Web Content Viewer
Actions
REALiS WUX500 D Pro AV
All Projectors
Item Code: 0071C011AA
PROJECTORS.USA.CANON.COM is our website dedicated solely to Canon Projectors.
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
See the contact information for the Canon Projector Account Manager that covers your state.
Features
This projector offers a DICOM Simulation Mode to simulate the results of devices compliant with the Digital Imaging and Communications in Medicine (DICOM) Part 14 standardized display function for display of grayscale images. The DICOM Simulation Mode adjusts the gradation between the minimum and the maximum luminance so gradation is distributed optimally. This feature is optimized for displaying medical images such as X-rays, CAT scans and MRIs, which makes this projector ideal for non-diagnostic purposes such as lectures, academic meetings and in-hospital conferences. This feature is recommended for use in medical schools for training and educational use only.
Clear-Base
DICOMM Simulation Mode
This projector projects bright 5000 lumen* images with up to a 2000:1 contrast ratio that helps ensure deep blacks, bright whites and outstanding color. The results are images with crisp depth and dimension, and amazing color accuracy, which is critical to those with discerning needs.
5000 Lumens
* When in Presentation Mode and lamp is set to Full Power Mode.
Canon's WUXGA resolution brings bright, true widescreen display of intricately detailed HD video content and still images with outstanding color richness to large-room installations in high resolution WUXGA (1920 x 1200) at a competitive price. Content is projected without compression. Widescreen graphics, text and other visual content from laptops and desktop computers are shown in accurate proportions, just as it appears on most monitor screens.
The exceptional imaging performance of this projector starts with Canon's proprietary AISYS (Aspectual Illumination System) Optical Engine, which utilizes advanced light management technology to maximize the contrast and brightness benefits of the projector's LCOS (Liquid Crystal on Silicon) display panels, which deliver superior reflectivity and durability while accomplishing high luminance. The result is highly detailed, seamless, ultra-sharp image projection in virtually any environment.
Drawing on Canon’s advanced optical expertise, this projector utilizes Genuine Canon Optics to project high-quality, virtually distortion-free images. Featuring a consistent F-Stop equivalent of F2.8, makes it possible to virtually maintain brightness throughout the zoom range with virtually no light loss, helping to maximize performance with installation flexibility.
These advanced designed optics employ dual-sided aspherical lens elements and Ultra Low Dispersion (UD) lens elements that significantly reduce chromatic aberration, ghosting and flare. This produces sharper, clearer images. The innovative optical system design also minimizes the total size of the optical system, enabling this projector to be smaller in size than other comparable systems.
Compact Design
This projector creates high resolution images within an incredibly compact projector size. The innovative AISYS Optical Engine makes this possible by independently controlling light in both vertical and horizontal directions to achieve both high brightness and contrast. Combined with the small size of the LCOS panels (just 0.76 inches), the projector is incredibly compact while delivering outstanding performance. At a height of 5.3 inches, width of 13.2 inches and weight of 13 pounds, it’s small and light enough to fit in a variety of spaces.
4-Point Keystone Correction
The Canon REALiS WUX500 D features 4-Point independent Keystone Correction that has been added to the WUX500 D giving the user the ability to adjust corners with precise accuracy. Furthermore, it allows the corners of the image to be independently adjusted to help ensure optimal image reproduction.
Manual Lens Shift
Manual lens shift makes it possible to adjust the image without digital distortion. The lens can be adjusted in both vertical and horizontal directions. Maximum lens shift is 0% - 60% vertical, +-10% horizontal.
Edge Blending
The Edge Blending function enables the user to combine multiple images to create a seamless projection. Advanced functions allow for color blending and black level adjustments to maximize image quality.
PC-Free Multi Projection
Multi-Projection: Up to nine REALiS WUX500 Ds can be networked together to project one full image without the use of a computer. This is accomplished by setting one projector as a “master” and all others as “slaves”. The “master” projector reads the JPEG image that is input via the USB port and then distributes the information to the other projectors. Finally, all projectors work together to display a complete image.
The WUX500 D is equipped with the following interfaces:
Video:
• DVI-I (Digital PC/Analog PC1)
• HDMI
• Mini Dsub15 (Analog PC2/Component Video)
Audio:
• Mini Jack (input) x3 (Stereo Sound)
• Mini Jack (output) (Stereo Sound)
Control:
• Dsub9 (RS-232C Connection)
• Mini Jack (Wired Remote Control Connection)
• RJ45
WIFI:
• Internal Card
HDBaseT
This projector is equipped with a built-in HDBaseT receiver facilitating uncompressed HD video, audio and control signals to be transmitted over one single LAN cable with a maximum distance of 100m. This reduces complex wiring schemes used for a typical setup as well as maximizing long cable runs with minimal image quality degradation.
HDBaseT operation may vary when connected to other third-party HDBaseT devices. Please consult with a Canon representative for a full compatibility list.
NMPJ (Network Multi Projection) With Wi-Fi
Network Multi Projection (NMPJ) is a function that projects video data from computers via a network. It offers a range of applications from a simple point-to-point direct connection to connecting multiple projectors to a number of computers. The Canon REALiS WUX500 D is equipped with Wi-Fi, which utilizes two modes of connection. The Projector Access Point mode allows users to directly connect up to five computers wirelessly. The Infrastructure mode enables the REALiS WUX500 D to connect to an existing network wirelessly, computers on this network (wirelessly or wired) are now connected and can start projecting by utilizing NMPJ function. There are 4 NMPJ modes to choose from:
Direct Mode: In this mode the user can connect directly to the projector using a network cable or can connect directly to the network where the projector is located. The user can connect 1 PC and use 1 projector.
Meeting Mode: This mode is for sharing materials among all meeting attendees, it also enables remote operation and sharing via the internet between bases in different locations. The benefit of this mode is that each PC can select multiple projectors as projector operation is enabled from each PC. This mode allows the user to connect up to 10 PCs and 6 projectors.
Classroom Mode: The instructor can decide which attendee PCs will connect with which projectors and can switch the attendee projections as the class progresses. The benefit of this mode is that one PC (instructor) selects which PCs (students) to project from and controls the projectors. Certain operations are enabled from the client PCs (students), however they're limited. In this mode the user can connect up to 10 PCs and 6 projectors.
Broadcast Mode: This mode enables one PC to connect up to 12 projectors.
Low Power Consumption and Simplified Maintenance
This projector uses a relatively low amount of power per lumen. It offers multiple power-management settings that allow the user to preset stand-by durations, execute power operations and auto-assign functions to the power button.
The design of this projector also allows for simplified maintenance – air filters and the projection lamp can be replaced while the projector remains ceiling mounted without having to uninstall.
Backed by Canon’s 3-Year Projector and Lamp Limited Warranty, and 3-Year Advanced Warranty Exchange Service Program and Service Loaner Program
This projector is backed by Canon USA's Projector and Lamp Limited Warranty, which ensures the Projector is free from defects in workmanship and materials for 3 years from the date of original purchase. The lamp is similarly covered for 120 days from the date of original purchase.
The Canon 3-Year Advanced Warranty Exchange Service Program*7 provides you with enhanced warranty service in addition to traditional "mail-in" repair service. The exchange program provides a replacement unit in exchange for your eligible inoperative Canon Projector if repair service is required during the product's limited warranty period.
3-Year Service Loaner Program
The Canon 3-Year Service Loaner Program*7 provides a loaner product in the event that your eligible Canon Projector is in need of repair during the limited warranty period. The loaner projector may be used while your inoperative unit is being serviced via Canon's "mail-in" repair service.
To learn more about Canon’s award winning Service & Support, including our 100% U.S.-based call center, visit projectors.usa.canon.com.
*7 Programs and service offerings subject to change without notice. For complete details, including terms and conditions for each program, or to learn more about Service and Support offerings for Canon professional projectors, please contact a Canon sales rep or call 1-800-OK-CANON.
Main Unit Spec
Projector Specifications
Imaging Device
0.71" LCOS Reflective LCD panel x3
Aspect Ratio
16:10
Native Resolution
1920 x 1200 (WUXGA)
Brightness
5000 Lumens (Normal) / 3800 Lumens (Power Saver)
Contrast Ratio
2000:1
Digital Keystone
V±20°, H±20°
Uniformity
90%
Zoom Ratio
1.8x
Electronic Zoom
12x Maximum
Focus
Manual
Lens Shift
Manual V: 0% -60%, H: ±10%
Throw Ratio
1.39 - 2.51:1
Image Adjustments
Image Mode
Standard / Presentation / Dynamic / Photo / sRGB / User 1 / User 2 / User 3 / User 4 / User 5
Color Adjust
Color Level, Color Balance, Color Temperature, Gain (R,G,B), Offset (R,G,B)
Wall Correction
Normal / Greenboard / Adjust (custom)
Mounting
360° projection
Tilt Angle
Bottom Front Feet: 2 places (Max. angles: 6° elevation)
Input Signals
Scanning Frequency
TBD
Analog PC Input
WUXGA / UXGA / WSXGA+ / SXGA+ / WXGA+ / FWXGA / WXGA / SXGA / XGA / SVGA / VGA
Digital PC Input
Component Video Input
1080p / 1080i / 720p / 576p / 576i / 480p / 480i
HDBaseT
Equivalent to the Input Signal of Digital PC Input and Digital Video Input.
USB Data Transfer
JPEG Still Image
Digital Video Input
1080p / 1080i / 720p / 576p / 480p
Dot Clock
TBD
Terminals
DVI-I
Digital PC/Analog PC Input
HDMI
Digital PC/Digital Video Input (supports deep color)
RJ-45 (HDBaseT)
HDBaseT input (image, audio and control signal)
Mini Dsub15
Analog PC/Component Video Input
Mini Jack x3
Audio Input x2, Audio Output x1
Mini Jack x1
Connecting Wired Remote
Dsub9
13.5 ~ 162MHz
Dsub9
RS-232C Connection
USB type A
Service Port
RJ-45
Network Connection (1000BASE-T / 100BASE-TX / 10BASE-T)
WiFi
NMPJ (Network Multi-Projection)
Remote Control
Remotes
Wireless Infrared (supplied) or Wired (optional)
Built-In Sound
Internal Amplifier
5W, Mono
Lamp
Type
250-NSHA lamp
Life
3000 Hours Full Power / 5000 Hours Power Saver
Power
260/200 W
Ratings
Fan Noise
37dB (Full Power) / 30dB (Power Saver)
Power Consumption
365/295 W
Standby Power
1.6 (HDBaseT)0.6 (Network) /0.2 W (Standard)
Heat Dissipation
Up to 1,246 BTU/h
Power Voltage
AC 100 ~ 240V, 50/60 Hz
Operating Temperature
32°F - 104°F (0°C -40°C)
Storage Temperature
14°F - 140°F (-10°C - 60°C)
Dimensions (W x H x D)
W: 13.26"(337 mm), H: 5.35"(136mm), D: 14.56"(370 mm) (including protrusion)
Weight
13 lbs. (5.9 kgs)
Projector Warranty
3 Years (parts and labor)
Lamp Warranty
120 Days
This is to make Misc appear on the page when needed.
WUX500 Projector Kit
WUX500 Projector Kit Projector Lens Cap Power Cord VGA to VGA Connection Cable (Mini Dsub15-Mini Dsub15) Projector Remote Control LV-RC06 (includes two AA batteries) Lamp RS-LP08 Quick Start Guide (book) User's Manual (CD-ROM) Warranty Card
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you REALiS WUX500 D Pro AV that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
A&E Specifications
A&E Specifications
Date:
07/19/17
Size:
409 KB
Drawings / 3D CAD
Date:
10/23/15
Size:
1.39 MB
Date:
01/23/15
Size:
779 KB
Date:
01/23/15
Size:
436 KB
Date:
02/20/15
Size:
1.71 MB
Date:
07/19/17
Size:
1.96 MB
Press Accolades
James Colquhoun Reviews Canon REALiS WUX500 Projector
The REALiS WUX500 is a “feature-packed small projector” that “packs a punch” according to reviewer Jim Colquhoun. This review emphasizes the compact size, high brightness, and "high quality color accuracy" of this impressive model.
ProjectorCentral.com "Highly Rated"
Our new Canon REALiS WUX500 Projector received a rating of "Highly Rated" from ProjectorCentral.com. This thorough review explains how the REALiS WUX500 "comes with some significant advantages including small size, edge blending capability, picture in picture, and the highly unusual ability to maintain almost undiminished maximum brightness throughout its full 1.8:1 zoom range" and the article notes how "This is unique" among projectors they have tested earning the highest ratings in features and ease of use.
DISCLAIMERS
*1 When in Presentation Mode and lamp is set to Full Power Mode.
*2 When standing the projector straight up or down, lamp life may be shortened.
 Return to Top
