Web Content Viewer
Actions
REALiS WUX7500 Pro AV
All Projectors
PROJECTORS.USA.CANON.COM is our website dedicated solely to Canon Projectors.
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
See the contact information for the Canon Projector Account Manager that covers your state.
Features
  • Up to 7500 Lumens and 2000:1*1 Contrast Ratio Delivers Bright, Engaging Images
  • Native WUXGA Resolution (1920 x 1200)
  • LCOS Technology with AISYS-enhancement
  • Six Optional Genuine Canon Interchangeable Lenses with Spigot Lens Mount System and Ultra Short Fixed Lens RS-SL06UW with V: -15% - 75%, H: ±30% Lens Shift
  • Multiple Image Modes including DICOM Simulation Mode*3 for Optimal Image Quality Reproduction
  • Image Adjustment and Advanced Adjustment Options for Customizable Image Characteristics
  • Motion Blur Reduction*4 with Low-delay Playback
  • Quiet Operation up to 27dB*2
  • Advanced Professional Installation Settings including Built-in Edge Blending and Advanced Registration
  • Versatile Connectivity - HDBaseT™, HDMI, DVI-I, DisplayPort, Wi-Fi® Connectivity, USB Type A, RJ-45, RS-232 and Audio Inputs
  • Network Multi Projection (NMPJ) over Wi-Fi®
  • Network Management including PJLink™, Crestron Connectivity and AMX Device Discovery
  • Built-in Real-time Clock
  • Low Power Consumption and Simplified Maintenance
  • Canon Service Tool for PJ
  • Backed by Canon's 3-Year Limited Warranty including the Advanced Warranty Service Exchange Program and Service Loaner Program*5
This is to make Misc appear on the page when needed.
Main Unit Spec
Projector Specifications
Imaging Device
0.71", LCOS Panel x3
Native Aspect Ratio
16:10
Native Resolution
1920 x 1200 (WUXGA)
Brightness
7500/5200/4500lm *1*2*3
Uniformity
90% *3
Contrast Ratio
2000:1 *3*4(all white: all black)
Digital Keystone
V: ±20°, H: ±20°
Image Size
40" - 600" *3
Optics
F Number, Focal Length
F1.89 - F2.67 *3
Zoom
1.5x *3
Focus
Powered *3
Throw Ratio
1.49 - 2.24:1 *3
Lens Shift
V:55% / -15%, H:10% / -10% *3
Image Adjustments
Image Modes
Standard, Presentation, Dynamic, Vivid Photo, Video, Cinema, Photo/sRGB, DICOM SIM, User 1 ~ 5
Color Adjustment
Color Level, Color Balance, Color Temperature, Gain (R,G,B), Offset (R,G,B)
Screen Color Correction
Normal / Greenboard / Adjust (custom)
Mounting
Ceiling, Table, Rear, Rear Ceiling, Rear Table
Adjustable Feet
4x, Extension Length: 14.6 mm, Maximum angle of inclination: ± 1.8°
Image Signals
Scanning Frequency
H: 15.625kHz ~ 75kHz, V: 24Hz ~ 60Hz
HDMI (Digital PC Input)
WUXGA, UXGA, WSXGA+, SXGA+, WXGA+, FWXGA, WXGA, SXGA, XGA, SVGA, VGA
HDMI (Digital Video Input)
1080P, 1080i, 720P, 576p
DVI-I (Digital PC Input)
DVI-I (Analog PC Input)
Display Port
1080P, 1080I, 720P, 576p, 576i, 480p, 480i *7
Mini Dsub15 (Analog PC Input)
Mini Dsub15 (Component Video Input)
RJ-45 (HDBaseT Input)
Image, Audio, Control, Network; Equivalent to image and audio of HDMI/DP
RJ-45 (Network Connection)
100BASE-TX, NMPJ screen transfer
USB Type A
JPEG still image (10912x8640)(Maximum pixels)
Dot Clock
162MHz (maximum)
Terminals
DVI-I
Digital PC/ Analog PC Input
HDMI
Digital PC/Digital Video Input
Display Port
Mini Dsub15
Analog PC2/Component Video Input
Mini Jack
Stereo Audio
Stereo Audio
Wired Remote Control Connection
Dsub9
RS-232 Connection
USB Type A
USB Connection
WiFi
IEEE 802.11b/g/n
RJ-45
HDBaseT/Network
Remote Control
Wireless Remote
Infrared
Built-In Sound
Internal Speaker
1W
Light Source
Type
Super High Pressure Lamp
Life
3000/4000/3000 *1
Ratings
Fan Noise
40/29/27 dB *1
Power Consumption
430/300/262 W *1
Standby Power Consumption
1.6 ~ 0.28 W *6
Power Voltage
AC100 - 240 V, 50/60 Hz
Heat Dissipation
1843 BTU/h
Operating Temperature
32°F - 104°F (0°C - 40°C), 20%RH - 85%RH
Storage Temperature
-4°F - 140°F (-20°C - 60°C)
Weight
28.6lbs. (13kg) approx.
Dimensions (W x H x D)
W: 19" (480mm), H: 7.7" (196mm), D: 20" (515 mm)
Notes
*1: Full Power / Power Saver 1 / Power Saver 2
*2: The luminance values for modes other than Full Power are calculated and are not guaranteed as specification
*3: When standard RS-SL01ST projection lens used
*4: When Lamp Control "ON"
*5: When lens shift mode set to "NORMAL"
*6: Varies when network and other settings applied
*7: Image signals equivalent to the HDMI terminal
WUX7500 Box Contents
WUX7500 Box Contents REALiS WUX7500 Pro AV Projector Lens Cap Power Cord Projector Remote Control RS-RC07 (includes two AA batteries) Lamp RS-LP12 Important Information (book) User's Manual (CD-ROM) Warranty Card
Brochures
Loading...
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you REALiS WUX7500 Pro AV that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
DISCLAIMERS
*1 All white: all black. When standard RS-SL01ST projection lens used. When the iris function is set to "Close 9."
*2 When "Power Saver 2" applied.
*3 This projector includes a DICOM Simulation Mode. It has not been cleared or approved for medical diagnosis and should not be used for these purposes.
*4 When motion blur reduction is activated, brightness will be affected.
*5 Programs and service offerings subject to change without notice. For complete details, including terms and conditions for each program, or to learn more about Service and Support offerings for Canon professional projectors, please contact a Canon sales rep or call 1-800-OK-CANON.
 Return to Top
