Web Content Viewer
Actions
LV-X420
Non-Interchangeable Lens DLP Projectors
Item Code: 1906C002AA
PROJECTORS.USA.CANON.COM is our website dedicated solely to Canon Projectors.
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
Features
This projector projects bright 4200 lumen images with up to a 10,000:1 contrast ratio*1 that helps ensure deep blacks, bright whites and outstanding color. The results are images with crisp depth and dimension, and great color accuracy, which is critical to those with discerning needs.
*1 Full white, full black, lamp level changes by following a brightness characteristic of an image.
Canon's XGA resolution brings bright, true widescreen display of intricately detailed video content and still images with outstanding color richness to midsize room installations in XGA (1024 x 768) at a competitive price. Content is projected without compression. Graphics, text and other visual content from laptops and desktop computers are shown in accurate proportions, just as it appears on most monitor screens. XGA resolution is used in a variety of applications and capable of projecting data produced by many devices.
This projector utilizes Single-chip Digital Light Processing (DLP) technology which is a widely utilized projection technology that creates natural and lifelike images. The DLP technology utilizes a 6-segment color wheel along with a reflective Digital Micromirror Device (DMD) to produce video and images with high brightness. The resulting video and images maintain the details inherent in what you are showing.
To achieve the best possible picture for your setting and presentation content, this projector features flexible image adjustment options. These include Multiple Image Modes and a Screen Color Correction function.
Image Modes provide different variations of color reproduction characteristics suitable for the image type and projection environment. They include:
Presentation: Ideal for somewhat bright rooms when text needs to be clear, such as when part of a video presentation.
Standard: Ideal for bright rooms, and when using content from computer screens or motion picture content.
sRGB: Complies with the sRGB standards and is intended to optimize the projection of photographs from sRGB compatible digital cameras.
Movie/Cinema: Intended for richly colorful videos or images.
User1/User2: Two user-defined modes that make it simple for users to customize and store up to two unique image modes. This allows multiple presenters to share the projector while keeping the image settings optimized for diverse subject matters or sources. In this mode, you may also make advanced color adjustments through the management of the six colors (R/G/B/C/M/Y) on the color wheel.
Screen Color Correction Mode
When projecting to a non-white, colored surface, colors of the projected image may appear different from the original image. The Screen Color feature helps to correctly match the colors of projected images to the color of many projected surfaces.
Connections include: HDMI and an HDMI/MHL*2,3,4 connection that simplifies connecting portable devices for video playback.
Industry-standard control and networking inputs include a USB mini B port for service, a network-ready RJ-45 port that enables authorized users to manage and control multiple projectors from any PC on a network (Gigabit data transfer speeds are supported), an RS-232 serial connection for monitoring the projector locally through a third-party control system, a USB Type A port to be used as a power supply terminal and a mini-jack that provides a trigger for screen operation.
*2 To utilize the MHL interface, a MHL cable is needed.
*3 Certain functions may not perform depending on the type of MHL connection. Operation from the remote controller is not possible when connecting an HDMI cable with a MHL adapter.
*4 Wireless remote does not operate while using the projector with an MHL device.
Compatibility with Crestron helps ensure seamless integration into many systems or infrastructures and smooth network management. Support for PJLink™ also makes it possible to control and monitor the projector over a network – this feature is ideal for observing lamp hours, usage and much more.
This projector is also equipped with e-Control, which allows the user to connect with the projector when using HTML via an internet browser. By typing the IP address of the projector into browser, users can connect and access information such as On/Off functions, Source settings, Blank, Inputs and more.
This projector offers a compact, lightweight and portable design ideal for shared use in different corporate or education locations. It weighs approximately 7.5 pounds and measures 12.3" x 4.4" x 9.0", making it relatively easy to move from room to room. It can be conveniently placed on a desk or table, as well as mounted on a wall or ceiling.
This projector offers multiple power-management settings that allow the user to preset stand-by durations, execute power operations and auto-assign functions to the power button.
The design of this projector also allows for simplified maintenance with a filter-free design. The projection lamp can also be replaced while the projector remains ceiling mounted without having to uninstall.
This model is capable of projecting 3D content via the DLP-Link System. Utilizing a 3D player along with DLP Link 3D glasses for your audience, this projector will display bright 3D images.
A 10W built-in speaker makes it easy to add sound to presentations and displays in a range of smaller environments without the need to add additional speakers and sound equipment, or connect to an already-present sound system.
Canon Lamp Based Projector Warranty & Lamp Limited Warranty
All Canon Lamp based Projectors offer peace of mind as they are backed by Canon USA's Projector and Lamp Limited Warranty, which guarantees that the projector will be free from defects in workmanship and materials for 3 years from the date of original purchase, and the Lamp for 120 days from the date of original purchase. For complete terms and conditions click here.
Advanced Warranty Exchange Service Program*5
The Canon Advanced Warranty Exchange Service Program*5 provides you with enhanced warranty service in addition to traditional "mail-in" repair service. The exchange program provides a replacement unit in exchange for your eligible inoperative Canon Projector if repair service is required during the product's limited warranty period.
Service Loaner Program*5
The Canon Service Loaner Program*5 provides a loaner product in the event that your eligible Canon Projector is in need of repair during the limited warranty period. The loaner projector may be used while your inoperative unit is being serviced via Canon's "mail-in" repair service.
CarePAK PRO AV Extended Service Plan*5
The Canon CarePAK PRO AV Extended Service Plan*5 offers options for one year or two years additional coverage for up to five full years of service and support from the date the Projector is purchased (only available on select models).
*5 Programs and service offerings subject to change without notice. For complete details, including terms and conditions for each program, or to learn more about Service and Support offerings for Canon professional projectors, please contact a Canon sales rep or call 1-800-OK-CANON.
Main Unit Spec
Projector Specifications
Imaging Device
DMD, x1
Aspect Ratio
4:3
Native Resolution
1024 x 768 (XGA)
Brightness
4200/3360 lm ◊1
Uniformity
80%
Contrast Ratio
10,000:1 ◊2
Digital Keystone
V: ±30°, H: ±30°
Electric Zoom
2x maximum (1.8 when overscan display)
Optics
F Number, Focal Length
F2.42 - F2.97, f=20.7 - 31.1mm
Zoom
1.5x
Focus
Manual
Image Size W:
40 - 260"
Image Size T:
30 - 170"
Projector Distance
1.20 -10.00m
Throw Ratio
1.83:1 - 2.75:1 ◊4
Lens Shift
64%, fixed
Image Adjustments
Image Mode
Presentation / Standard / sRGB / Movie/Cinema / User 1 / User 2
Color Adjustment
Color Temperature, Color Balance, Color Tint
Pale Yellow, Pink, Pale Green, Blue, Blackboard
Mounting
Front Table, Rear Table, Front Ceiling, Rear Ceiling
Adjustable Feet
Front : 1, Rear 1
Image Signals
Scanning Frequency
V: 24Hz - 119.989 Hz, H: 15.73 kHz - 101.563 kHz
Analog PC Input
WUXGA / WSXGA+ / UXGA / SXGA+ / WXGA+ / WXGA / SXGA / XGA / SVGA / VGA / MAC
Digital PC Input
Component Video Input
1080p / 1080i / 720p / 576p / 480p / 576i / 480i
Digital Video Input
MHL Input
Video Input/ S-video Input
NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N
Terminals
Dsub15
Analog PC / Component Video Input (x2), Analog PC / Component Video Output (x1)
HDMI
Digital PC / Digital Video Input
HDMI/MHL
Digital PC / Digital Video / MHL Input
Mini DIN4
S-video Input
RCA x3
Video Input / Audio-L / Audio-R
RJ-45
Network Connection (100BASE-TX / 10BASE -T)
Dsub9 (Control)
RS-232C
USB Type A
Power Supply Terminal (1.5A)
USB Mini B
Service Port
Mini Jack
Audio Input (x1), Audio Output (x1)
Mini Jack
12V Output (Trigger for screen operation)
Remote Control
Wireless Remote
IR
Built-In Sound
Internal Amplifier
10W, Monaural
Lamp
Type
Super-high Pressure Lamp
Life
2500H/3000H (Lamp mode: Normal/Eco)◊5
Power
310/245W ◊1
Ratings
Fan Noise
40/36 dB ◊1
Power Consumption
410/320W ◊1
Standby Power Consumption
2.0/0.5W ◊3
Heat Dissipation
Up to 1,399 BTU/h
Power Voltage
AC100 - 240V : 50/60Hz
Operating Temperature
41°F - 104°F (RH: 10 - 85%) (No Condensation)
Dimensions (W x H x D)
W: 12.3" x D: 9" x H: 4.4"
Weight
7.49 lbs.
Notes
◊1: Lamp mode is Normal/Eco. Brightness in Eco mode is only a calculated value, and is not guaranteed as specification.
◊2: Full white, full black, lamp level changes by following a brightness characteristic of an image.
◊3: "Standby Power" function is set to Network/RS-232
◊4: Calculated at 100" (diagonal).
◊5: This time guarantees a 50% survival rate and a 50% brightness-maintenance rate. This value does not guarantee the operating life of lamp.
This is to make Misc appear on the page when needed.
LV-X420 Box Contents
LV-X420 Box Contents LV-X420 Projector Power Cord VGA to VGA Connection Cable (Mini Dsub15-Mini Dsub15) Projector Remote Control LV-RC11 (includes battery Type: CR2025) Lamp LV-LP42 Quick Start Guide (book) User's Manual (CD-ROM) Warranty Card
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-X420 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
A&E Specifications
A&E Specifications
File Description:
Date:
07/19/17
Size:
319 KB
Drawings / 3D CAD
File Description:
Date:
07/19/17
Size:
628 KB
Date:
07/19/17
Size:
435 KB
Date:
07/19/17
Size:
472 KB
DISCLAIMERS
 Return to Top
