Web Content Viewer
Actions
REALiS WUX5800Z Pro AV
All Projectors
Item Code: 2500C002AA
PROJECTORS.USA.CANON.COM is our website dedicated solely to Canon Projectors.
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
See the contact information for the Canon Projector Account Manager that covers your state.
Features
The projector projects bright 5800 lumen images with up to a 4000:1*3 contrast ratio that helps ensure deep blacks, bright whites and outstanding color. The results are images with crisp depth and dimension, and amazing color accuracy, which is critical to those with discerning needs.
*3 All white: all black. When standard RS-SL01ST projection lens used. When the iris function is set to “Close 9.”
Canon's WUXGA resolution brings bright, true widescreen display of highly detailed HD video content and still images with outstanding color richness to large-room installations in high resolution WUXGA (1920 x 1200) at a competitive price. Widescreen graphics, text and other visual content from laptops and desktop computers are shown in accurate proportions from edge to edge with sharp detail.
The projector's laser light source provides up to 20,000*1 hours in standard use of continuous, reliable, high-quality projection. The hours of operation can be nearly doubled when utilizing the Long Duration modes to up to 20 times*7 longer than a conventional lamp's life. Operation is virtually maintenance-free with minimal downtime, as the light source doesn't require routine replacement. This keeps running costs relatively low when looking at the total life of the product – a key consideration for challenging and hard-to-reach installations.
Other advantages of the laser light source include a quick start-up time, installation flexibility and more.
Fast Boot Function
When Fast Boot Function is set to ON, the startup time is reduced to virtually 2 seconds*8 the next time the projector is started from a standby status.
Omnidirectional Projection*2
Because this projector uses a laser light source instead of a conventional lamp it can be installed at any angle on a 360° axis facing in any direction. A Menu Rotation function also enhances portrait projection, allowing adjustment of the angle of the projector's menu up to 90° left and right.
Wider Color Gamut
Because the laser light source produces a wide range of colors, the projector covers the sRGB color space to deliver millions of colors.
Quiet Modes
Quiet Modes reduce the volume of projector operation to around 29 dB for more silent performance to reduce any potential of interfering with audible content.
*1 This is an estimated value, actual hours may vary depending on usage and environment. This is not a guarantee of the life span of individual laser diodes.
*2 Air vents should not be blocked. See User Manual for recommended installation.
*7 Compared with LX-MU700 (using a conventional lamp).
*8 Startup time will change when startup from AC off.
The exceptional imaging performance of the projector starts with Canon's proprietary AISYS (Aspectual Illumination System) Optical Engine. This engine utilizes advanced light management technology to maximize the contrast and brightness benefits of the projector's LCOS (Liquid Crystal on Silicon) display panels, which deliver superior reflectivity and durability while accomplishing high luminance. The result is highly detailed, seamless, ultra-sharp image projection in virtually any environment.
Six optional interchangeable Genuine Canon lenses enable a wide variety of applications for exceptional image quality and flexibility. A spigot lens mount system is designed so that the lens can be quickly and securely installed in virtually seconds. Optional lenses include the Ultra Short Fixed Lens RS-SL06UW, which features compatibility with Marginal Focus for accurate projection onto a spherical surface, a 0.54:1 throw ratio and a generous vertical lens shift of V: -15% – 75%, H: ±30% horizontal.
The projector supports High Dynamic Range (HDR) exhibiting bright highlights and deep blacks for a wider dynamic range. The wider dynamic range expands the contrast and the color, both extremely important factors when it comes to the image. This provides an incredible viewing experience.
The projector includes pre-set Image Modes and additional customizable Image Modes to suit a wide range of user preferences and projection environments.
Multiple Image Modes
Image Modes provide different variations of color reproduction characteristics suitable for the image type and projection environment. They include:
Standard: Ideal for bright rooms, and when using content from computer screens or motion picture content.
Presentation: Ideal for somewhat bright rooms when text needs to be clear, such as when part of a video presentation.
Dynamic: Ideal for rooms that are somewhat bright, and when showing motion picture content.
Vivid Photo: Ideal for rendering rich color brilliantly and reproducing skin tones naturally.
Photo/sRGB: Ideal for projecting images from sRGB-supported digital cameras.
Video: Ideal for rooms that are somewhat dark, and for video content.
Cinema: Ideal for viewing theatrical image content in a room without lighting.
5 Customizable Modes: Ideal for custom set-ups. Provides up to 5 user-selected combinations of image quality settings that can be stored in the memory and selected as an image mode.
DICOM Simulation Mode*4: Ideal for displaying medical images in non-diagnostic settings. Both Blue Base and Clear Base settings are supported.
*4 This projector includes a DICOM Simulation Mode. It has not been cleared or approved for medical diagnosis and should not be used for these purposes.
The projector offers extensive image quality adjustments to help users customize the image to meet their specific projection needs.
Image Adjustments
The Image Adjustment settings allow users to customize the image and color characteristics to fulfill their specific imaging needs. These include:
Brightness
Contrast
Sharpness
Gamma
Color Adjustments
  • Color Level
  • Color Balance
  • Color Temperature
  • Gain (RGB)
  • Offset (RGB)
Advanced Image Adjustments
These adjustments provide greater flexibility to professional users with more options to adjust the image as desired. These settings include:
Ambient Light: This technology allows the user to select the color temperature, lamp type and other characteristics that are in the active environment.
Random Noise Reduction: This feature eliminates minute noise that may appear in the image.
MPEG Noise Reduction: This feature eliminates block noise that may appear when playing back compressed digital images and “mosquito noise” that may appear in a dot pattern near the edges.
Mosquito Noise Reduction: This feature eliminates “mosquito noise” exclusively from still images.
Dynamic Gamma: When applied, this feature analyzes individual areas of the image for specific, independent contrast adjustment so light and dark areas do not appear over- or under-exposed.
Memory Color Correction: This Canon technology can be used to enhance skin tones and other color features for rich, vivid results that look striking to the human eye.
6-Axis Color Adjust: This technology lets users fine-tune the hue and saturation of each of the primary and secondary colors, providing a high degree of control that can make each projected image a “masterpiece.”
Fine-tune Gamma: This setting enables the adjustment of gamma curve, allowing the user to adjust white, red, green and blue.
The projector includes Canon's latest Motion Blur Reduction*5 feature for improved visibility when movement is fast. By inserting extra frames to video content, motion blur is reduced and the clarity of graphics and text on fast-moving objects is preserved. Three different modes (Strong, Low and Off) are included for flexibility, with each depending on the level of movement and type of video content.
*5 When motion blur reduction is activated, brightness will be affected.
Operating Mode
Four work modes allow adjustment to maximize projector life.
  • Normal: Brightness is set by Light Mode settings.
  • Fixed Brightness: Brightness does not change due to aging. Maximum brightness is set at 70–20% of initial brightness.
  • Longer Duration 1: To be used for a long period of time. Maximum brightness is 70–20% of current brightness.
  • Longer Duration 2: Used for longer periods of time. Maximum brightness is set to 50–20% of current brightness.
Furthermore, light emission in the following ranges can be adjusted in the Brightness Level function when Operating Mode is not set to Normal.
Operating Mode Light Source Output
Fixed Brightness 70% – 20%
Longer Duration 1 70% – 20%
Longer Duration 2 50% – 20%
* Values for non-standard light source output and brightness are approximations.
Light Source Mode
To reduce projector noise and cooling fan speed, different light modes can be selected.
Setting Light Source Output Brightness Noise Level
Normal 100% 5800 lumens 35 dB
Quiet 1 70% 4060 lumens 32 dB
Quiet 2 50% 2900 lumens 29 dB
Adjust 20 – 100% 29 – 35 dB
Position Lock
This feature ensures specific installation settings such as Image Flip, Keystone Correction and Lens Position are not accidentally disturbed, saving users time from the inconvenience of reconfiguration.
360-degree Vertical Installation
This feature allows the projector to be positioned anywhere on the vertical axis. A Menu Rotation function also enhances portrait projection, allowing adjustment of the angle of the projector's menu up to 90 degrees left and right. Sensors within the projector sense the angle of the projector and flip the image accordingly in increments of 90 degrees.
4-point Keystone Correction
Allows the corners of the image to be independently adjusted to help ensure optimal image reproduction.
Lens Position Memory
Up to 3 different custom lens presets can be stored and memorized. Each preset includes information for a variety of lens settings.
  • Zoom
  • Focus
  • Lens Shift
  • Keystone
  • Aspect
  • Screen Color Adjustment (Normal, Blackboard, etc.)
  • Digital Image Shift
This is especially convenient for digital signage as this projector makes it easy to switch from one signage set-up to another. The lens presets can also be of use in education where the presets can be used to quickly change the settings from projecting on a screen to the settings needed for projecting on a blackboard.
Screen Color Correction
Enables users to fine-tune the colors of images based on the color of the projection surface. Adjustments can be made from Normal and Greenboard, as well as additional tuning for projecting onto virtually any other colored surface.
Test Patterns
Up to 27 test patterns are provided to enable smooth installation and adjustment.
A variety of advanced installation settings provide added customization options for challenging installation areas.
High Altitude
If the projector sits in high land over 2300 meters above sea level, High Altitude mode enables faster fan speeds to prevent overheating.
Edge Blending
The Edge Blending function enables the user to combine multiple images to create a seamless, extra-wide projection. Advanced functions allow for color blending and black level adjustments to maximize image quality.
Micro-Digital Image Shift
The Micro-Digital Image Shift function shifts the image electrically, using the surplus pixels on the LCOS panel.
Registration
The Registration function modifies the registration by electronically correcting color shift due to changes in alignment of each RGB panel position.
Fan Mode
Fan Mode gives the user the ability to adjust the fan speed to support different environmental workspaces.
Vertical Projection
The Vertical Projection function automatically adjusts fan speeds and other configurations to support vertical installations.
Connections include: HDMI, DVI-I and analog RGB computer connectors; DisplayPort for image and audio signal transmission over a single cable; Wi-Fi® support for NMPJ functions; a VGA connector; and a LAN connection terminal which relays data to a built-in HDBaseT™ receiver for transmission of video and audio signals from a source device. Industry-standard control and networking inputs include a network-ready RJ-45 port enabling authorized users to manage and control multiple projectors from any PC on a network (Gigabit data transfer speeds are supported), an RS-232 serial connection for monitoring the projector locally through a third-party control system, a USB Type A port for easy installation of firmware upgrades and a mini-jack for connecting an optional hand-held wired remote controller.
Built-in network multi projection (NMPJ) function and Wi-Fi® connectivity enable selective sharing of visual content from one or more PCs and laptops, wirelessly or over LAN. Four NMPJ modes enable selective sharing of visual information:
Direct Mode: In this mode, the user can connect directly to the projector using a network cable or can connect directly to the network where the projector is located. The user can connect 1 PC and use 1 projector.
Meeting Mode: This mode is for sharing materials among all meeting attendees. It also enables remote operation and sharing via the internet between bases in different locations. The benefit of this mode is that each PC can select multiple projectors as projector operation is enabled from each PC. This mode allows the user to connect up to 10 PCs and 6 projectors on an infrastructure connection, or 5 PCs and 1 projector on a wireless connection.
Classroom Mode: The instructor can decide which attendee PCs will connect with which projectors and can switch the attendee projections as the class progresses. The benefit of this mode is that one PC (instructor) selects which PCs (students) to project from and controls the projectors. Certain operations are enabled from the client PCs (students), although they're limited. In this mode the user can connect up to 10 PCs and 6 projectors via an infrastructure connection, or 5 PCs and 1 projector via a wireless connection.
Broadcast Mode: This mode enables one PC to connect up to 12 projectors (infrastructure connection only).
NMPJ mode Connection Type Max No. of Projectors Max No. of PCs
Direct Mode Infrastructure 1 1
Meeting Mode Infrastructure 6 10
Classroom Mode Infrastructure 6 10
Broadcast Mode Infrastructure 12 1
Compatibility with Crestron, Extron XTP and AMX Device Discovery helps ensure seamless integration into many systems or infrastructures and smooth network management. Support for PJLink also makes it possible to control and monitor the projector over a network – this feature is ideal for observing lamp hours, usage and much more.
The built-in Real-time Clock allows scheduling of specific operations such as set startup and shutdown at chosen times. This helps to manage power consumption by creating operating schedules which can result in extended projection life. For convenience, Real-time Clock settings can be accessed via the projector's own user-friendly graphical interface.
Multiple power-management settings help to conserve projector life, allowing the user to preset stand-by durations and execute power on and off operations – all with the benefit of a Real-Time Clock, accessible via Web UI or internal GUI.
Canon's free PJ App makes it possible to control Canon projectors remotely and conveniently from iOS® devices. Wi-Fi® connection enables the clear display of the projector menu on the screen of your tablet or smartphone – supporting simplified set-up, operation and maintenance. It's the ideal solution for making adjustments to spherical or domed surface projections, on which menus may be difficult to view and navigate. The app also brings speed and clarity to error correction and allows multi-projection across up to 9 projectors – independently and simultaneously.
Learn more at: http://projectors.usa.canon.com/resources/CanonServiceTool.php
Canon Laser Projector Warranty
All Canon Laser Projectors offer peace of mind as they are backed by Canon USA's Laser Projector Limited Warranty, which guarantees that the projector will be free from defects in workmanship and materials for 5 years from the date of original purchase or 12,000 hours of use (whichever occurs first). For complete terms and conditions click here.
Advanced Warranty Exchange Service Program*6
The Canon Advanced Warranty Exchange Service Program*6 provides you with enhanced warranty service in addition to traditional “mail-in” repair service. The exchange program provides a replacement unit in exchange for your eligible inoperative Canon Projector if repair service is required during the product's limited warranty period.
Service Loaner Program*6
The Canon Service Loaner Program*6 provides a loaner product in the event that your eligible Canon Projector is in need of repair during the limited warranty period. The loaner projector may be used while your inoperative unit is being serviced via Canon's “mail-in” repair service.
CarePAK PRO AV Extended Service Plan*6
The Canon CarePAK PRO AV Extended Service Plan*6 offers options for one year or two years additional coverage for up to five full years of service and support from the date the Projector is purchased (only available on select models).
*6 Programs and service offerings subject to change without notice. For complete details, including terms and conditions for each program, or to learn more about Service and Support offerings for Canon professional projectors, please contact a Canon sales rep or call 1-800-OK-CANON.
Main Unit Spec
Projector Specifications
Imaging Device
0.71", LCOS Panel x3
Native Aspect Ratio
16:10
Native Resolution
1920 x 1200 (WUXGA)
Brightness
5800/4060/2900 lm *1*2*3*4
Uniformity
90% *3
Contrast Ratio
4000:1 *3*8 (all white: all black)
Digital Keystone
V: ±20°, H: ±20°
Image Size
40" - 600" *3
Optics
F Number, Focal Length
F1.89 - F2.65 *3
Zoom
1.5x *3
Focus
Powered *3
Throw Ratio
1.49 - 2.24:1 *3
Lens Shift
V:55% / -15%, H:10% / -10% *3*6
Image Adjustments
Image Modes
Standard, Presentation, Dynamic, Vivid Photo, Video, Cinema, Photo/sRGB, DICOM SIM, User 1 ~ 5
Color Adjustment
Color Level, Color Balance, Color Temperature, Gain (R,G,B), Offset (R,G,B)
Normal / Greenboard / Adjust (custom)
Mounting
360°
Adjustable Feet
4x, Extension Length: 14.6 mm, Maximum angle of inclination: ± 1.8°
Image Signals
Scanning Frequency
H: 15.625kHz ~ 75kHz, V: 24Hz ~ 60Hz
HDMI (Digital PC Input)
WUXGA, UXGA, WSXGA+, SXGA+, WXGA+, FWXGA, WXGA, SXGA, XGA, SVGA, VGA
HDMI (Digital Video Input)
1080P, 1080i, 720P, 576p
DVI-I (Digital PC Input)
DVI-I (Analog PC Input)
Display Port
1080P, 1080I, 720P, 576p, 576i, 480p, 480i *9
Mini Dsub15 (Analog PC Input)
Mini Dsub15 (Component Video Input)
RJ-45 (HDBaseT Input)
Image, Audio, Control, Network; Equivalent to image and audio of HDMI/DP
RJ-45 (Network Connection)
100BASE-TX, NMPJ screen transfer
USB Type A
JPEG still image (10912x8640)(Maximum pixels)
Dot Clock
162MHz (maximum)
Terminals
DVI-I
Digital PC/ Analog PC Input
HDMI
Digital PC/Digital Video Input
Display Port
Mini Dsub15
Analog PC2/Component Video Input
Mini Jack
Stereo Audio
Stereo Audio
Wired Remote Control Connection
Dsub9
RS-232 Connection
USB Type A
USB Connection
WiFi
IEEE 802.11b/g/n
RJ-45
HDBaseT/Network
Remote Control
Wireless Remote
Infrared
Built-In Sound
Internal Speaker
1W
Light Source
Type
Blue Laser Diode, Yellow Phosphor
Life
Aprox. 20,000 *5
Ratings
Fan Noise
35/32/29 dB *1
Power Consumption
485 W
Standby Power Consumption
1.6 ~.28 W *5
Power Voltage
AC100 - 240V : 50/60 Hz
Heat Dissipation
Up to 1655 BTU/h
Operating Temperature
32°F - 104°F (0°C - 40°C), 20%RH - 85%RH
Storage Temperature
-4°F - 140°F (-20°C - 60°C)
Weight
37.4 lbs. (17kg) approx.
Dimensions (W x H x D)
W: 19" (480mm), H: 7.7" (196mm), D: 21.4" (545 mm)
Notes
*1: Normal / Quiet 1 / Quiet 2
*2: The luminance values for modes other than Normal are calculated and are not guaranteed as specification
*3: When standard RS-SL01ST projection lens used
*4: When image mode is set to Presentation
*5: This value does not guarantee the service life
*6: When lens shift mode set to "NORMAL"
*7: Varies when network and other settings applied
*8: When the iris function is set to "Close 9"
*9: Supports image signals equivalent to the HDMI terminal
This is to make Misc appear on the page when needed.
WUX5800Z Box Contents
WUX5800Z Box Contents REALiS WUX5800Z Pro AV Projector Power Cord Projector Remote Control RS-RC07 (includes two AAA batteries) Important Information (book) Warranty Card
Brochures
Loading...
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you REALiS WUX5800Z Pro AV that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
A&E Specifications
A&E Specifications
Date:
02/28/18
Size:
466 KB
Drawings / 3D CAD
Date:
02/28/18
Size:
1.20 MB
Date:
02/28/18
Size:
814 KB
Date:
02/28/18
Size:
409 KB
Date:
02/28/18
Size:
4.00 MB
Videos
Introducing the Canon REALiS LCOS Projectors
Watch and learn about exciting additions to Canon’s award-winning lineup of REALiS LCOS Projectors.
DISCLAIMERS
*3 All white: all black. When standard RS-SL01ST projection lens used. When the iris function is set to "Close 9."
 Return to Top
