Web Content Viewer
Actions
Rayo S1
All Projectors
Item Code: 3481V070
Features
Your office or home. At a friend's house. Inside a camping tent. Your hotel room while on vacation—plenty of places you'll discover on your own. Weighing approximately half a pound, the Rayo S1 is so compact that it can fit in your pocket or bag to have with you at all times.
What a View
Pretty much whatever you want to view and share, you can with the Rayo S1. Whether it's presentations or documents among co-workers at the office, a movie with the family from an app or USB drive, photos on your phone or your Canon digital camera (compatible with the Canon Camera Connect app***) or simply browsing the web, you can project it all with up to 100 lumens of brightness in WVGA resolution, at up to 84 inches in size.
*** Compatible with iOS® versions 9.3/10.3/11.2, Android smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1/8.0/8.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
Simple to the Touch
You'll love how simple the Rayo S1 is to use, even from the very first time. Just turn the projector on, aim it at the wall, the optional screen or whatever you choose as your canvas, and easily access what you'd like to project with the convenient Smart Touch Pad.
Sound On
The Rayo S1 provides impressive sound quality for your movies and can even be used as a remote Bluetooth®* speaker to listen to your favorite playlists from your compatible devices.
* Bluetooth® and Projector mode cannot be used together. During a Bluetooth® connection, the quality of communication can vary depending on the connected device or environment. The company is not responsible for any problems resulting from loss, blocking, or misuse of data transmitted or received by using the Bluetooth® function. If there is an interfering object between devices that transmits and receives data, the effective network connectivity range can decrease. It may be incompatible with some devices, including devices not certified by Bluetooth® SIG (Special Interest Group). Do not use the Bluetooth® function for illegal activities (illegal copying, air transmission, or transmission for profits and etc.). The company is not liable for any problems resulting from these actions.
Project and Reflect
With the Rayo S1's built-in Wi-Fi®**, you can pair your compatible mobile device and mirror its screen to project anytime, anywhere. Documents. Photos. Apps. Whatever you have, you can share.
** The applications running and other operations on the smart device can delay the transmission speed during a wireless connection. The performance of the wireless connection can vary depending on the OS type of your smart device and the wireless environment of your manufacturer. With "SoftAP" mounted, a wireless connection for mirroring can occur within an external router. Before using the DLNA, make sure that a wireless supported smart device or laptop has a DLNA supported application or media players installed. For more details, see the user guide of your device. For smart devices running on Android OS, Android OS 4.2.2 or later is required to set up a mirroring connection. For iOS® devices, iOS® 8.0 or later is required to use the sharing function. When you set up a mirroring connection from a Windows computer, specifications for graphics, wireless LAN, hardware, and software of Windows® 8.1 or later are required. At a DLNA-based wireless connection, the Internet connection of the smart device will use a 3G/4G connection. When you play a video from the middle after setting up a wireless connection to a smart device, buffering may occur depending on the type of a player on the device. So, make sure to play from videos from the beginning. When you change the wireless connection mode (Bluetooth® or Projector), make sure to end the connection with the device and check for the availability of connection before switching the mode. The quality of the wireless connection can vary depending on the device and the access environment.
Power Player
Power can be hard to come by, but through a USB connection, the Rayo S1 is also a charger that supplies battery power to your mobile device when needed.
The Rayo S1 makes it easy to download your favorite streaming apps, games, books and more so that you can enjoy the content you want almost anytime and anywhere.
Use Your Memory
With 4GB of internal memory, you can store documents, videos, images, apps and more for quick, convenient access right from the Rayo S1 itself.
The Rayo S1 provides built-in Wi-Fi®** and a built-in web browser, allowing you to easily access the Internet from the projector itself and navigate using the Smart Touch Pad.
Camera to Projector
The Canon Camera Connect app*** comes pre-installed with the Rayo S1. Via built-in Wi-Fi®** or Bluetooth®*, it allows you to easily connect to your compatible Canon digital camera and directly share images and videos.
Rechargeable Battery
The Rayo S1 has a built-in rechargeable battery, providing up to 120 minutes of power on a single charge.
Connect any device with a USB cable to the Rayo S1 with the included USB terminal. Plus, listen to clear sound that's just for you with the convenient headphone jack.
Flexible Angles
When a flat surface or certain height won't do, make the easy adjustment with an optional tripod to get the angle you prefer.
Specifications
Projector Specifications
Input Power
DC 5V, 2A
Power Consumption
9W
Standby Power
0.04W
Image Element
DMD device (Aspect ratio 16:9)
Projection Lens
Pixels: 409920 pixels (854x480 WVGA)
Projection Distance: 19.7–118.1 in. / 0.5–3m
Zoom Ratio: Fixed (854x480)
Focus: Manual
Light Source
RGB LED
High-pressure Lamp (Output standard: 3W)
LED (Lifetime: Approx. 10,000 hrs.)
Screen Size
14-84 in. (0.4-2.1m)
Color Reproduction
Full Color
Optical Power
Standard: 70 lumens Maximum: 100 lumens
Contrast Ratio
800:1
Projection Ratio
1.6:1
Output Resolution
WVGA (854x480)
Input Resolution
Full HD (1920x1080)
Offset
100%
Input Connect
USB Type-A
Bluetooth® 4.0
Output Connect
Audio jack (Ø 3.5mm stereo mini jack)
Wireless Standard
Wi-Fi® (Android™ OS/iOS®/Windows® OS)
Power Frequency: 2.4GHz/5GHz
Channel: 802.11 a/b/g/
Speaker
3W Woofer, Mono
Battery
14.06Wh (3.7V, 3,800mAh)
Charging time: Max. 4 hrs.
Playing time: Max. 2 hrs.
OS
Android™ 7.1.2
Memory
4GB internal
USB Charging
1A/h (Battery life: Charge-discharge 300 times)
LED Alert
Charge status alert: DUAL (Red: Charging / Green: Charging completed)
Bluetooth® status alert: SINGLE (Blue)
Noise
18dB
Dimensions (W x H x D)
Approx. 4.13 x 4.13 x 0.79 in. / 105 x 105 x 20mm
Weight
Approx. 0.52 lbs. / 235g
Environment
Temperature: 32-104 °F / 0-40 °C
Power: DC 5V, 0.5A~2A
Rayo S1 Box Contents
Rayo S1 Box Contents Rayo S1 Body USB Charger USB Type-A
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Rayo S1 Mini that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Videos
Canon Rayo S1 Mini Projector Introduction Video
The Rayo S1 is a lightweight, pocket-sized mini projector for business and home use, letting you project presentations, office documents, videos, photos and the web almost anywhere and anytime. It’s also a Bluetooth speaker, a mobile device charger, and more.
This is to make Misc appear on the page when needed.
DISCLAIMERS
The Rayo S1 has not been authorized as required by the rules of the Federal Communications Commission. This device is not, and may not be, offered for sale or lease, or sold or leased, until authorization is obtained.
 Return to Top
