradations.
This projector includes pre-set Image Modes and additional customizable Image Modes to suit a wide range of user preferences and projection environments.
Multiple Image Modes*8
Image Modes provide different variations of color reproduction characteristics suitable for the image type and projection environment. They include:
Standard: Ideal for bright rooms, and when using content from computer screens or motion picture content.
Presentation: Ideal for somewhat bright rooms when text needs to be clear, such as when part of a video presentation.
Video: Ideal for rooms that are somewhat dark, and for video content.
This projector offers extensive image quality adjustments to help users customize the image to meet their specific projection needs.
Image Adjustments
The Image Adjustment settings allow users to customize the image and color characteristics to fulfill their specific imaging needs. These include:
Brightness
Contrast
Sharpness
Gamma
Noise Reduction
White Gain
Offset (RGB)
Dynamic Black
Color Adjustments
• Color Temperature (Native, 5400K, 6500K, 9300K)
• White Balance (RGB Offset, RGB Gain)
• Hue
• Saturation
• Gain (RGBCMY)
• White Gain (RGB)
Advanced adjustments allow greater flexibility to the professional user through digital fine-tuning of picture and color characteristics to meet specific image content or environmental conditions. These settings include:
Digital Alignment
This function gives users the ability to digitally zoom, pan and scan the image.
H/V Alignment
This keystone adjustment feature allows correction of trapezoid-shaped projections so that viewers can see a clearly aligned square-shaped image. It's possible to make adjustments horizontally and vertically to achieve optimum positioning with no need to physically move the projector.
Keystone
V: ±40% keystone for projecting on a surface at a ±40° vertical.
This model is capable of projecting 3D content via the DLP-Link System. Utilizing a 3D Blu-ray player along with DLP Link 3D glasses for your audience, this projector will display bright 3D images.
Comprehensive input and output connections allow versatility and easy set-up for a wide range of content sources. Connections include: HDMI, DVI-D, and analog RGB computer connectors; a VGA connector; 5-BNC connectors; DisplayPort for image and audio signal transmission over a single cable; a LAN connection terminal for wired transmission of image and audio signals from a PC; a network-ready RJ-45 port as well as audio output. Industry-standard control and networking inputs include a USB mini B port for easy installation of firmware upgrades, a network-ready RJ-45 port enabling authorized users to manage and control multiple projectors from any PC on a network (Gigabit data transfer speeds are supported), an RS-232 serial connection for monitoring the projector locally through a third-party control system and 3D Sync Out that enables content to be displayed in 3D; a mini-jack that provides a trigger for screen operation and a mini-jack for connecting an optional hand-held wired remote controller. This projector also offers a built-in HDBaseT port for transmission of uncompressed HD video, audio and control signals over one single LAN cable up to a maximum distance of 328 feet. This helps reduce the number of unsightly wires without degrading image quality.
Compatibility with Crestron, AMX Device Discovery and Extron helps ensure seamless integration into most systems or infrastructures and smooth network management. Support for PJLink also makes it possible to control and monitor the projector over a network – this feature is ideal for observing lamp hours, usage and much more.
Easy Access to Replacement Parts
A simplified design helps ensure maintenance efforts are kept to a minimum. Air filters, lenses and lamps can be easily replaced without removing the projector from most installation positions.
Lamp Power Modes
To help keep maintenance and running costs to a minimum, this projector also features an Eco Mode option which can increase the life of the lamp from 2000*11 hours with both lamps on in Normal mode, to 4000*11 hours in Eco mode. There is also a Custom Power Level mode for even more flexible power adjustment.
Canon 3-Year Projector & Lamp Limited Warranty
All Canon Projectors offer peace of mind as they are backed by Canon USA's Projector and Lamp Limited Warranty, which guarantees that the projector will be free from defects in workmanship and materials for 3 years from the date of original purchase, and the Lamp for 120 days from the date of original purchase. For complete terms and conditions click here.
3-Year Advanced Warranty Exchange Service Program*2
The Canon 3-Year Advanced Warranty Exchange Service Program*2 provides you with enhanced warranty service in addition to traditional "mail-in" repair service. The exchange program provides a replacement unit in exchange for your eligible inoperative Canon Projector if repair service is required during the product's limited warranty period.
3-Year Service Loaner Program*2
The Canon Service Loaner Program*2 provides a loaner product in the event that your eligible Canon Projector is in need of repair during the limited warranty period. The loaner projector may be used while your inoperative unit is being serviced via Canon's "mail-in" repair service.
Extended Service Plan*2
Canon CarePAK PRO AV Extended Service Plan*2 offer options for one year or two years additional coverage for up to five full years of service and support from the date the Canon REALiS PRO AV Installation Projector is purchased.
Projector Specifications
Imaging Device
DLP x1
Aspect Ratio
16:10
Native Resolution
1920 x 1200 (WUXGA)
Brightness
7500 Lumens (Dual Lamp, Lamp Mode: Normal)*2*3
Uniformity
85%*2
Contrast Ratio
2100:1*2
Digital Keystone (Vertical)
V±40°
Optics (Projector Lens)
*Please see lens information at the bottom*
Image Adjustments
Image Mode
Presentation, Standard, Video
Mounting
Front table, Rear table, Front ceiling, Rear ceiling, Upward & Downward.
Tilt Angle
Front 2: Rear: 1
Image Signals
Scanning Frequency
H: 15.62 ~ 91.15 KHz, V: 24 ~ 85.06 Hz
Analog PC Input
WUXGA/WSXGA+ /UXGA/SXGA+/WXGA+/WXGA/SXGA/XGA/SVGA/VGA
Digital PC Input
Component Input
1080p/1080i/720p/576p/480p
Digital Video Input
1080p/1080i/720p/576p/480p/576i/480i
Dot Clock
157.5 MHz
Terminals
Dsub15 (Computer-1)
Analog PC / Component Video Input
5BNC (Computer-2)
DVI-D
Digital PC / Digital Video Input
HDMI
DisplayPort
RJ-45
HDbaseT Input / Network Connection (100BASE-TX / 10BASE-T)
Dsub15 (Monitor-out)
Image Output
Dsub9 (Control)
RS-232 Connection
USB Mini B
Service Port
3D Sync Out
For 3D Display
Mini Jack (Trigger)
For Picture Control
Mini Jack (Remote)
Wired Remote Control Connection
Remote Control
Wireless Remote
IR
Built-In Sound
Internal Sound
10W x2, Stereo
Lamp
Type
Super-high Pressure Lamp (x2)
Life
2000 (Normal),  4000 (Eco) Hours
Power
350/280W (x2)*1
Rating
Fan Noise
Dual Lamp: 41/36 dB, Single Lamp: 38/35 dB*1
Power Consumption
Dual Lamp: 850/680W
Single Lamp: 440/370W*1
Standby Power Consumption
6.0/0.5W*4
Heat Dissipation
Up to 2,901 BTU/h
Power Voltage
AC 100 - 240V, 50/60Hz
Operating Temperature
40°F - 104°F
Storage Temperature
-4°F - 140°F (-20°C - 60°C)
Dimensions (W x D x H)
19.8" x 20.8" x 8.7"
Weight
45.2 lbs.*5
Notes
*1: Lamp Mode is Normal/Eco
*2: When using Standard Zoom Lens (LX-IL03ST)
*3: When a color wheel is incorporated from beginning (color wheel gives priority to brightness)
*4: Standby mode is Network/Eco
*5: Excluding Lens
Optics (8 Interchangeable Genuine Canon Lenses)
LX-IL01UW - Ultra Wide Zoom Lens
PROJECTION LENS
F1.96 ~ 2.3/ f= 11.3 - 14.1mm
LENS SHIFT
V: 0 - 50%, H: ±6.7%
ZOOM
1.25x
FOCUS
40 - 500" **2
SCREEN SIZE
40 - 500"
PROJECTION DISTANCE
5.31' - 6.69' (1.62 - 2.04m)
THROW RATIO
0.75 - 0.93:1 **1
RS-IL02WZ - Wide Zoom Lens
PROJECTION LENS
F1.85 - 2.5 / f= 18.7 - 26.5mm
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.41x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
8.89' - 12.72' (2.71 - 3.88m)
THROW RATIO
1.25 - 1.79:1 **1
LX-IL03ST - Standard Zoom Lens
PROJECTION LENS
F1.7 - 1.9 / f= 26 - 34mm
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.3x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
12.23' - 16.14' (3.73 - 4.92m)
THROW RATIO
1.73 - 2.27:1 **1
LX-IL04MZ - Middle Zoom Lens
PROJECTION LENS
F1.86 - 2.48 / f= 32.9 - 54.2mm
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.65x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
15.74' - 26.24' ( 4.8 - 8m)
THROW RATIO
2.22 - 3.67:1 **1
LX-IL05LZ - Long Zoom Lens
PROJECTION LENS
F1.85 - 2.41 / f= 52.9 - 79.1mm
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.5x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
25.36' - 38.38' (7.73 - 11.7m)
THROW RATIO
3.58 - 5.38:1 **1
LX-IL06UL - Ultra Long Zoom Lens
PROJECTION LENS
F1.85 - 2.48 / f= 78.5 - 121.9mm
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.55x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
37.66' - 59.28' 11.48 - 18.07m
THROW RATIO
5.31 - 8.26:1 **1
LX-IL07WF - Short Fixed Lens
PROJECTION LENS
F1.85 / f= 11.6mm
LENS SHIFT
V: 0%, H: 0%
ZOOM
Fixed
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
-5.24' (-1.66m) **3
THROW RATIO
0.76:1 **1
LX-IL08WZ - Wide Zoom Lens
PROJECTION LENS
F2.11 -2.37
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.5x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
7.57' -11.38' (2.31 -3.47m)**3
THROW RATIO
1.07 - 1.61:1 **1
Notes
**1: Calculated value for 80" Image
**2: Indicates focus ability range in the chart. Optical feature guaranteed range is: 50 - 300"
**3: Calculated for 100" image.
DLP LX-MU700 Box Contents
DLP LX-MU700 Box Contents LX-MU700 Pro AV Projector Dust Cap Power Cord Color Wheel BRT (Brightness priority)* Color Wheel COL (Color priority)* VGA to VGA Connection Cable (Mini Dsub15-Mini Dsub15) Projector Remote Control LX-RC01 (includes two AA batteries) (2) Lamp LX-LP01 Important Information Guide (book) User's Manual (CD-ROM) Warranty Card
* 6 Segment-BRT color wheel is optimized for brightness and preinstalled. Use the optional, bundled 6 Segment-COL color wheel for optimal color.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LX-MU700 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
A&E Specifications
A&E Specifications
File Description:
Date:
01/15/16
Size:
545 KB
Drawings / 3D CAD
File Description:
Date:
01/15/16
Size:
532 KB
Date:
01/15/16
Size:
1.28 MB
Date:
01/15/16
Size:
468 KB
Date:
01/15/16
Size:
3.91 MB
File Description:
Date:
07/19/17
Size:
1.86 MB
This is to make Misc appear on the page when needed.
DISCLAIMERS
*1 When using Dual Lamps, Standard Zoom Lens LX-IL03ST, 6-Segment BRT color wheel and Lamp Mode is Normal.
*2 Programs and service offerings subject to change without notice. For complete details, including terms and conditions for each program, or to learn more about Service and Support offerings for Canon professional projectors, please contact a Canon sales rep or call 1-800-OK-CANON.
*3 Indicates focus ability range in this chart. Optical feature guaranteed range is: 50-300 in.
*4 Calculated value for 80-inch image.
*5 The maximum upward shift and the maximum horizontal shift cannot be used simultaneously.
*6 Tilting greater than ±15 degrees may decrease lamp life. If the projector is installed at a tilt angle, it is recommended to replace the lamp once it reaches a 50% life span.
*7 Lens LX-IL01UW permits up/down movement by 0-50%, and left/right movement by ±6.7%.
*8 Lens LX-IL07WF does not support lens shifting.
*9 Available image modes vary to some extent depending on the selected input signal and setting.
*10 Once the cable supplied with the screen has been connected, the screen will automatically be adjusted whenever the aspect is changed.
*11 Actual time varies depending on installation environment and usage conditions.
 Return to Top
