Web Content Viewer
Actions
LX-MU800Z
All Projectors
Item Code: 1318C002AA
PROJECTORS.USA.CANON.COM is our website dedicated solely to Canon Projectors.
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
See the contact information for the Canon Projector Account Manager that covers your state.
Features
The LX-MU800Z's laser light source provides large venues with up to 20,000 hours of continuous, reliable, high-quality projection – many times longer than a conventional lamp's life. Because there are no lamps or filters to replace, there is virtually no maintenance required and downtime is minimal. This keeps running costs relatively low when looking at the total life of the product – a key consideration for challenging and hard-to-reach installations, such as auditoriums and lecture halls or hard-to-access digital signage sites.
This projector projects a bright 8000 lumen picture with up to a 10,500:1*1 contrast ratio that helps ensure deep blacks, bright whites and outstanding color. The results are images with crisp depth and dimension, and amazing color accuracy, which is critical to those with discerning needs.
Canon's WUXGA resolution brings bright, true widescreen display of intricately detailed HD video content and still images with outstanding color richness to large-room installations in high resolution WUXGA (1920 x 1200) at a competitive price. Content is projected without compression. Widescreen graphics, text and other visual content from laptops and desktop computers are shown in accurate proportions, just as it appears on most monitor screens.
This projector utilizes Single-chip Digital Light Processing (DLP) technology which is a widely utilized projection technology that creates natural and lifelike images. The DLP technology utilizes a reflective Digital Micromirror Device (DMD) to produce video and images with high brightness. The resulting high-resolution video and images maintain the details inherent in what you are showing.
This projector is up to the challenges of a variety of installation applications given the wide assortment of optional lenses available to help achieve optimal image quality. The eight interchangeable lens options range from a Short Fixed Lens to an Ultra Long Zoom Lens, covering a variety of throw ratios. Screen sizes up to 500-inches*5 are possible with this projector. Please refer to the chart below for the throw ratio, zoom ratio, lens shift and screen sizes available with each optional lens.
For added convenience, this model features a quick release button to quickly install and uninstall lenses.
Lens Ultra Wide
Zoom Lens
LX-IL01UW
Short Fixed
Lens
LX-IL07WF
Wide Zoom
Lens
LX-IL08WZ
Wide Zoom
Lens
LX-IL02WZ
Standard
Zoom Lens
LX-IL03ST
Middle
Zoom Lens
LX-IL04MZ
Long Zoom
Lens
LX-IL05LZ
Ultra Long
Zoom Lens
LX-IL06UL
Throw
Distance
5.31 – 6.69 ft
(1.62 – 2.04m)
- 5.24 ft.
(- 1.66m)
7.57 – 11.38 ft.
(2.31 – 3.47m)
8.89 – 12.72 ft.
(2.71 – 3.88m)
12.23 – 16.14 ft.
(3.73 – 4.92m)
15.74 – 26.24 ft.
(4.8 – 8m)
25.36 – 38.38 ft.
(7.73 – 11.7m)
37.66 – 59.28 ft.
(11.48 – 18.07m)
Throw
Ratio*6
0.75 – 0.93:1 0.76:1 1.07 – 1.61:1 1.25 – 1.79:1 1.73 – 2.27:1 2.22 – 3.67:1 3.58 – 5.38:1 5.31 – 8.26:1
Zoom
Ratio
1.25x
Optical Zoom
Fixed 1.41x
Optical Zoom
1.5x
Optical Zoom
1.3x
Optical Zoom
1.65x
Optical Zoom
1.5x
Optical Zoom
1.55x
Optical Zoom
Size*5
40 – 500 in. 40 – 500 in. 40 – 500 in. 40 – 500 in. 40 – 500 in. 40 – 500 in. 40 – 500 in. 40 – 500 in.
F Number F1.96 – 2.3 F1.85 F1.85 – 2.5 F2.11 – 2.37 F1.7 – 1.9 F1.86 – 2.48 F1.85 – 2.41 F1.85 – 2.48
Focal
Length
11.3 – 14.1mm 11.6mm 18.7 – 26.5mm 15.73 – 23.59mm 26 – 34mm 32.9 – 54.2mm 52.8 – 79.1mm 78.5 – 121.9mm
Lens
Shift*7
V: 0 – 50%
H: ±6.7%
V: 0%
H: ±0%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
Lens Standard
Zoom Lens
LX-IL03ST
Middle
Zoom Lens
LX-IL04MZ
Long Zoom
Lens
LX-IL05LZ
Ultra Long
Zoom Lens
LX-IL06UL
Throw
Distance
12.23 – 16.14 ft.
(3.73 – 4.92m)
15.74 – 26.24 ft.
(4.8 – 8m)
25.36 – 38.38 ft.
(7.73 – 11.7m)
37.66 – 59.28 ft.
(11.48 – 18.07m)
Throw
Ratio *6
Zoom
Ratio
1.3x
Optical Zoom
1.65x
Optical Zoom
1.5x
Optical Zoom
1.55x
Optical Zoom
Size *5
F Number F1.7 – 1.9 F1.86 – 2.48 F1.85 – 2.41 F1.85 – 2.48
Focal
Length
Lens
Shift *7
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
V: 0 – 50%
H: ±10%
This projector is equipped with a built-in HDBaseT receiver facilitating uncompressed HD video, audio and control signals to be transmitted over one single LAN cable with a maximum distance of 100m. This reduces complex wiring schemes used for a typical setup as well as maximizing long cable runs with minimal image quality degradation.
HDBaseT operation may vary when connected to other third-party HDBaseT devices. Please consult with a Canon representative for a full compatibility list.
Portrait Projection*2
This projector can be positioned on its side so that images more suited to portrait projection*2 can be optimally displayed. This is a useful feature for sales promotion, digital signage, museums and art galleries.
360-degree Vertical Installation*8
Setting up the LX-MU800Z is convenient with 360 degrees of rotation that accommodates any angle on the vertical axis. This supports a wide range of installation options, including table and ceiling as well as rear facing, front and down positions. An included High Altitude Mode increases fan speed for maximum efficiency.
Motorized Lens Shift
Motorized vertical and horizontal lens shift allows for adjustment of the image with virtually no distortion. Most lenses can shift up to 0–50% vertically*9,10 and ±10% horizontally*9,10. This model is also equipped with motorized zoom and focus – all of which can be adjusted through the included remote control.
Lens Position Memory
Up to 8 different custom lens presets can be stored and memorized. Each preset includes information for a variety of lens settings such as lens shift, lens zoom and focal length. This makes it easy to switch from one projection set-up to another.
For added convenience, other standard lens settings are also included, such as a Center Lens setting that moves the lens shift, zoom ratio and focal length of the lens to the center position.
Test Patterns
10 test patterns are provided to enable smooth installation and adjustment.
Rotation
The LX-MU800Z allows the projected image to be rotated up to 25 degrees clockwise or anticlockwise without losing any part of the picture.
H/V Alignment
This keystone adjustment feature allows correction of trapezoid-shaped projections so that viewers can see a clearly aligned square-shaped image. It's possible to make adjustments horizontally and vertically to achieve optimum positioning with no need to physically move the projector.
4-point Keystone Correction
Additional installation convenience is provided by 4-point Keystone Correction, which includes independent corner image adjustments to accurately correct for situations in which the position of the projector may be slightly angled with respect to the projection screen. This feature is also critical for applications that require precise projection stacking.
Edge Blending
The Edge Blending function enables the user to combine multiple images to create a seamless, extra-wide projection. Advanced functions allow for color blending and black level adjustments to maximize image quality.
Brightness Adjustments
Brightness can be adjusted for different environments, source material and individual preferences. Precise corrections can be made easily by remote control in a range of approximately 20% to 100% with adjustment of light source power*11 by 1%. This feature ensures seamless brightness when combining two projected images into one with Edge Blending.
This projector includes pre-set Image Modes and additional customizable Image Modes to suit a wide range of user preferences and projection environments.
Multiple Image Modes*12
Image Modes provide different variations of color reproduction characteristics suitable for the image type and projection environment. They include:
Standard: Ideal for bright rooms, and when using content from computer screens or motion picture content.
Presentation: Ideal for somewhat bright rooms when text needs to be clear, such as when part of a video presentation.
Video: Ideal for rooms that are somewhat dark, and for video content.
This projector offers extensive image quality adjustments to help users customize the image to meet their specific projection needs.
Image Adjustments
The Image Adjustment settings allow users to customize the image and color characteristics to fulfill their specific imaging needs. These include:
Brightness
Contrast
Sharpness
Gamma
Noise Reduction
White Gain
Offset (RGB)
Dynamic Black
Color Adjustments
• Color Temperature (Native, 5400K, 6500K, 9300K)
• White Balance (RGB Offset, RGB Gain)
• Hue
• Saturation
• Gain (RGBCMY)
• White Gain (RGB)
Power Mode
Allows the user to select either Full Power to project images at full brightness, or Power Saver which reduces lamp brightness to save energy. A Custom Power Level mode is also available, allowing the user to maximize TCO by adjusting power to their preferences.
This projector includes a built-in HDBaseT receiver so uncompressed HD video, audio and control signals can be transmitted over one single LAN cable up to a maximum distance of 100m. This reduces complex wiring and maximizes long cable runs with minimal image quality degradation. Other connections include: 3G-SDI, HDMI and DVI-D, for sending and receiving large data volumes to support various applications that surpass standard HDTV, such as high-definition display devices and 3D displays; as well as a VGA connector, 5-BNC connectors and a LAN connection terminal for wired transmission of image and audio signals from a PC. Industry-standard control and networking inputs include a network-ready RJ-45 port enabling authorized users to manage and control multiple projectors from any PC on a network (Gigabit data transfer speeds are supported), an RS-232 serial connection for monitoring the projector locally through a third-party control system; a mini-jack that provides a trigger for screen operation and a mini-jack for connecting an optional hand-held wired remote controller.
Compatibility with Crestron, AMX Device Discovery and Extron helps ensure seamless integration into most systems or infrastructures and smooth network management. Support for PJLink also makes it possible to control and monitor the projector over a network – this feature is ideal for observing lamp hours, usage and much more.
Canon 3-Year Projector & Lamp Limited Warranty
All Canon Projectors offer peace of mind as they are backed by Canon USA's Projector and Lamp Limited Warranty, which guarantees that the projector will be free from defects in workmanship and materials for 3 years from the date of original purchase, and the Lamp for 120 days from the date of original purchase. For complete terms and conditions click here.
3-Year Advanced Warranty Exchange Service Program*3
The Canon 3-Year Advanced Warranty Exchange Service Program*3 provides you with enhanced warranty service in addition to traditional "mail-in" repair service. The exchange program provides a replacement unit in exchange for your eligible inoperative Canon Projector if repair service is required during the product's limited warranty period.
3-Year Service Loaner Program*3
The Canon Service Loaner Program*3 provides a loaner product in the event that your eligible Canon Projector is in need of repair during the limited warranty period. The loaner projector may be used while your inoperative unit is being serviced via Canon's "mail-in" repair service.
Extended Service Plan*3
Canon CarePAK PRO AV Extended Service Plan*3 offer options for one year or two years additional coverage for up to five full years of service and support from the date the Canon REALiS PRO AV Installation Projector is purchased.
Projector Specifications
Imaging Device
DMD x1
Aspect Ratio
16:10
Native Resolution
1920 x 1200 (WUXGA)
Brightness
8000lm *1*2
Uniformity
90% *1
Contrast Ratio
1050:1/10,500:1 (Dynamic Black Off/On) *1
Digital Keystone
V±40°, H±60°
Optics (Projector Lens)
*Please see lens information at the bottom*
Image Adjustments
Image Modes
Presentation, Standard, Video
Color Adjustment
n/a
Screen Color Correction
n/a
Mounting
360°
Adjustable Feet
Front 2: Rear: 2
Image Signals
Scanning Frequency
H: 15.62KHz ~ 91.15KHz, V: 24Hz ~ 85.06Hz
Analog PC Input
WUXGA/WSXGA+ /UXGA/SXGA+/WXGA+/WXGA/SXGA/XGA/SVGA/VGA
Digital PC Input
Analog Video Input
n/a
Component Input
1080p/1080i/720p/576p/480p
Digital Video Input
1080p/1080i/720p/576p/480p/576i/480i
Dot Clock
157.5 MHz
Terminals
Dsub15 (Computer-1)
Analog PC / Component Video Input
5BNC (Computer-2)
DVI-D
Digital PC / Digital Video Input
HDMI
DisplayPort
n/a
RJ-45
HDbaseT Input / Network Connection (100BASE-TX / 10BASE-T)
Dsub15 (Monitor-out)
Image Output
5BNC (3G-SDI)
1x Input, 1x Output
Dsub9 (Control)
RS-232 Connection
USB Mini B
n/a
3D Sync Out
n/a
Mini Jack (Trigger)
For Picture Control
Mini Jack (Remote)
Wired Remote Control Connection
Remote Control
Wireless Remote
IR
Built-In Sound
Internal Amplifier
n/a
Lamp
Type
Laser/Phosphor
Life
20,000 hours *4
Power
n/a
Rating
Fan Noise
40/37dB *2
Power Consumption
890/845W *2
Standby Power Consumption
6.0/0.5W *3
Heat Dissipation
Up to 3,038 BTU/h
Power Voltage
AC 100 - 240V, 50/60Hz
Operating Temperature
40°F - 104°F
Storage Temperature
n/a
Dimensions (W x D x H)
19.68", 8.50", 23.38"
Weight
61.7lbs.
Notes
*1: When using a standard zoom lens (LX-IL03ST)
*2: Power mode of Laser is Normal/Eco
*3: Standby power is On/Off
*4: Life based on an average value of usage time when the brightness of the laser light source drops to approximately 50% of what it was from first use.
Optics (8 Interchangeable Genuine Canon Lenses)
LX-IL01UW - Ultra Wide Zoom Lens
PROJECTION LENS
F1.96 ~ 2.3/ f= 11.3 - 14.1mm
LENS SHIFT
V: 0 - 50%, H: ±6.7%
ZOOM
1.25x
FOCUS
40 - 500" **2
SCREEN SIZE
40 - 500"
PROJECTION DISTANCE
5.31' - 6.69' (1.62 - 2.04m)
THROW RATIO
0.75 - 0.93:1 **1
RS-IL02WZ - Wide Zoom Lens
PROJECTION LENS
F1.85 - 2.5 / f= 18.7 - 26.5mm
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.41x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
8.89' - 12.72' (2.71 - 3.88m)
THROW RATIO
1.25 - 1.79:1 **1
LX-IL03ST - Standard Zoom Lens
PROJECTION LENS
F1.7 - 1.9 / f= 26 - 34mm
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.3x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
12.23' - 16.14' (3.73 - 4.92m)
THROW RATIO
1.73 - 2.27:1 **1
LX-IL04MZ - Middle Zoom Lens
PROJECTION LENS
F1.86 - 2.48 / f= 32.9 - 54.2mm
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.65x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
15.74' - 26.24' ( 4.8 - 8m)
THROW RATIO
2.22 - 3.67:1 **1
LX-IL05LZ - Long Zoom Lens
PROJECTION LENS
F1.85 - 2.41 / f= 52.9 - 79.1mm
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.5x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
25.36' - 38.38' (7.73 - 11.7m)
THROW RATIO
3.58 - 5.38:1 **1
LX-IL06UL - Ultra Long Zoom Lens
PROJECTION LENS
F1.85 - 2.48 / f= 78.5 - 121.9mm
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.55x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
37.66' - 59.28' 11.48 - 18.07m
THROW RATIO
5.31 - 8.26:1 **1
LX-IL07WF - Short Fixed Lens
PROJECTION LENS
F1.85 / f= 11.6mm
LENS SHIFT
V: 0%, H: 0%
ZOOM
Fixed
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
-5.24' (-1.66m) **3
THROW RATIO
0.76:1 **1
LX-IL08WZ - Wide Zoom Lens
PROJECTION LENS
F2.11 -2.37
LENS SHIFT
V: 0 - 50%, H: ±10%
ZOOM
1.5x
FOCUS
Powered
SCREEN SIZE
40 - 500" **2
PROJECTION DISTANCE
7.57' -11.38' (2.31 -3.47m)**3
THROW RATIO
1.07 - 1.61:1 **1
Notes
**1: Calculated value for 80" Image
**2: Indicates focus ability range in the chart. Optical feature guaranteed range is: 50 - 300"
**3: Calculated for 100" image.
LX-MU800Z Box Contents
  • LX-MU800Z Pro AV Projector
  • Dust Cap
  • Power Cord
  • VGA to VGA Connection Cable (Mini Dsub15-Mini Dsub15)
  • Projector Remote Control LX-RC01 (includes two AA batteries)
  • Anti-Theft Screw For Lens (used to prevent mounted projection lens from being removed)
  • Important Information Guide (book)
  • User's Manual (CD-ROM)
  • Warranty Card
This is to make Misc appear on the page when needed.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LX-MU800Z that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Awards
College Planning & Management 2016 New Product of the Year Award Program "Gold in A/V Equipment"
The LX-MU800Z Laser DLP Projector was awarded Gold in the College Planning & Management 2016 New Product Award Program. This program honors the outstanding product development achievements of manufacturers and suppliers whose products or services are considered to be particularly noteworthy in their ability to improve the learning environment
Learn More
A&E Specifications
A&E Specifications
File Description:
Date:
07/19/17
Size:
1.45 MB
Drawings / 3D CAD
File Description:
Date:
07/19/17
Size:
633 KB
Date:
07/19/17
Size:
1.11 MB
Date:
07/19/17
Size:
471 KB
Date:
07/19/17
Size:
7.62 MB
File Description:
Date:
07/19/17
Size:
1.86 MB
DISCLAIMERS
*1 10500:1 with Dynamic Black on and 1050:1 with Dynamic Black off.
*2 For Portrait Projection a mount would be needed to allow for proper air flow. Using the projector in portrait projection may reduce the lifetime of optical parts when the lens faces downward during projection and when the air intake vent of the projector faces downward during portrait projection.
*3 Programs and service offerings subject to change without notice. For complete details, including terms and conditions for each program, or to learn more about Service and Support offerings for Canon professional projectors, please contact a Canon sales rep or call 1-800-OK-CANON.
*4 Compared with LX-MU700 (using conventional lamp)
*5 Indicates focus ability range in this chart. Optical feature guaranteed range is: 50–300 in.
*6 Calculated value for 80-inch image.
*7 The maximum upward shift and the maximum horizontal shift cannot be used simultaneously.
*8 When standing the projector straight up or down, lamp life may be shortened.
*9 Lens LX-IL01UW permits up/down movement by 0–50%, and left/right movement by ±6.7%.
*10 Lens LX-IL07WF does not support lens shifting.
*11 Light source power is not equivalent to brightness.
*12 Available image modes vary to some extent depending on the selected input signal and setting.
 Return to Top
